Old 10-05-2002, 07:59 PM
FEDERAL AGENT
Rides:1995 m3
95sdm3 is a New Registered Member
95 turbo questions
i have some friends at a shop that are going to turbo my 95 m3 with a stand alone engine management system. has anyone had any problems with theirs. any input would help.
thanks,jeff
Old 10-09-2002, 08:16 AM
I drive a beater....
Rides:A sleeper....
Jeff...
more specifics are needed in regards to your question.
Are you asking if people have had problems with stand alone systems?? or, are you asking about custom turbo setups w/stand alone systems, etc...
Old 10-09-2002, 11:29 AM
FEDERAL AGENT
Rides:1995 m3
the big question is what is the most common problem with a turbo bmw. i have had expierence with other types of cars that are turbo so i know the generics about a custom turbo set up on a non-turbo car.
have you had expierence with stand alone systems? is it really necessary with a obd 1 car?
thanks jeff
"Ahhh...Much Better!!"
Old 10-09-2002, 11:45 AM
Rides:A sleeper....
Well...
I think there are varying opinions. I think an adequately programmed chip is sufficient provided you have someone skilled that programs the chip. The benefits of a stand alone system would not be fully utilized by someone like me. I am rather the type of program it to work, and once it does, I don't like messing with it.
If you are familiar with out cars that are non-aspirated and become aspirated, those problems that they experience are also similar problems associated with bimmers. The primary worries is detonation/pre-ignition; however you want to label -- e.g., the engine blowing up. It seems that with a well-programmed chip, and water injection, you can easily run 17 lbs of boost on stock internals. I believe this should yield you around 400+ rwhp and 400+ ft*lbs of torque which is adequate to most people.
If you REALLY want to push the envelope, I think you are talking about major engine work, JE pistons, pauter rods, etc. My compression is 8.5:1 with a 2.0 mm stopper metal head gasket. I would also go with arp head stud kit, etc. OBD-I yields more favorble power gains than OBD-II -- and is much more friendlier to tune than OBD-II cars (it seems at least).
I have not used a stand-alone system with my bimmer. I used one in my MKIV and MKIII; BUT, I was constantly playing around with the boost levels, changing out injectors, fuel pumps, etc. I do not play around with the bimmer as much....so, I personally do not think a stand-alone system is worth the money. I think it IS worth the money if you plan on changing your boost levels, changing your injectors, changing your HFM size, changing your fuel pump, etc...b/c then it would be a useful tool. But, if you are building a system to say run 12 lbs at lo-boost and 17 lbs at hi-boost (that's what I am aiming for) with water injection. Once you build up everything else to handle it, probably larger injectors...maybe a larger fuel pump, etc....I don't see the need for a stand-alone system. Others may disagree; but, once you achieve the A/F ratio you want, really no sense in fooling around with it. Again, if you want to upgrade to say a T61, or a hybrid T3/T4 (is that even possible??)...then perhaps stand-alone is something you might want to consider....
Other problems, heat...but that is generic to all F/I vehicles. Moreso with the bimmers b/c you have to fit the FMIC -- pipe the BOV back in, probably use an external wastegate...depends upon the size of the HFM you are using....etc...etc....people always worry about the longevity of owning an aspirated vehicle; but, hell, how many people ACTUALLY keep a car for MORE than 5 years, not many....
AA has proven to be excellent in programming chips for turbo cars. I am sure there are tuners that are just as good; but, for a no-hassle approach, I think AA is one of the better companies.
Hope this answers your question; but, this is only MY opinion -- others may completely disagree with me on this viewpoint.
Old 10-09-2002, 11:57 AM
FEDERAL AGENT
Rides:1995 m3
since you own vw's then you probably have heard of atp, or advanced tunng products in freemont cali. my friend is getting a link stand alone in his mk3 golf vr6 with a t4 turbo system.
since the price of our bimmers are a lot more than other cars that, to fix and so forth, that i would be that same as you as in that i would not mess with the boost levels either. i would lower the compression with a 2mm head gasket. how did you lower your compression? i am actually looking at a system that that would do 10-12 lbs lo-boost and 14-16 lbs hi-boost. i want this car to still be streetable.
thanks jeff
Old 10-09-2002, 12:05 PM
Rides:'98 BMW M3
Jeff,
Curious but what kind of turbo kit do you have?
Old 10-09-2002, 12:24 PM
FEDERAL AGENT
Rides:1995 m3
my m3 is not turbo yet. i have about 8 months still. my friends are desigining a custom setup for me.
which turbo system from aa do you have?
