Old 09-24-2002, 08:30 PM
600hp E39 pilot
Rides:BMW E39 1998 532i
SC5-Charles is a New Registered Member
Exclamation Welcome to the DARK SIDE: PART ONE
Welcome to the DARK SIDE PART ONE: Vacation in Miami
NOTE: Those of you who have inside information regarding the current status of the car, all shall be revealed in time. J
Background: Show dynochart of supercharger setup. (In the case that the attachment does not appear it shows 363 hp and 303 ft-lbs torque on a dynojet. Those of you who are familiar with the car will find this redundant. For those that are not, then this a little background information to better understand the situation.
February 2000 – A normal 1998 E39 528iA goes under the knife for an ESS Powerdyne 6psi blower kit. After 36 hours of intense labor, out comes out an acquired taste for pure evil (power). It is raining during my first ride in the new setup. Immediately my first reaction is, “Hmmm not what I was expecting…”
September 2000 – Upon the success of Jon Sibal’s transmission swap, talks regarding a 5-gear manual transmission swap begins with Michelangelo Motorwerkes. My reasoning was simple: Slush box vs. clutch; doesn’t take a mental giant to know that manual trannys put more power to the ground. In addition with the automatic being only 4 gears, and the manual being a closely spaced 5 gears, acceleration was about to change from night to day.
December 2000 – I discover an RMS Stage 2 E46 3.2 liter car will soon be dismantled. In one fell swoop I acquire everything under that hood. Inline 3.2 liter E36 M3 engine, Vortech S/C, Supersprint headers, RMS stage 1 aftercooler, OBD1 wiring harness, and M50 intake manifold.
March 2001 – the transformation is complete. The first time I’m taken out in the car it is raining again. The car is strong. However the aftercooler tank as well as aftercooler radiator is not complete and I’m advised to stay under full throttle. I learn to mix my own gas
August 2001 – The aftercooler is complete. Upon installation of the aftercooler I try full throttle and discover what engine knock is (hereon referred as ping). Thus begins my year-long crusade to eliminate ping. I suspect the RMS software is not performing. Months of dealing with only Michelangelo Motorwerkes are mostly fruitless. I attempt to search farther in terms of geography
September 2001 – Trailer my car up to Sonoma’s Sear’s Point Raceway for installation and tuning of Unichip. It is discovered that there are unknown limitations on the car causing the car to lean out above 5500 RPMS. This is my “ghost” that I must find and rid my car of.
November 2001 – Talks with Karl from AA begin regarding larger HFM as well as custom tuned chip. Installation of chip and HFM do not solve detonation. The existence of the “ghost” is confirmed.
January 2002 – Car enters SHO Shop under Vadim’s care. After 2 months and thousands of dollars spent, the car is returned in virtually the same condition it was given. I am getting desperate. Software solutions are not the answer to the problem. There’s something else wrong with the car.
May 2002 – Talks with Active Autowerke go into full effect. Through a personal friend and countless stories I learn of their abilities and solutions to all problems. Frustration gets the best of me…
A long introduction, and this is where my story begins…
It’s a hot afternoon and the truck appears outside my front door. It’s a lot larger than I’d imagined it to be. A 53’ Fully enclosed big yellow 18-wheeler with the words “Exotic Car Transport” written on the side of it. It’s tall enough to brush up against the trees on my front lawn. In less than 30 minutes my car is among some of the most exotic cars in the world. 996TT, Ferraris, and one-of-a-kinds I’ve never heard of. Destination: Miami Florida, headed for Active Autowerke. My goal is simple: Let’s get this thing running the way it should be and hopefully make as close to 400hp to the wheels as possible through custom tuned software, cams, upgraded pulley, etc.
I’ll tell you it was the strangest feeling in the world watching that trailer leave with my baby in it. Then again in my heart, part of me was saying “Good riddance” since so much frustration and anger had resulted in my endeavor to undertake a task greater than the abilities of a few west-coast tuners put together.
My feelings regarding the decision I made:
I read the DTM boards in addition to the bimmerforums.com quite often and I see the nightmares people have with problems with their cars on an almost daily basis. Occasionally the nightmare takes the form of a faulty part that is BMW’s fault. Sometimes the nightmares are misunderstandings between a customer and a vendor but more than often it’s the result of someone being “unable to deliver”. Let’s face the facts. Regardless of what the problem or situation is, when you turn to a “specialist” to solve your problems, there is a certain level of expectation that actions will be taken to remedy the problem, right? Let’s leave the politics and courtesy at the door. When the shit hits the fan all that matters is, “Can you walk your talk?” It all boils down to competence. But this is not a post for me to complain about how I was wronged by so-and-so. I brought that stuff onto myself in attempting to do something that had never been done so let me deal with it. However when good money is spent for services that aren’t delivered then there’s a “slight discrepancy” with what you wanted compared with what you get (to say the least).
When I sent my car to Active, I caught the first glimpse of hope I’d seen in a LONG time. I get regular reports from Karl and it has never been difficult to keep up with exactly where the project is and what has been done to solve the problems for the car. Within the first 2 days of inspection, Karl Hugh found my “ghost”. The “ghost” was a 2nd fuel pressure regulator that someone escaped the attention of many who have looked through this car. Apparently when the engine swap with OBD2 to OBD1 swap took place, OBD2 left an FPR in the car, and the engine came with an FPR as well. It makes me rather sad that an FPR can go unnoticed for an entire year on the west coast yet be resolved in the matter of 3 days on the east coast. I have the utmost love for the westside, but come on now. I’m at a loss of words when I think about the amount of time, money, and effort I put in (and not being a mechanic it’s like searching for a needle in the haystack trying to find my “ghost”), between March 2001 and May 2002. The amount in thousands would unfortunately be an understatement. Perhaps that is a harsh lesson learned as well when undertaking something you don’t understand quite well enough.
