Old 09-18-2002, 07:51 PM
AaronM3's Avatar
Rides:95 BMW M3
AaronM3 is a New Registered Member
rebuilt engines safe to run turbo/sc?
Alright, I just recently blew up piston 5 and her valves.... which i just replaced. Engine has 74k on it.. its a 95 3.0L M3.... is she safe to run turbo/sc on? I seriously have the need for speed and i want to kick some local ass around here on the street .... and my baby needs some firepower under her hood. I am looking at being content around 350-400 HP ( 300ish at the wheel) ... and the rest will go to tunes and ride. But my question is will my engine handle the pressure of say 8psi or 12 being fixed up? I resealed all my other pistons and my compression is all around 200 give or take.... am i alright or do I have a problem? Also, how hard is it to install a turbo? Sorry so many questions, just entertain me please.
" drive hard or get out of the way"
Old 09-19-2002, 02:51 AM
Rides:95 M3 & 94 325is
JCM3 is a New Registered Member
I wouldn't see why not. As long as the motor is is good health (compression) then I say do it. But first did you replace the parts w/ oem quality components and did they check the rods & bearings? If so then 8 psi should be no problem w/ either alcohol inj (s/c) or good front mount/ headgasket (turbo).
Old 09-19-2002, 04:09 AM
I drive a beater....
Rides:A sleeper....
to run 12 though...
you might have to lower the compression, just to be on the safe side of things, plus, ARP head stud kit would be nice -- I believe AA's stage I gen III is around 360 at the crank....
problem is -- trust me, you will want more boost....just when you think you are satisfied, it pulls you back in..... sometimes it is better just to WISH....rather than to have...because you crave more and more....
you start thinking of ...hmm... a T61 would sound nice.... perhaps I can reach the 500 rwhp level....hehe...
Old 09-19-2002, 05:34 AM
Paddy Mack's Avatar
Rides:MMMGood 95 M3
Paddy Mack is a New Registered Member
Re: to run 12 though...
My thoughts exactly
While the engine's on the operating floor, bore it out a bit, put in some different pistons and rings to lower the c/r for some room to play with later.
it's exactly what I did. My c/r is currently b/t 8.1 - 8.3. Currently running 9 psi w/absolutely no detonation worries and putting out b/t 350-360 rwhp. At some point I plan on going to b/t 12 and 14 and the lower the c/r at that point, the better. Of course, I'll need to do some other things at that point as well.
Old 09-19-2002, 07:34 AM
Rides:A sleeper....
right...
Manifold and head work was done while the engine was out to give a little better airflow, and it was stroked a bit. I think JE rods and pistons would be the next step if I decided to approach one bar on a consistent basis.
I know the car can safely handle 13 psi -- it was dynoed at 18 psi and a nitrous intercooler was hooked up -- but that has me edgy to do that, although the mcoupe AA has been dynoing at 19 psi with stock internals...so who knows...maybe 1 bar is safe with stock internals.
I think if I can run one bar safely w/o detonation -- I'll be happy....although I say that now.
I only run 7 lbs right now, because anymore is honestly overkill where I live and it keeps up with most cars or beats them.... what size injectors are you running paddy mack?
I have a holley fuel pump and 55 lb. injectors which I think are WAY to big. I might go back down to 42 lb. injectors, or maybe even 36 lb ones. I think my fuel consumption would improve dramatically as a result. I'm running a little rich to be safe since I don't have a stand alone fuel management system right now. I think the ECU does an adequate job right now.... I don't need to get crazy with things.
Old 09-19-2002, 08:14 AM
Paddy Mack's Avatar
Rides:MMMGood 95 M3
55?!?
Mine are 35. Out of curiousity who did your tuning and do you know why they're that big?
Like yours, outside of the SSR comp rims, mine's a total sleeper too. Keeps away the punks on the streets better that way. Dang.....still have to take the racing number off the window though!
Old 09-19-2002, 08:47 AM
Rides:A sleeper....
hey...
everyone's jaw drops like that. I don't think even Craig's 700+ supra had 55 lb injectors in it. Not really sure what they were thinking. It was an AA tuner that does work in NJ/NY for them and has done multiple installs. So, it wasn't just some sideshow freak ...
The ONLY reason why I would guess 55 lb. injectors were put in is because they were contemplating a HUGE turbo -- but, even then, I think 42 lb. injectors would suffice....just upgrade the fuel pump -- and everything should be fine.
It's nice having a sleeper -- although I am seriously considering the aquamist system and yanking the nitrous n-tercooler system in there. I like the idea of a water system cleaning my valves, etc. Aftercooling I don't think is as beneficial as water injection; but, that's just my thoughts. With water injection, I probably could run one bar safely...
I am also going to S/C the green bimmer -- I'd like to compare the two as far as driveability, enjoyability, etc. Right now, I'd like to upgrade my speakers and sound system; but, I am saving the money for the S/C right now.....I even stopped myself from buying the pool table...although, I am still bitter about that.....
But, the silver one is not getting great gas mileage, my thoughts are that these injectors are way to big, but, I don't want to fool with it either, its running perfect...and I am a big fan of the cliche, if it ain't broke, don't try to fix it....
So, I am ambivalent about fooling with anything on the engine right now....only maybe the water injection -- but, that's a different animal....
Old 09-19-2002, 09:00 AM
Paddy Mack's Avatar
Rides:MMMGood 95 M3
To that end, check out EBAY. I've seen some very slightly used Vortech's for just over 50% under the price of a new unit. Just last week there was a Vortec w/10k miles on it that went for $3500. You probably know all this but........if you don't plan to go over 10 PSI w/the s/c you may want to look at a Powerdyne unit - it's also much quieter.
Next year I'll be getting the WAI myself to go along w/the added boost. AA has a quality WAI unit but there's also a maker up here in KC that makes it for several hundred below theirs. For a pro it's mounted in the engine bay thereby missing trunk cd player, shorter lines, and no gravity worries. The con is you don't have the luxury of automatically washing your windshield anymore as it uses that reservoir and a slightly smaller tank. If you're interested I'll PM the site.
Old 09-24-2002, 11:32 AM
Rides:E46 M3
Full throttle is a New Registered Member
It's like a drug! You always want more and more and more and more...
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
