Old 04-21-2002, 04:20 PM
Rides:1997 M3/2
Medvedko is a New Registered Member
Redline oil kills Vanos???
Hey guys,
I have used Redline oil with great success for the past 2 years. Anyway, I went through some old "oil" threads and people have mentioned that there is something in Redline oil that can destroy the vanos on our cars. Can somebody please explain this too me and why this would happen only with Redline oils.
Thanks
Old 04-21-2002, 08:29 PM
Rides:97 m3
mrclam is a New Registered Member
i am actually currently undergoing this problem on m3 right now...my vanos is making funny noises just a month after putting it into the car. i'm thinking about having the dealer inspect it and hopefully replace vanos under the CPO warranty...otherwise i don't know what to do about it. does anyone have more information?
97 Alpine M3
x-brace
euro floating rotors + hawk hps pads
gc coils 450/525
ZKWs + DDEs
Old 04-21-2002, 11:54 PM
Rides:97 m3
bump^
97 Alpine M3
x-brace
gc coils 450/525
ZKWs + DDEs
Old 04-22-2002, 01:39 AM
Utah Rep
Rides:pinto
hmmmm, unlikely but i guess its possible something about the oil or one of its additives could somehow affect some of the vannos components.
Old 04-22-2002, 03:25 AM
Baby M3's Avatar
Ba Dawg
Rides:Cha Ching!
Baby M3 is a New Registered Member
Hmm.. Interesting observation.
Red Line oil's been around for a while and it's the first time that I heard something negative about it.
Thanks for the heads up.
Please keep us posted.
Jon
Old 04-22-2002, 08:03 AM
Knightmare69's Avatar
Hater
Rides:05 CGM WRX
Knightmare69 is a New Registered Member
Has anyone actually contacted Redline and brought this to their attention? I'm sure Redline would be able to somewhat answer this question, hopefully. Thank god I haven't switched over from Mobil1 yet.
Phaze Motorsportz
Power Thru
05 CGM Stage II WRX
Old 04-22-2002, 08:31 AM
Rides:1997 M3/2
Thanks for all the input. I have not experienced any problems as of yet and don't plan to. I am not going to say out loud that Redline is a poor product. I have it in my tranny and it is smooth as hell. I just know that certain people who had Vanos failures on this or other boards have had Redline in their systems. Otherwise I have seen a ton of other people who have their vanos fail with other oils. I do wonder sometimes if using such light oils can cause damage to other things quiker than just having the security of enough oil at start up. I have heard and seen too many cars using light oils that tick like mad and others that don't. Almost seems to damge and annoy other things in the motor.
Anyway, I might just stick with 5-30 Mobil 1 "tri" synthetic considering it is a widely marketed oil and I change it often enough "2500 miles or every 3 months" so breakdown isn't a major concern. I guess I will stick with Redline in my VDUB.
If anyone has contacted Redline about this issue please by all means post a response. I would like to know as well if there is some additive used that is fooling with the VANOS.
Old 04-22-2002, 12:40 PM
Rides:97 m3
i just called redline and the tech was out to lunch but they said they would call me back in probably half an hour or so, i will post an update.
97 Alpine M3
x-brace
gc coils 450/525
ZKWs + DDEs
Old 04-22-2002, 01:46 PM
Rides:97 m3
UPDATE:
i just spoke with the tech at redline oil. he claims that there are known problems with the VANOS unit, but not in usage with redline oils, and that there is nothing in redline that would cause the vanos to malfunction/screw up. the tech then told me to take up my problem with bmw and it sounds as if the dealership may pay for the repair now(under CPO)
97 Alpine M3
x-brace
gc coils 450/525
ZKWs + DDEs
Old 04-22-2002, 02:02 PM
Rides:1997 M3/2
Cool,
It is a bit more comforting to know that Redline isn't the cause of VANOS failures. I see a lot of racers sponsored by Redline and only heard the best of things about the oil from everyone.
I called BMW (my dealership) and spoke with the tech over there. He told me it is extremely unlikely that an oil can destroy the VANOS drive system unless it was in there for 20k+ miles. He said they have replaced some before the cars hit break-in. He also said they have one customer M3 with over 95,000 that has no problems since new. So, I guess either you have a good unit or a poor unit.
Thanks mrclam for going through this!
Andre
Old 04-22-2002, 02:34 PM
Rides:HELLROT '95 325i
Red Bimmer is a New Registered Member
I've been using Castrol 10-40 for the past month after a year of Castrol 20-50. My car kinda makes a chucking or metal valve cover shuddering noise when changing from gear to gear (from the engine). Does this mean a vanos problem and if so does the vanos go bad if the oil is too light? Thanks
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734
