Old 09-27-2002, 12:27 AM
womanizer
Rides:95 Cosmos M3
twinturbobb is a New Registered Member
Vanos or no Vanos......?
i see some people liking the non-vanos 325i and some liking it more. correct me if im wrong, but vanos is variable valve timing on the exhaust cam, creating a higher exhaust gas velocity coming out of the combustion chamber, therefore resulting in higher torque all around. much like vtec on a honda motor, this seems like a good idea. aside from forced induction, why would you not want this to be on your bmw?
Brandon
95' M3 Cosmos 5spd
95' Toyota Supra TT 6spd (sold)
87' 325is (sold)
Old 09-27-2002, 01:51 AM
M3GTDRIVER's Avatar
M3 GT DRIVER
Rides:'95 E36 M3 GT
M3GTDRIVER is a New Registered Member
Vanos or not vanos ?
Variabelen Nockenwelle Steuerung (Variabel Cam Timing) is a way to get better overall performance out of the engine. The Singel Vanos only adjusts the intake cam and it's used to tame the camtiming of a, for normal streetuse, too wild cam so it can be used for normal streetuse. It let's the engine idle decent by reducing the camoverlap and also it will produce more torque at lower rpm's. The vanossystem works from Idle up to 6000rpm and it's also used to govern the max speed of 155mph in the M3 for instance.
The newer Double Vanos has adjustment of both intake and exhaust cam. The addition of the exhaust cam timing is for emission and economy only.
Old 09-27-2002, 01:44 PM
womanizer
Rides:95 Cosmos M3
ok, so once again.........why would you not want this?
Brandon
95' M3 Cosmos 5spd
87' 325is (sold)
Old 09-27-2002, 01:52 PM
BMWKrazed's Avatar
Young M Driver
Rides:04 STi
BMWKrazed is a New Registered Member
i think i understand VANOS. but i don know what setup my car has, maybe someone can help
i have a 98 M3 coupe (non-lux) and i was wondering if i have single or double VANOS...?? i have no idea (obviously)
Old 09-27-2002, 01:53 PM
Evolution Driver
Rides:1998 BMW M3
BMWM3some is a New Registered Member
There is no reason you wouldnt want it, people who dont have it just like to think that to make themselves feel better, if it wasnt good BMW wouldnt have created it and put it on their cars. Also if it wasn't good the Evo II Euro M3's wouldn't have DUAL VANOS instead of single VANOS like in the US .
2003 Mitsubishi Lancer Evolution
Rally Red
Old 09-27-2002, 01:54 PM
Evolution Driver
Rides:1998 BMW M3
Your car has single VANOS, No E36 US SPEC M3 has Dual VANOS, only the EVO II European M3's had the Dual VANOS, so to answer your question you have single VANOS.
Rally Red
Old 09-27-2002, 01:57 PM
BMWKrazed's Avatar
Young M Driver
Rides:04 STi
thanks for that fast repple BMWM3some!
now ill have to go get the euro spec s52(or whatever it is there)
Old 09-27-2002, 07:09 PM
Rides:Nissan 240sx
cdlong is a New Registered Member
for a highly tuned engine, it doesn't help much since you shift enough to keep the engine in higher rpms. (read "highly tuned" as "race")
it's more complicated, more things that might break. and heavier, not weight of the car, but weight of the valve train, extra weight hurts throttle response. and it makes the power less linear, you don't want the power at the wheels to spike right in the middle of a turn and spin you.
Old 09-27-2002, 10:08 PM
womanizer
Rides:95 Cosmos M3
so the difference is the torque and what not, but can you actually feel a difference between a vanos and non-vanos car? or is it just evident on paper..........?
Brandon
95' M3 Cosmos 5spd
87' 325is (sold)
Old 09-28-2002, 02:47 AM
Guido's Avatar
Italy's Finest
Rides:whatever suits me at the moment (usually 95M)
Guido is a New Registered Member
if you were to buy a set of shrick cams, how would this affect the venos's performance
Old 09-29-2002, 12:28 PM
M3GTDRIVER's Avatar
M3 GT DRIVER
Rides:'95 E36 M3 GT
VANOS the GRAPH.
Here's a graph below with the hp and torque of the Euro M3 3.0L engine (S50B30). Hp is in KiloWatts (multiply with 1.4 to get HP, roughly) and Torque is in Nm (devide by 1.5 to get FtLb, roughly).
Anyway, you can see that max. Torque is from 3500rpm up to about 6000rpm almost constant and if you don't use blowers or a turbo it's unpossible to create such a torque-curve (this is not a curve but a straight) without the VANOS system.
So I would say the only ones that say they don't wanna have it are the ones that don't HAVE it and the ones that have it are the lucky ones.
Okay if you have a race car with a typical rpm range between 6500 and 8500rpm or higher you would use the VANOS only during start or during a lowspeed first gear turn or at a pitstop and then you could ask if the complexety and extra weight are to bare in favor of the 'low'speed torque.
But in case of the daily driver / groceriegetter that only sees max shift-rpm only once in a while, make sure you have it!! You are far better of with it.
Grtz M3GTDRIVER.
p.s. The race M3 I work on, uses the same VANOS system since 1993, with no problem. max rpm about 9000rpm.
Old 10-01-2002, 06:05 PM
womanizer
Rides:95 Cosmos M3
ttt
Brandon
95' M3 Cosmos 5spd
87' 325is (sold)
Old 10-02-2002, 07:04 AM
M3GTDRIVER's Avatar
M3 GT DRIVER
Rides:'95 E36 M3 GT
Hi Brandon what does that mean, ttt ??????
Yes I drive a '95 M3 GT and it's the best car I ever had!!
Mod's: Group-N exhaust and finally found original GT-rearwing raising blocks.
Old 10-02-2002, 07:33 AM
Rides:Nissan 240sx
To The Top
it sends the thread to the top of the list so people will see it and reply. i'm not sure why he did that cause i thought we covered pretty much everything.
Old 10-02-2002, 11:08 AM
womanizer
Rides:95 Cosmos M3
i was just wanting to get more info and a few more opinions on this, but it seems like no one wants to post about it anymore :-/
Brandon
95' M3 Cosmos 5spd
87' 325is (sold)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