I hope I don’t come across as preaching because I feel that if just one person learns from my mistakes then I’ve saved someone a lot of trouble. I put off sending my car to Florida for the longest time because I figured the cost of the transport wouldn’t be cost effective. But instead I wasted a lot more money, time, and effort messing around with incompetence. If you’re going to do something, have it done right the first time. You reap what you sow.
Not wanting to end on a negative note, in the span of 3 days the car was tuned for 340+ hp and 310 ft-lbs of torque on AA’s Mustang dyno. Considerable gains were made in torque though not too as much for horsepower. Thus the saga continues and we’ll see what the car can put out with cams and a new pulley…
Attachment below is a dyno of the car on a dynojet during testing before being sent to Florida.
Old 09-24-2002, 08:35 PM
Rides:two four dour family sedans :)
ernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master Licenseernie has achieved their Master License
Muahahahahahahaha. For those who dont know, Charles is one power crazy guy. Just how much, I guess we will find out soon.......
Ernie
ernie-2 dremel tool-0
richard is my hero
Old 09-24-2002, 09:20 PM
Chase265's Avatar
Rides:E46 323Ci
Chase265 is a New Registered Member
wow i don't believe i read the whole thing....
it sounds like things are progressing nicely..I hope things works out the way you want charles...
Old 09-24-2002, 10:18 PM
Rides:what don't i drive?
typejr is a New Registered Member
I gave up reading after it said 335 hp or something like that.
gimme a break! it's 1:18 am and I have class at 8! blahhh
Old 09-24-2002, 10:19 PM
crap it's 363
Old 09-24-2002, 10:31 PM
325_JdP's Avatar
this is my 5th car
Rides:1999 Accord LX
325_JdP is a New Registered Member
its frickin 1:30am. i'll read when i'm *REALLY* bored.
Old 09-24-2002, 11:08 PM
occupational hazzard
Rides:///M?
///Nima is a New Registered Member
Charles,
congrates and thanks for the heads up!
-Nima
Something old/new soon
Old 09-25-2002, 02:34 AM
Suneal's Avatar
Rides:Cooper S
Suneal is a New Registered Member
Old 09-25-2002, 05:23 AM
Orange County Rep.
Rides:2005 Audi S4
tranmanm3 is a New Registered Member
Charles,
Cant wait to see the finished product.
Hope everything works out and I hope all is well
Old 09-25-2002, 05:46 AM
Rides:'98 BMW M3
I just cant wait for part two
Old 09-25-2002, 06:07 AM
alen's Avatar
Rides:j31'ed A4
alen alen alen alen alen alen alen alen alen alen alen
nice story, i hope your long-term project will progress well in the future.
Old 09-25-2002, 06:35 AM
PrinceE30's Avatar
Stick Shift Cowboy
Rides:1991 BMW 318is
PrinceE30 is a New Registered Member
Score one for AA...
That puts an end to the question on who's doing engine work when I get some money together...
-Prince
Randall Prince
http://www.rp1.us/ Used Cars
Old 09-25-2002, 06:48 AM
E36M3's Avatar
Rides:E36M3 3.3 OBD1, RMS Stg3
E36M3 is a New Registered Member
Hey Charles! Glad to hear things are going better. Believe it or not, this is not the first time I have heard "specialists" forgetting about a FPR. In fact, when I asked several specialists if our cars come stock with FPR's, many of them don't know. Unbelievable.
As you know, I have a ton done under the hood as well. The car is going in for "final" tuning soon and I want to send it to a competent place. Are you saying that you couldn't find anyone out here, including Evosport? They might tune the car and I want to find out your opinion. They will be tuning through a TEC3.
Bottom line, I'll pay for results. Even if that means sending it to the Eastside on a trailer. I just know the motor is capable of much more than it is currently putting out.
Old 09-25-2002, 07:38 AM
Magnus's Avatar
Dado's REAL Wifey.
Rides:Car
Magnus has achieved their Master LicenseMagnus has achieved their Master LicenseMagnus has achieved their Master LicenseMagnus has achieved their Master LicenseMagnus has achieved their Master LicenseMagnus has achieved their Master LicenseMagnus has achieved their Master LicenseMagnus has achieved their Master LicenseMagnus has achieved their Master LicenseMagnus has achieved their Master LicenseMagnus has achieved their Master License
Happy it's done
The favor tree is dead. Sorry. Queef!
DTMPøwe!
Old 09-25-2002, 07:42 AM
600hp E39 pilot
I'm shocked at the amount of support from the enthusiasts. I look to many of you for advice and/or just to throw around ideas. I'll try to respond to as many of your comments as possible:
E36M3: I honestly don't want to do any finger pointing. All I can tell you is what I have experienced. The car was at Evoport for way too long and they didn't really solve any of my problems. I would strongly suggest you to take this consideration seriously for tuning your TEC3, I thought you were going to send it to RMS though...
Ernie: Give me a call tonight, we have to finish talking lol
Again, tranmann, PrinceE30, alen, nima, Mr. Caldito, 740idogg, chase265, typejr, etc. thanks for showing your support for this ridiculous adventure hehehe
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
