Old 04-25-2002, 04:19 PM
Rides:94 325is...........pshhhhhh
E36Turbo is a New Registered Member
Exclamation Can someone please explain what Vanos is??????
I was trying to explain it to a friend and i was just getting confused myself. Can someone please explain the meaning and what it does and all? Thanks
Old 04-25-2002, 05:00 PM
PrinceE30's Avatar
Stick Shift Cowboy
Rides:1991 BMW 318is
PrinceE30 is a New Registered Member
Variable Valve Timing.
As your engine changes RPMs, the time which gasoline actually is injected and detonates is normally the same at 1000RPMS as it is at 7000RPMS. However, because of the movement of the pistons and such, the release of the gas into the system can be too late (or early) for optimal detonation time. Therefore, VANOS will open valves earlier (or later) to let gas and air into the cylinder at a more optimal time. On new VANOS engines, both intake and exhaust valves are variable, but they used to only be in the intake.
From what I hear, VANOS always is on...and infinitly variable whereas iV-TECH or VVTi only work above 7000RPMS. Also, BMW uses this on not only 4 cylinder engines, but 6 and 8 as well. AUDI had a great explination on their site a while back. Check it out. I'll keep an eye out for it as well.
-Prince
Randall Prince
http://www.rp1.us/ Used Cars
Old 04-25-2002, 05:19 PM
Joey325i's Avatar
Its like VTech but better
Old 04-25-2002, 05:24 PM
Tnucu's Avatar
Banned
Rides:1987 325is
Tnucu is a New Registered Member
Um its "like" VTEC, but ALOT better....
Old 04-25-2002, 06:07 PM
PrinceE30's Avatar
Stick Shift Cowboy
It "is" V-TECH, but at all RMPS and infitesimally variable...
-Prince
Randall Prince
Old 04-25-2002, 06:36 PM
ToM3's Avatar
l337 m3
Rides:m3
ToM3 is a New Registered Member
clicky
Old 04-25-2002, 06:43 PM
Rides:bmw 318is 1994
SfLbMw is a New Registered Member
does my 1994 318is have vanos and if not, why the hell not
94 318is mettalic green
clear corners (front only)
ractive intake
new fockford component speakers
2 12 inch infinity subwoofers
rockford 800a2 amp
1000 watt capacitor
painted side skirts and front and rear bumpers
engine rebuild
bosal exhaust
Old 04-25-2002, 06:46 PM
Joey325i's Avatar
All BMWs after '93 came with vanos
Old 04-25-2002, 07:00 PM
Rides:03 M3, 03 gmc sierra
blown318 is a New Registered Member
It's different than Vtec because w/ vanos, cam timing changes. W/ Vtec, what changes is valve lift and durations due to another cam lobe that comes into use. Cam timing does not change w/ Vtec. This is a very simplified explanation, but thats how i've always understood it. Feel free to add to or correct what i've said if i'm wrong.
Also, 94 318s don't have vanos
Old 04-25-2002, 07:12 PM
Rides:Coolpix 5700 & Canon S230
nanoflux is a New Registered Member
This site below has a GREAT explaination, in detail, about what it does and how it works for BMWs. It's what I read when I was trying to figure it out.
http://www.bmwworld.com/technology/vanos.htm
Old 04-25-2002, 07:28 PM
Matt's Avatar
matt
Rides:1990 325i
ummmm, bimmer pride and all, but VANOS sux compared to VTEC.
VTEC actually allows the profile of the cam to change at a certain RPM, as Alex Mc put it: "Its like switching from stock cams to schricks at some RPM"
its what allows a tiny motor to make so much HP, because it's optimized for a high RPM as well as low.
1973 Verona-ish 2002
2004 Mazda3 Hatch
1994 Honda CBR600 F2
Old 04-25-2002, 07:47 PM
PrinceE30's Avatar
Stick Shift Cowboy
VANOS WAS NOT MEANT TO MAKE BIG HP...
Yes, you heard that right. VANOS is not meant to create a lot of horseopower. What is does do though is give you a lot of low end torque, often where the strait sixes lack the omph to get moving. This will allow you a more drivable car at all speeds, whereas when you have V-TECH you need to be driving over 6000RPMS (approximatly 80% of redline). Do you drive your Civic/Prelude at 6500RPMS often?
I think not. VANOS is be better. Proof : M5
-Prince
Randall Prince
Old 04-25-2002, 08:24 PM
Rides:'01 Acura 3.2CL TypeS
JRockCLS is a New Registered Member
WAY off.
VTEC switches cam lobes at a pre-determined RPM, and for my car it switches at ~5000rpm, IIRC. Prelude, Accord, Civic, CL/TL all hit VTEC changeover around five grand. Only the S2000 revs high enough to warrant a 7k VTEC engagement rpm. Heck, my car redlines at 7200rpm.
i-VTEC intelligent valve-control continuously adjusts the camshaft, just like the newest version of Vanos, although Vanos seems to be more concerned with maintaining torque than increasing high-end horsepower. Either is equally as effective, it's just a matter of which you prefer.
I think not.
While your numbers are exaggerated, I agree to a point: I use a similar logic for why I won't spend a ton of money to buy headers for my car - on my car headers only give a noticeable boost in high rpm range (above 5200rpm... pretty much only in VTEC range) and because I'm not driving in that part of the powerband very often, I don't feel it is economical for me to buy super-expensive headers that I won't use all that often. Only Comptech currently makes headers for my car, and they are $1250 + install. Compared to most other V6 headers which are around $800 (you BMW people don't count because ALL your mods are super-expensive)!
Old 04-25-2002, 08:53 PM
PrinceE30's Avatar
Stick Shift Cowboy
Sorry about the inaccurate numbers with the RMPS. I've heard different stories from different people and sites. Thanks for clearing it up though!
-Prince
Randall Prince
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
