  #16 (permalink)
Old 12-04-2001, 08:10 PM
Rides:95 BMW M3 5SPD & 95 M3 AU
Qwickm3 is a New Registered Member
I had no idea the turbo sat so close to the bottom of the car. Has anybody ever damaged the set up from running over something?
Damion Moses #620 IP
  #17 (permalink)
Old 12-05-2001, 04:17 AM
Rides:'98 BMW M3
Ryan-
Yes the turbo will only be the serious modification. I'm debating if I should install the water/alcohol injection as well. I already have an aftermarket exhaust, AA lightweight flywheel and turbo clutch installed.
Seedster-
Not sure if I would call it a DIY. It is highly recommended that the installation be done on a lift. If you have one, then just have a good welder, cutting and grinding tools. Not to mention large drill bits and a tap set. More welding will be involved on the 3rd day on the exhaust side. Installation of the intake tubing will be fitted and installed. More grinding is necessary to clear out some parts.
Hoping to install some of the wiring as well.
QwickM3-
I'll take a rear view picture of how parallel in relationship the downpipe is with the body frame. Karl did told me to be careful in going over speedbumps.
  #18 (permalink)
Old 12-05-2001, 04:49 AM
Seedster's Avatar
Rides:96 333i and your mother
Seedster is a New Registered Member
For sure I was assuming you have a lift as well as the given drill/tap/die bits. Nothings looks too complicated as of yet (granted insane amounts of man hours have already been put in ). What does all the "wiring" include? I just wanna know why AA slaps such a high price on their OBD2 forced induction. Also, how is more fuel being added? I.E. with some S/C's its fuel management unit thing which increases fuel pressure with vacuum/boost, with nitrous its a fuel pressure riser (tapped into the stock FPR), how's it done here?
saeed
~333
  #19 (permalink)
Old 12-05-2001, 09:10 AM
==|\/|== is a New Registered Member
Talking
would someone please do a DIY of a DINAN SC now????
  #20 (permalink)
Old 12-05-2001, 09:57 AM
Rides:98 M3
fourfa is a New Registered Member
it's been done, in my driveway. Took a couple days of several hours at a time, maybe 12-15 total? Not hard at all, their kit is remarkably complete. The supercharger install did not require a single trip to the hardware store. I should repeat that: this did not require a SINGLE trip to the store. Everything was included, labeled, and called out in the instructions.
very doable, and for $5,500, pretty much the way to go for 350 hp.
  #21 (permalink)
Old 12-05-2001, 10:23 AM
HRM for the DINAN SC. is there any need for any sort of ECU programming???
  #22 (permalink)
Old 12-05-2001, 10:27 AM
Rides:98 M3
yes, and they don't have a flasher like the SharkInjector. Luckily we live 5 minutes from Dinan, so no problem.
  #23 (permalink)
Old 12-05-2001, 12:43 PM
Boozin
Rides:E30 M3 (89)
Kevin is a New Registered Member
Yeah that looks like a fairly easy install considering whats being done. I would definitly do it myself but take my time although I don't have a E36.
  #24 (permalink)
Old 12-05-2001, 12:56 PM
Ces Ces is offline
Rides:A Tortured Hellrott
Ces is a New Registered Member
I was under the impression they only did the obd2 turbo in-house? am i wrong or what?
  #25 (permalink)
Old 12-05-2001, 12:58 PM
Rides:325is
Bernman is a New Registered Member
It only looks easy because we are getting the "Reader's Digest" version
I can't really imagine trying to drill, tap, and weld with the car on jackstands. How many of us have lifts so we can go up and down at will to access the top and bottom of the car? Not to mention being able to stand underneath...
I think if you are thinking of doing forced injection in your garage, you should be thinking of something that is belt driven.
Thanks for the write-up Jon. Great stuff!
Bernman
  #26 (permalink)
Old 11-23-2003, 03:26 PM
bimmerdriver99's Avatar
99 dakar m3
Rides:99 Dakar M3
bimmerdriver99 is a New Registered Member
ahh ya i was just wondering how much does AA charge for there install in the 1st place Just wondering. also what is the difference between internal and external BOV's is it the External that makes that Pshhhhhhh sound
Camera: NIKON D100 |PHOTO WEBSITE| /// M POWER
  #27 (permalink)
Old 11-23-2003, 03:31 PM
Rides:DTMPOWER Project E36 M3, E46 323
Neel
I guess this eliminates Ernie :got me:
http://www.myspace.com/dtmpower
I can't see pics at work.
Websense
  #28 (permalink)
Old 11-23-2003, 03:48 PM
Rides:bob49
bob49 is a New Registered Member
internal and external Wastegates i think you mean...
  #29 (permalink)
Old 11-23-2003, 05:09 PM
KLEAR's Avatar
Rides:'95 325is
KLEAR is a New Registered Member
Can be done w/o a lift, done in my backyard, but had to be welded elsewhere.
  #30 (permalink)
Old 11-23-2003, 05:19 PM
triplebeam's Avatar
Rides:1993 325is w/M3 Swap & 88 Civic Hatch w/a B18
triplebeam is a New Registered Member
Ryan-
I dont know the numbers know but on low boost I might be looking at 380hp and on high boost it'll be around 400hp. I dont know when the installation will be done. I'm thinking late next week.
Awesome, Hey what do you consider low boost? & what would you say is high boost? Just wondering cause I plan on doing a similar project Thanks
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458
