  #46 (permalink)
Old 08-18-2002, 10:58 PM
Rides:Toyota Mr2 Turbo
Pouya is a New Registered Member
Originally posted by Agaponi
HKS makes the SSQ BOV that work like a 2 stage BOV, so you can work on the low boost release (idle) and high boost release (shifting)...
The SSQV is actuated by pressure alterations only, not by the rate of pressure or vacuum in the line, which ensures a quick valve response and complete closure during idle. On typical blow-off valve designs, a large valve is utilized in order to accommodate high boost / high horsepower applications. However, these large valves tend to react slowly and require high activation pressure to open, therefore are not able to activate and prevent compressor surge at light-load conditions. On the other hand, smaller, fast reacting valves do not discharge the airflow capacity required for high horsepower applications and tend to creep open and leak as the boost pressure overpowers the spring on these push type valves. For maximum performance, the HKS SSQV incorporates both a small primary valve for ultra quick activation, along with a larger secondary valve for additional discharge capacity. The SSQV is engineered to initially open the small primary valve at light throttle and load conditions, then sequentially opens the secondary valve for additional relief capacity under high boost and load conditions.
1993 Toyota Mr2 Twin VATN Turbo 315rwhp@15.5psi
Mazda RX-7 GTU
  #47 (permalink)
Old 08-19-2002, 10:43 PM
Originally posted by kumanchu
the turbo equivalent of this bypass valve is actually the wastegate; which reroutes air going to the compressor from the intake side of the turbo manifold.
I think you are confusing your terms! A wastegate has nothing to do with the compressor stage of the turbo! An external wastegate gas is either dumped into the atmosphere (loud!) or rerouted back into the exhaust path (not as loud, but can cause turbulence and backpressure if not dumped about 18 inches away from the turbo). A turbo manifold is the equivalent of a exhaust manifold or a header. There is no such thing as an intake side of an exhaust manifold! That's like me saying the "air filter side of my muffler." Turbocharged cars also have bypass valves. In fact, a lot of turbocharged cars stock come with these valves.
Mazda RX-7 GTU
  #48 (permalink)
Old 08-19-2002, 10:53 PM
the blitz super siren bov is loud cause it was designed to be. the hks ssbov gets the sound closest to when you actually say psssh so people are atracted to it.
BlitZ super siren? I think you mean the BlitZ Super Sound or Dual Drive blow off valve.
The HKS blow off valve you are referring to actually sounds nothing like the typical blow off valve. Since it is super sequential it sounds different depending on how much boost is vented. It has more of a high pitch tweet, like a rush of air mixed with a bird. Click here to here it go off on a Supra.
Mazda RX-7 GTU
  #49 (permalink)
Old 08-23-2002, 04:59 PM
uberpanzer's Avatar
Old School Guru
Rides:e30 M3 (thinks its an iX)
uberpanzer has achieved their Master Licenseuberpanzer has achieved their Master Licenseuberpanzer has achieved their Master Licenseuberpanzer has achieved their Master Licenseuberpanzer has achieved their Master Licenseuberpanzer has achieved their Master Licenseuberpanzer has achieved their Master Licenseuberpanzer has achieved their Master Licenseuberpanzer has achieved their Master Licenseuberpanzer has achieved their Master Licenseuberpanzer has achieved their Master License
Is that HKS one the type that is used on the WRC cars? I'm at work w/out speakers and can't hear the sound FXs. Also saves me from getting it later (when I get home).
My alternator is hurting....
"Well when you blew it, you really blew it with pizazz." - CleanAzzE30z
  #50 (permalink)
Old 08-23-2002, 06:05 PM
Solokron's Avatar
Rides:'97 Vert
Solokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master License
Gawd damn the blitz super siren bov is loud!
1995 325Is, 1996 Dinan Supercharged M3, 1997 328ic, 2005 X5 3.0
  #51 (permalink)
Old 08-23-2002, 06:29 PM
jagsm3's Avatar
Rides:Porsche 911TT 2001
jagsm3 is a New Registered Member
where can I get one and how much?
