Closed Thread
  #16 (permalink)
Old 09-27-2002, 04:53 PM
Matt's Avatar
matt
Rides:1990 325i
I just can't stand it when people get all BMW-sighted. Wonderful cars, of course, but not the be all and end all.
  #17 (permalink)
Old 09-27-2002, 05:00 PM
Jasons TEG's Avatar
Pristine Performance
Rides:Integra that's for sale
Jasons TEG is a New Registered Member
Just a heads up for all the people saying "Vtech" instead of "VTEC".
Vtech, with an "H", is a phone company... www.vtech.com
VTEC, without an "H", is Honda's Variable Valve timing and electronic lift control.
Jason-
PS. VTEC is better.
Dealer prices on AA, Dinan and BMP Products!
Jason@PristinePerformance.com
Recent shipment of Dinan products for sale BELOW dealer cost.
  #18 (permalink)
Old 09-27-2002, 05:01 PM
Rob ITR1035's Avatar
Beer Technician
Rides:Subaru Legacy Wagon
Rob ITR1035 is a New Registered Member
like i said, check out the avatar for 'vtech'
Beer Tech's Very Own Forum
  #19 (permalink)
Old 09-27-2002, 05:03 PM
scottycs's Avatar
Custom Turbo 328
Rides:e28, e30, e36, e39
hah I didnt notice i did that.
-Chris
  #20 (permalink)
Old 09-27-2002, 08:36 PM
alen's Avatar
Rides:j31'ed A4
alen alen alen alen alen alen alen alen alen alen alen
Originally posted by ///M3Hellrot
I have trouble believing that the VVT system on a $35k Honda S2000 is better than the double Vanos system on a $75k BMW M5. Is it just me? Seems like you can't really aruge this point.
with the cars you are comparing, why not just compare civic ex with the m3 and their vvt systems. lol
  #21 (permalink)
Old 09-27-2002, 10:21 PM
Tony Mack's Avatar
Master Debater
Rides:vehicle that does not attend BMW Meets NEMore
Tony Mack is a New Registered Member
HERE VANOS EXPLAINED
VANOS is a combined hydraulic and mechanical camshaft control device managed by the car's DME engine management system.
The VANOS system is based on an adjustment mechanism that can modify the position of the intake camshaft versus the crankshaft. Double-VANOS adds an adjustment of the intake and outlet camshafts.
VANOS operates on the intake camshaft in accordance with engine speed and accelerator pedal position. At the lower end of the engine-speed scale, the intake valves are opened later, which improves idling quality and smoothness. At moderate engine speeds, the intake valves open much earlier, which boosts torque and permits exhaust gas re-circulation inside the combustion chambers, reducing fuel consumption and exhaust emissions. Finally, at high engine speeds, intake valve opening is once again delayed, so that full power can be developed.
VANOS significantly enhances emission management, increases output and torque, and offers better idling quality and fuel economy. The latest version of VANOS is double-VANOS, used in the new M3.
VANOS was first introduced in 1992 on the BMW M50 engine used in the 5 Series.
In overhead cam engines, the cams are connected to the crankshaft by either a belt or chain and gears. In BMW VANOS motors there is a chain and some sprockets.
The crankshaft drives a sprocket on the exhaust cam, and the exhaust cam sprocket is bolted to the exhaust cam. A second set of teeth moves a second chain that goes across to the intake cam. The big sprocket on the intake cam is not bolted to the cam, for it has a big hole in the middle. Inside the hole is a helical set of teeth. On the end of the cam is a gear that is also helical on the outside, but it's too small to connect to the teeth on the inside of the big sprocket. There is a little cup of metal with helical teeth to match the cam on the inside and to match the sprocket on the outside. The V (Variable) in VANOS is due to the helical nature of the teeth. The cup gear is moved by a hydraulic mechanism that works on oil pressure controlled by the DME.
At idle, the cam timing is retarded. Just off idle, the DME energizes a solenoid which allows oil pressure to move that cup gear to advance the cam 12.5 degrees at midrange, and then at about 5000 rpm, it allows it to come back to the original position. The greater advance causes better cylinder fill at mid rpms for better torque. The noise some people hear is the result of tolerances that make the sprocket wiggle a bit as the cup gear is moved in or out.
Double-VANOS (double-variable camshaft control) significantly improves torque since valve timing on both the intake and outlet camshafts are adjusted to the power required from the engine as a function of gas pedal position and engine speed.
