Old 04-30-2002, 07:52 AM
Rides:BMW/M3/1997
97M3Coupe is a New Registered Member
Nos???
I did a search on NOS and Nitrous but didn't find any thing helpful. I'm thinking of putting NOS on my car but I wanted to get an idea of what other members have done, their setup. How much NOS, 50..100 shot? Wet or Dry? Any internal changes? Dyno tuned...and if so what did you use to adjust the Air/Fuel? Bottle heater? Most importantly performance gains, on the dyno and at the track. As all the members with NOS know, it the best dollar to hp gain. And the cost of a supercharger and turbo system for a BMW is ridiculous.
Old 04-30-2002, 08:04 AM
Scho's Avatar
Moderator
Rides:1999 White M3
Nitrous Express #20923 w/ purge. I am installing it as we speak. I am taking mass amounts of pictures and doing a huge write-up on it. I wil also have timeslips with and without and show what improvement it made.
Old 04-30-2002, 08:40 AM
Rides:BMW/M3/1997
can't wait for your write up. What kind of hp gains you looking for? Did you do a baseline dyno? What's the compression ratio of your motor?
Old 04-30-2002, 08:46 AM
Scho's Avatar
Moderator
Rides:1999 White M3
All internals are the same. I am still running stock compression. I am replacing the Bosch Platinum +4 plugs (which suck anyway) with NGK one range colder plugs with stock gapping. I am also running an MSD window switch which will prevent the nitrous from spraying in the event that I miss a shift or hit the rev limiter. I am adding a purge valve for the cool factor. It does have a function too. In two weeks, I should be complete with the install and write-up. I have to find time to put on my brakes and coilovers too in there.
Old 04-30-2002, 10:07 AM
Rides:BMW/M3/1997
sounds like a good setup! When is the NOS going to kick in? Are you going to have it setup that the NOS kicks in at a certain RPM Range or is it always going to be spraying?
This is a stupid question but I have to ask, What is a coilover? And are you installing an aftermarket one?
Old 04-30-2002, 10:34 AM
Scho's Avatar
Moderator
Rides:1999 White M3
The nitrous will kick in at 3500 and will not spry over 6500. This should work and is what most people run between. I will not use it in first gear. As soon as I shift to second, you activate the switch. As long as you are full throttle, it will be spraying.
Coilovers for M3: (Click) http://www.ground-control.com/gccatm3.htm
Old 04-30-2002, 06:15 PM
MPower95's Avatar
Keeping it ill
Rides:95 BMW M3
MPower95 is a New Registered Member
I had the exact same kit as SCHO but had to sell it b/c I got an exceeding 100 ticket. It's a great kit.
BTW, NOS is not nitrous, NOS is a company (nitrous oxide systems), so when you say NOS you are referring to the actual company. N20 is nitrous. Just thought I'd let you know.
Please resize your signature image in accordance to the guidelines.
Old 04-30-2002, 08:26 PM
///Ti's Avatar
Poor ass white boy
Rides:'93 325i
///Ti is a New Registered Member
just wondering
will a shot of nitrous rip my 318ti with 70k miles to peices, i want more power so bad
Old 04-30-2002, 09:14 PM
Rides:Turbo 332is, 86 535i
LDORADO325 is a New Registered Member
Re: just wondering
I had a 55 shot on my 325i with over 122,000 miles on it and it worked fine, the engine actually ran smoother after using it. I had a zex kit and it worked nice, it started spraying at full throttle. I also had a bottle heater which you should definately get if you live in a cold climate, this made the nitrous work a lot better. but you have to be careful with a bottle heater because i have seen where someone left theirs on over night and it blew up his whole trunk and part of his garage door. I wish i still had mine, i was going to upgrade to the 75shot soon but then my dad found it. Nitrous is awesome, and you can totally feel it when it starts spraying in, unlike other mods where you always have the power and you dont really notice it, but when you use the nitrous you get a nice pull pushing you in the seat. for powergain wise there was one test i did, when my car didnt have the nitrous on i couldnt get the wheels to spin holding the brake and gas, but when i hit the switch they started smoking. And one other thing to mention my car was a automatic and when you floored it when it would downshift it would clunk into gears becasue of the nitrous, so i would recommend flooring it then turn on the switch when it downshifts. I still miss nitrous to this day, i only had it for one week, but that was one of the funnest weeks with my car!!!
-Mike
Built S52 w/GT3582R T4
My Website w/ More Pics
Old 04-30-2002, 09:54 PM
Solokron's Avatar
Rides:'97 Vert
Solokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master LicenseSolokron has achieved their Master License
I need NOS!
When I see that 97M3Coupe, what comes to mind is Paul Walker say... "
I need NOS! "
LOL
Old 04-30-2002, 09:56 PM
Solokron's Avatar
Rides:'97 Vert
MPower95 - N2O is nitrous. Don't forget about
I couldn't find the sub so I went with super. At any rate better than saying 2 oxygens. :P
I must have been inhaling it.
Old 05-01-2002, 09:10 AM
Rides:BMW/M3/1997
I just got off the phone with a NOS representative and he informed me that the Wet kit can lead to problems with the 1 and 2 cylinders but a Dry kit won't. I think he might have been saying that because NOS primarily deals with Dry kits. But he told me if I wanted to run their Dry kit I needed to find the Fuel Regulator. Where is our Fuel Regulator located?
Old 05-01-2002, 02:49 PM
Adriano's Avatar
Rides:BMW 96 318i w/M3 engine S/C & nitrous
Adriano is a New Registered Member
Don't use nitrous. Hey I'll say it again. Don't use nitrous.
Just fried my engine, and I have alot of experiance with nitrous oxide. I have been researching it for over 6 months and installed 3 other systems in other cars before I installed my Zex kit. I was racing a mustang and only had the 75 HP shot in it when my engine crapped out. Well now I have no compression from my cylinder #1. If you absolutely must have the bottle, I suggest not going over the 50 HP shot for 4 cylinder and not over 75 for 6 cylinder. Zex is computer controlled and monitors the pressure of your fuel rail. When there is not enough fuel going into your cylinders, the nitrous shuts off to prevent lean mixture leading to detonation. It is supposidly a safe kit but has no compensation as to how much pressure is in your bottle. Now I am going to put a regulator on my setup so I know that I will be shooting the same no matter how full my bottle is. Oh, that is after I rebuilt my f@#&ing engine.
Agent BMW trailer
Old 05-01-2002, 03:03 PM
Scho's Avatar
Moderator
Rides:1999 White M3
It is a proven fact that Wet kits are safer than dry kits. Wet kits also provide more horsepower. If you buy a wet kit and you do not like it, all you do is yank the fuel side of the kit and you have a dry kit. Ta-da! Earlier designed wet kits could cause puddling of fuel in the intake manifold, but that has been perfected by nitrous express. I have never heard of an NX kit causing damage. If the kit is hooked up properly and not abused, it will provide perfectly safe hp gains!
Old 05-01-2002, 04:16 PM
///Ti's Avatar
Poor ass white boy
Rides:'93 325i
whats it cost to fill a bottle
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