  #52 (permalink)
Old 08-23-2002, 06:57 PM
kumanchu's Avatar
Rides:'00 GC8
kumanchu is a New Registered Member
no there at least WAS a super siren; i'm positive. i should have an ad for it in one of my older ricer magazines somewhere. and the the sound that i was talking about out of the hks unit was from the high pressure release.
werd to yo moffa
  #53 (permalink)
Old 08-26-2002, 01:10 AM
Rides:330ci
nickl382 is a New Registered Member
yes i'm aware of what a BOV is for; you are somewhat correct in what you are saying. a bov allows excess boost to be released in a turbo charged system. why? because if you don't dump that extra boost; you put MAJOR stress on the turbo
Just wondering how many people here have their knowledge from hands on experience, word of mouth, research, ???
I think that is a necessary credential to list when spreading your devine omniscience here on the board.
  #54 (permalink)
Old 08-26-2002, 03:33 PM
mgd's Avatar
mgd mgd is offline
Broke
Rides:turbo widebody 325
mgd is a New Registered Member
Well the answer to title of the thread is Yes, it is possible. But does it run with only a bov? No. I went to pick up my car today with the HKS SSQ BOV installed with my supercharger, and it runs well on open throttle, but any steady rpm and it studders and runs like crap. Doesn't stall though. The guy at the shop recommended installing the recirculating bypass in addition to the bov. That way it will still recirc and be able to blow off. The supra's he works on use two bov's, so he said it should still be audible.
Is anyone familiar with the HKS SSQ? When it blows off it sounds like a series of chirps. Could that be because it's not tuned for it? Or is that how it's supposed to sound? Thanks
building something like no other...
  #55 (permalink)
Old 06-20-2007, 12:48 AM
E30stain's Avatar
Sherminator
Rides:'96 323i
its susposed to sound like a series of chirps... as u all hopefully know by now its the pressure of the air pushing the BOV open... when it pushes open it doesnt do it exactly smoothly or open a great deal... since it only opens as a small gap the sound it high pitched and as the pressure is released the BOV closes, while its closed the pressure builds up again causing another release... as it operates on whatever psi you set it then the pressure(depending on which brand/model BOV) in the manifold fluctuates (from memory) about 0.2psi (please correct me if you know the proper value)... hope that clears things up... and they theoretcally should work on a SC as when you take your foot off the accelerator, yes the supercharger slows down(faster than a turbo) but the throttle body is still closed... so there should still be enough pressure there to use a BOV, i personally like bypass style because its more stealth... but then again i dont like people knowing my car is more powerful then theirs until i strip them of victory.
'is she fucked or is she proper fucked?'
'shes proper fucked'
'ahhh fuck'
  #56 (permalink)
Old 06-20-2007, 12:50 AM
E30stain's Avatar
Sherminator
Rides:'96 323i
oh and the fluctuations may be the factor that causes your idle to be off... using 2 BOV as u mentioned sounds like a good idea as it will smooth it out (like an engine, 2cyl exhaust flow is smoother than 1)
'ahhh fuck'
  #57 (permalink)
Old 06-20-2007, 12:51 AM
E30stain's Avatar
Sherminator
Rides:'96 323i
oh lol bump... yeah its an old thread :P
'ahhh fuck'
  #58 (permalink)
Old 06-20-2007, 05:00 PM
Highboosted's Avatar
Road Race or Die
Region: USA - Great Plains
Yes....it's an old thread.
And one thats SOOOO full of misinformation and people who don't know crap about supercharger and turbocharger systems it's unbelievable.
BTW, the SSQV is not supposed to sound like a series of chirps. I have a couple of them on my car, and if they are overtightened they will chirp repededly, but not intended to do that because of the stress your doing to the compressor.
Funny thing is, throughout this thread I didn't read ONE post that had correct information in it.
Join NASA, too!!!!!
  #59 (permalink)
Old 06-20-2007, 11:47 PM
E30stain's Avatar
Sherminator
Rides:'96 323i
lol i meant atmospheric BOV in general... hmm maybe im wrong but thats what a mechanic told me and being a physics(sorta) student i looked at it and it seems to work out :P.
'ahhh fuck'
  #60 (permalink)
Old 06-21-2007, 06:39 AM
Stealth's Avatar
T-Bag
Rides:RSX Type S
Stealth is a New Registered Member
wow....
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338