On most BMW engines that use a single VANOS, the timing of the intake cam is only changed at two distinct rpm points, while on the double-VANOS system, the timing of the intake and exhaust cams are continuously variable throughout the majority of the rpm range.
With double-VANOS, the opening period of the intake valves are extended by 12 degrees with an increase in valve lift by 0.9 mm.
Double-VANOS requires very high oil pressure in order to adjust the camshafts very quickly and accurately, ensuring better torque at low engine speeds and better power at high speeds. With the amount of un-burnt residual gases being reduced, engine idle is improved. Special engine management control maps for the warm-up phase help the catalytic converter reach operating temperature sooner.
Double-VANOS improves low rpm power, flattens the torque curve, and widens the powerband for a given set of camshafts. The double-VANOS engine has a 450 rpm lower torque peak and a 200 rpm higher horsepower peak than single-VANOS, and the torque curve is improved between 1500 - 3800 rpm. At the same time, the torque does not fall off as fast past the horsepower peak.
The advantage of double-VANOS is that the system controls the flow of hot exhaust gases into the intake manifold individually for all operating conditions. This is referred to as "internal" exhaust gas re-circulation, allowing very fine dosage of the amount of exhaust gas recycled.
While the engine is warming up, VANOS improves the fuel/air mixture and helps to quickly warm up the catalytic converter to its normal operating temperature. When the engine is idling, the system keeps idle speeds smooth and consistent thanks to the reduction of exhaust gas re-circulation to a minimum. Under part load, exhaust gas re-circulation is increased to a much higher level, allowing the engine to run on a wider opening angle of the throttle butterfly in the interest of greater fuel economy. Under full load, the system switches back to a low re-circulation volume providing the cylinders with as much oxygen as possible.
I will start attending Bmw meets again in the future if anyone
  #22 (permalink)
Old 09-27-2002, 10:27 PM
alen's Avatar
Rides:j31'ed A4
couldn't have explained it better
  #23 (permalink)
Old 09-27-2002, 11:37 PM
phatfarm's Avatar
Rides:e34 95 530i
phatfarm is a New Registered Member
haha how did i know i would see these kind of retarted posts... go to bimmerforums if u want an educated answer.. but then again in bimmerforums u get all the nerds bitching and moaning about not being able to get girls... (in off-topic)....
  #24 (permalink)
Old 09-28-2002, 12:40 AM
Rides:89 dinan 535i turbo
535turbo is a New Registered Member
Bottom line you cant compare bimmers and hondas. The only car that comes close to equal engineering is the s2000, 240hp out a 4cyl, that was one of the most craziest ride ive ever been on, the acceleration, the handling, the braking, i could expect nothing more from a porsche.
  #25 (permalink)
Old 09-28-2002, 06:22 AM
Beer Technician
actually i think we already discussed that....in a discussion about vvt systems, you definately compare bmw and honda...i wont say one is better than the other, both have their advantages.
  #26 (permalink)
Old 09-28-2002, 06:47 AM
Han's Avatar
Han Han is offline
Bus Driver
Rides:1990 ///M3
Han is a New Registered Member
christ.. i hate these threads.
nothing but ignorance. at you bmw guys.
get off your high horses.
VTEC is a better system than VANOS.
the S2000 is faster than the e36 m3 (straight line, and turns).
  #27 (permalink)
Old 09-28-2002, 07:01 AM
Beer Technician
no way man, no way in hell is something on a 35k car as good as something on a BMW
  #28 (permalink)
Old 09-28-2002, 07:07 AM
Josh's Avatar
Rides:in a car
What is the most powerful street motor in a production car that uses VTEC?
  #29 (permalink)
Old 09-28-2002, 07:11 AM
Beer Technician
Acura NSX...
3.2liter: 290hp @ 7100rpm, 224ft lbs @ 5500rpm
  #30 (permalink)
Old 09-28-2002, 07:23 AM
Josh's Avatar
Rides:in a car
With that said, I am going to play devil's advocate here, putting the merrits of both systems aside. If infact, VTEC is the better system, why is it out matched by BMW's Vanos equipped S50B32 and S54 motors with similar displacement as the NSX motor by a 30 to nearly 50 horsepower margin? Is there still advantage to the NSX motor over the two BMW motors mentioned?
Closed Thread
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366
