Old 09-06-2002, 07:43 PM
Rides:98 M3
TurboM3 is a New Registered Member
Turbo Guages
What are the 3 guages that are used when having a turbo application?
also does anyone have A pillar pics that can post for me?
Thanks
Mark
M3s are fast!
Audio
Focal
McIntosh
A/D/S
Old 09-07-2002, 03:35 AM
Dakar is Fast
Rides:Carrera Aero
icemann633 is a New Registered Member
Boost, Air-Fuel Mixture, Exhaust Temp(EGT)
Old 09-07-2002, 12:54 PM
Rides:98 M3
cool thanks for the heads up.
You wouldnt happen to know any online stores where i could check them our do you?
Thanks
Mark
M3s are fast!
Audio
Focal
McIntosh
A/D/S
Old 09-07-2002, 08:45 PM
Rides:1992 330is
Bmw330is is a New Registered Member
BMP has some VDO guages.
Joe
92 330is
Old 09-08-2002, 06:09 AM
Dakar is Fast
Rides:Carrera Aero
www.supremepowerparts.com does custom A-pillar moldings. As far as gauges i like autometer's. I will think of some more sites. i know there are some out there...
Old 09-08-2002, 09:48 AM
Matt's Avatar
matt
Rides:1990 325i
www.jegs.com
www.summitracing.com
I would get oil temp, too. put 3 in the console and one in the A pillar.
1973 Verona-ish 2002
2004 Mazda3 Hatch
1994 Honda CBR600 F2
Old 09-08-2002, 08:45 PM
Rides:98 M3
how come they dont make pillar mounts for BMWs only honda and stuff?
Thanks
Mark
M3s are fast!
Audio
Focal
McIntosh
A/D/S
Old 09-08-2002, 09:01 PM
poohlvhun's Avatar
got fish?
Rides:a 4 door
poohlvhun is a New Registered Member
try egauges.com
they have duo A-pillar mounts, just get also a single pod mount and you will be able to fit 3 gauges on the A-pillar.
cheers.
Old 09-09-2002, 04:40 AM
I drive a beater....
Rides:A sleeper....
I like...
I am running A/F, boost in the A-pillar and Oil pressure and fuel pressure below the OBC.
I also would recommend an EGT gauge as well -- possibly an Oil temperature gauge (the A/F one I don't think you really need).
The EGT one that I would get oscillates at about 1600 cycles per minute, it's about 4 inches long and about 2 inches thick, it will fit in your glove box and it is VERY accurate. Cost is around $300 I believe, so not that bad. Considering if you can afford to turbo/S/C your vehicle, don't go cheap on the gauges....
Old 09-09-2002, 05:38 AM
Rides:WRX
luckyguy19 is a New Registered Member
I don't thing an a/f gauge is a good tool for any modified car. When a car goes wot it does not use the O2 sensor anymore cause its not very reliable at those engine speeds. The computer runs off internal maps at that time. An EGT gauge is much more effective in diagnosing a lean or rich motor. In my opinion the best gauges for a turbo car are; boost, EGT, and oil pressure.
Old 09-09-2002, 05:52 AM
Rides:98 M3
Thanks again guys
Hey Jderry do you have a link to that guage you are talking about? I would like to see why it would be $300 others i have seen are like $50. I'm not trying to go cheap or anyhting i just would like to compare quality
Thanks
Mark
M3s are fast!
Audio
Focal
McIntosh
A/D/S
Old 09-09-2002, 06:13 AM
Rides:A sleeper....
I don't have a link...
speak to your local tuner shop...they should know of the one, I'll pm you the name when I find out this weekend...
ciao
Old 09-09-2002, 09:41 AM
Super Geek
Rides:01' C240, 02' Honda CBR600F4i, Cobra Replica
oober is a New Registered Member
If you are going to run three or four guages, And mount some in the A pillar and some below the OBC. You *should* put the boost and the egt in the easiest to see position. Put A/F and oil pressure/temp ect.
If you can't see the boost, and EGT, you risk blowing your engine. Personal experance with this. I used to drive a talon, and I was testing out a new boost controler, and the vacume/boost piping to the wastegate came off and for a split second in 3rd gear my car pulled harder then it has EVER, I thought that it was on some kinda of crack. I looked at my boost guage and I was well over 2 bar (apx 14.7psi is 1 bar. ) OMfG, It was something else. close to 450hp. but had i not left off, The car would have been done, in a matter or seconds, err second (maybe 2) .
Old 09-11-2002, 07:29 AM
Rides:A sleeper....
well...
after a thorough discussion with some people --- differing opinions on the EGT gauge functionality. The system I am referring to is the computech system, it taps the 1,3,6 or 1,3,5?? I forget, it oscillates at 1600 cycles per minute.
From what we've been debating, an EGT gauge, normally placed by the collector, does NOT give an accurate reading. The reason, it is: 1) time delay (40 seconds plus to register a change in temp.); and 2) the temperature decreases incrementally with increasing distance.
However, I think a normal HKS EGT gauge, for instance, is fine if you are NOT going to be running increased boost, larger injectors, etc. However, if you ARE going to do this, I would consider the computech system, it gives more reliable feedback for tuning considerations.
If you do go with the EGT gauge, I believe someone said make sure it is an open probe -- that is used...also, typically add about 50-100 degrees to the reading, just to account for distance variations, etc. I think 1500 and below is idea, preferably around the 1300 range.
Luckyguy - well, wouldn't using a wideband O2 sensor fix that problem though?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
