Old 04-18-2002, 11:13 PM
Rides:E30 --- 325
ThE bRoWn GuY is a New Registered Member
Turbo, MAF, and BOV
Guys i need help...
1. Some say that with a turbo (94 325is) the b.o.v. must be routed back into the system, and some say its fine to vent into the atmosphere.. So which is it?
2. With a 4mm copper headgasket what will the new compression be? And what is a safe level of boost to run?
3. Where can i get a set of 42lbs injectors for a good price??
Thanks a lot for all of your input!!
Old 04-19-2002, 03:13 AM
Seedster's Avatar
Rides:96 333i and your mother
Seedster is a New Registered Member
Re: Turbo, MAF, and BOV
Originally posted by ThE bRoWn GuY
Guys i need help...
1) I'm almost positive that net gains will be better when air is blown off into the atmosphere. Of all the people that I know personally that run turbos on their e36s (both ///M and non-///M), everyone runs bovs that blow into the atmosphere. The HKS i believe is the most popular.
2) sorry....no clue
3) I think 42lbs injectors would be complete overkill...but I do know that injectors off of a mustang are direct PnP for our cars. You can pick up a nice 30lbs or 35lbs set for damn cheap if im not mistaken.
saeed
~333
Old 04-19-2002, 06:13 AM
Rides:95 Stg 2+ Turbo M3
mattduncan is a New Registered Member
im getting a turbo system this weekend, the guy i am buying it from says that bmws have to use the one that go back in the system to keep teh car from stalling.
Old 04-19-2002, 06:35 AM
Rides:97 M3, 01 Suzuki TL1000R,
///MARIO is a New Registered Member
With a MAF meter you need to vent back in so you don't stall coming off throttle. The MAF measures how much air goes into the intake and adjust fuel, if you vent the air out you loose the air and get the extra fuel and that's why you stall, stalling is worse with cold weather for some reason.
One way to get around it if you must vent to the atmosphere (cool sound), is to get an adjustable BOV, like the Greddy, so you can tighten the spring pressure and only let a little air out.
One other reason to blow it back in, is to use that air pressure to blow against the turbo and keep the blades spinning.
You won't notice a performance increase by venting to the atmosphere.
Old 04-19-2002, 07:32 AM
Joey325i's Avatar
You actually gain more power venting it back into the MAF, venting into the atmosphere is mainly for sound, BMWs you have to route it
back or else you will stall the car. In order to run open bov you would have to get software that bypasses the MAF so it will not sense
the lost of air.
Old 04-19-2002, 08:35 AM
Utah Rep
Rides:pinto
yup these guys are all correct...
when you vent to the atmosphere, you dump aready measured air out of the system and it runs RIIIICH... depending on PSI and other things, it might not run that rich (low boost/small turbo won't dump as much air) but yeah, you'll probably want to route it into the intake so it doesn't cough and stumble... if you don't mind that, well, it will sound "cool"
- btw this is worse when its cold because cold is more dense anyway, so when you vent some, it dumps even MORE o2 then hot... you also make more power on cold air....
personally i don't like the sound that much. *braces for flame broiling*
42lbs injectors... seaarch around on the mustang sites... SVT uses bosch as well as bmw, so you can get them for cheap from the ford guys (thank god)...
find out what the stock bore and stroke are, along with compression, and punch some numbers and find out the new compression... i'm just a bit hung over and too lazy to find the stock #'s...
Old 04-19-2002, 09:21 AM
Seedster's Avatar
Nice thinkin Pete! Now if it just wasn't a school night last night....i'd be there with ya
saeed
~333
Old 04-20-2002, 01:56 AM
Banned
Rides:BMW
Easy answer.
Blow off valves provide ZERO power gains. None. They aren't for adding power.
They keep back pressure from spinning the turbine blades in reverse and wearing out the bearings on the compressor prematurely. They may improve throttle response a bit.
On a vehicle that blows THROUGH the MAF (like the mechtech), you route the BOV relief to atmosphere. If you are pulling through the MAF, like AA, you blow off into the intake.
Reason being just like stated above, sucking through, the maf thinks that there is air going into the engine, so it compensates with fuel, and there in reality is no air...so the engine wants to stall.
With mine blowing through, the MAF knows that the air has been blown off already, so it compensates for it.
Old 04-20-2002, 02:32 AM
TurboX5LMR's Avatar
1 Jacked-Up 3er
Rides:A Turbo Slug
TurboX5LMR is a New Registered Member
Nicely put everybody...
My BOV goes out into the atmosphere...and it often stalls.
Old 04-20-2002, 01:17 PM
Misterdvs's Avatar
Island Boy
Rides:2002 Hubbard BZ
Misterdvs is a New Registered Member
I'm goin with Joey325i since he has one
Old 04-20-2002, 02:28 PM
Rides:E30 --- 325
First of all thanks for all the info!
Brad.. can you expand on the push pull factors... (basic setup of each)..
A Tire question... What is the widest tire possible that can fit on a 7.5inch rim?
ps.. yes i will need the 45lbs...
and does anyone know who can program software for cheap? aa wants 600!!! i'm sure its good but i may incorporate a standalone in the future.. soo...
Thanks
Old 04-20-2002, 06:34 PM
TurboX5LMR's Avatar
1 Jacked-Up 3er
Rides:A Turbo Slug
For a standalone computer... kinda expensive... but go with the Motec System http://www.motec.com/home.htm
Gene used to run a Electromotive TecII in his turbo M3 before.
Old 04-20-2002, 07:23 PM
Utah Rep
Rides:pinto
bad thing with blow through setups is the stock computer only measures the amount of air going through, not its pressure... so the stock computer has a bitch of a time dealing with boost when set up this way...
when you set it up pull through, the sensor sees a whole bunch of air going by, rather then about the same amount, except at higher pressure.
motec... sweet if you have the $$$
otherwise i'd get the unichip, its almost as programmable as motec, easier to set up and just taps into the stock wiring... with motec, you'll probably also need different gauges, which is another fairly expensive item. (stacks or pi preferably)...
nobody can really program OBD II for cheap... to tell you the truth dinan and AA are the two places who can do it well (with the bmw setup), and they are $$$
600 is a decent price.
Old 04-20-2002, 09:44 PM
Rides:E30 --- 325
Sorry about that its OBD 1..
Old 04-21-2002, 07:37 PM
Twin Screw Jockey
Rides:1997 M3/4 + other
45lb injectors
Thanks
According to my calculations, you could not possibly need 45 lb injectors unless you are running over 20psi boost on the 2.5L engine, or over 13lbs on the 3.2, assuming a max 80% injector duty cycle at stock fuel pressure.
With 45lb injectors, your car will probably idle and low-load part throttle cruise like crap!!
Steve
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