Old 10-09-2002, 03:14 PM
Rides:'98 BMW M3
I have the OBD2 Turbo Kit. Stage 2 turbo and stage 2 intercooler.
Old 10-09-2002, 05:37 PM
FEDERAL AGENT
Rides:1995 m3
what output do you have?
i know that aa is very reliable for their kits, and besides the main difference of you being the obdII and 3.2L motor, have you had any problems with the motor/reliability of the car?
thanks for all of your guys' input!!!!!!
Old 10-10-2002, 04:51 AM
Rides:A sleeper....
Jeff...
Well, since you want to run 12 lbs at lo-boost and probably 17 lbs at hi-boost like me. How are the leakdown and compression tests? If you are going to lower compression, consider JE pistons/rods, etc... technically, stock internals will hold at LEAST 17 lbs of boost -- I believe OZ is running 22 lbs of boost on stock internals in the mcoupe...whether the engine will last more than 1 year, not sure...but I am assuming you will run 17 lbs only once in a while, maybe once a week at the most....so, 12 lbs i perfectly fine I believe.
You will need water injection (thanks Jon for helping out with that)...Jon (bmwguy206) seems to be very knowledgeable about this and so does Mark (M3turboCA). I believe they do all of the work on their cars and could provide good feedback to you regarding any questions you might have.
My compression was lowered with a 2.0 mm stopper MHG. ARP head bolts and stud kit was also used for insurance. You will also need probably 42 lb injectors (maybe 36 lb injectors are okay; but, at 17 lbs of boost, I would begin to wonder), possibly a larger fuel pump (depending on how old yours is).
I have never aspirated a VW, I owned a golf GTI before, hella fun to drive; but the MKIV and MKIII are supra's (the latest generation and earlier generation).
What type of turbo are you going to use??? What size A/R? internal/external wastegate? are you going to use a hybrid BOV? My whole developmental goal now is to reach 400+ rwhp safely without using the nitrous intercooler. Mine is the 20g mitsubishi -- I believe a T61 will fit -- I've heard of some ideas of using a hybrid turbo, or even a DUAL turbo setup. I think the T61 will spool slower -- but, you will gain more power at the top-end. I would prefer quicker spooling....hence, the head job, port-matching, downpipe, etc...
Still though, my turbo doesn't really kick until about 3500+ rpm's. I WISH I could get it to kick around the 3000 rpm range...that would be SWEET....
What do your friends say about the benefits of a stand alone system versus having a chip that is programmed?
Old 10-10-2002, 08:21 AM
m3wannabe's Avatar
Jedi
Rides:1995 M3 Avus
m3wannabe is a New Registered Member
Click here to email me
"All you touch and all you see, is all your life will ever be" R.W.
Old 10-10-2002, 11:18 AM
FEDERAL AGENT
Rides:1995 m3
the size of turbo i want is actually a t4 ball bearing. it may spool a little slower than the 20g, but the ball earing can make that up a little. i would use an external wastegate.
are most bmw's that are turbo reroute the BOV back into the intake? why dont they just vent it into the atmosphere?
if my friends at the shop could achieve a setup like you said with 400 rwhp and a spool up at 3000 rpm would be great.
my friends at the shop mostly use stand alones for obdII cars. i, personally feel that a good programmed chip would do well for a obd I car.
Old 10-11-2002, 03:54 AM
Rides:A sleeper....
what about the hybrid...
T3/T4 setup, you get the faster spool-up with the benefits of the bigger power of the T4??
You could use a hybrid BOV which I believe is around $500 ...so, that might be a little extravagant just to get the PSHHHH sound...
From what I remember steve telling me and others, the BOV is plumbed back in because of the MAF sensor... I believe if the air is allowed to vent the car will run extremely lean ...and when you come to a hard stop, the car will completely stall.... I've heard of some running with the open BOV's...but, they still have to watch out for stalling problems...
Old 10-11-2002, 04:12 AM
Twin Screw Jockey
Rides:1997 M3/4 + other
James,
The car will actually run pig-rich for a second when the metered air "blows out". The DME measured the air coming in, added fuel for it, but the air is no longer there, so the extra fuel creates a VERY rich condition.
This often is enough under the corresponding low/no load condition to kill the engine.
Steve
Old 10-11-2002, 05:12 AM
Rides:A sleeper....
Thanks...
So much information to learn.... Hopefully one day, I can talk about things knowledgeably...
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
