Old 04-16-2002, 04:08 PM
Rides:E36 M3
jwocky is a New Registered Member
Installing Supercharger
I read this about the installation of the Dinan supercharger kit:
More is involved in the installation of the Dinan than just "bolting on" the supercharger. The Dinan installation relocates the cruise control and a filter canister from the left front of the engine compartment to the empty battery mount in the right rear. The radiator is removed to install the drive pulley and a portion of the fan shroud is cut away to clear the more forward fan location. New higher capacity fuel injectors are installed with the injection dwell controlled by the chip. An electronic unit is installed to translate the new fuel injection characteristics for the O2 sensors etc. Some fabrication is required to route the air intake for the supercharger downward to receive air from the lower part of the air dam.
I definitely plan on reading up extensively on supercharger installation before actually doing it, but are the above steps/modifications really difficult? $2,000 for factory installation - what a ripoff.
Thanks!
Old 04-16-2002, 09:48 PM
mgd's Avatar
mgd mgd is offline
Broke
Rides:turbo widebody 325
mgd is a New Registered Member
To answer your question, No it's not difficult at all. I just finished up my second supercharger installation on my friends car with him. Plan on having your car out of commission for a couple days since it's your first time. A little advice, go slow and make sure you do everything right. Don't rush anything. The process really isn't that hard but it can be frustrating at times. As long as you take your time to make sure everything is done right, it's cake. They wanted 2k for installation?!?!?! That's a bit much for 6-8 hours of professional labor.
building something like no other...
Old 04-16-2002, 09:52 PM
Rides:E36 M3
6-8!? hah, those dinan ripoff artists estimate 20 hours @ $100/hr.
Old 04-16-2002, 11:22 PM
mgd's Avatar
mgd mgd is offline
Broke
20hrs?!?!?!?!?! hahahahahaha What place is it???? Unless the dinan kit is drastically different from the rms kit, which I don't believe it is, or unless they're piss ass drunk, I can't see how it would take someone 20 hrs to put it in let alone a shop. Are you sure the shop knows it's a supercharger and not a turbo? Someone please correct me if I'm wrong but 20 hrs for any supercharger is very excessive.
Old 04-17-2002, 03:11 AM
Utah Rep
Rides:pinto
they use 3 hours to drink a bottle of tequila... 10 to pass out on the toilet and throw up, then 7 to install it.
pretty typical dinan
Old 04-17-2002, 05:14 AM
Rides:E36 M3
Yep, positive it is 20 hours. It's listed on Dinan's price/labor hours sheet for all their products... which means every Dinan/BMW dealer will charge that much.
Old 04-17-2002, 05:23 AM
Rides:E36 M3
A further question I do have though is whether or not the installation of a supercharger will need any sort of "tuning"?
In other words, suppose you install the system properly (meaning all parts in the right place, etc...) and have your software reprogrammed with the Dinan software - are you then done and will you then be able to achieve similar hp/torque #'s to those Dinan advertises? OR will you have to tweak/tune the physical system/software somehow to achieve those #'s?
Old 04-17-2002, 07:59 AM
Florida Rep.
Rides:'98 Turbo M3
///MCubed is a New Registered Member
I am pretty sure Dinan does not dyno tune their cars, so they use a standard software package in all their cars. So to answer your question, you can to the install and just get the DME programmed by Dinan, plug it in and you are done (maybe someone with a Dinan system can concurr with this).
'98 M3
GReddy Gauge For Sale (Click Here)
"Come Play with Power"
Old 04-17-2002, 10:43 AM
mgd's Avatar
mgd mgd is offline
Broke
hahahaha Sad, but unfortunately, very true...
Old 04-17-2002, 10:47 AM
mgd's Avatar
mgd mgd is offline
Broke
Unless you're running high boost, it's not really necessary. You can buy an a/f piggyback system. HKS and Apexi both make one. These allow you to do a little fine tuning yourself to get optimal performance. Most dyno places will do this for you. Although some of them will only do it if you have their preferred system. I know evosport uses the apexi afc. Call around to your local shops and see what they'll do.
Old 04-17-2002, 10:59 AM
Scho's Avatar
Moderator
Rides:1999 White M3
HAHA, I always drink beer when I work on my car! Maybe I should get a job at Dinan. I have an Engineering Degree!
Old 04-17-2002, 11:52 AM
NewImageMotorsports
Rides:an old beater!
Stylin is a New Registered Member
I drank a few beers installing my SC.. after a little while I got a bit confused..
This vaccum hose goes where again??!!
Old 04-17-2002, 07:22 PM
*Persian Version*
Rides:Red Beauty
Alibabajun:. is a New Registered Member
all this talk about how hard it is to install a S/C...does anyone know how hard it is to make one? I might have a source for getting the crank pulley for around 200$. I'm really interested in making one, but dont know where to begin or look. is there a page that explains all the FAQ?
TIA
"Be civil to all; sociable to many; familiar with few; friend to one; enemy to none."
Dynamic Perceptions | Prints
Red Beauty
Old 04-17-2002, 07:31 PM
Mike325is's Avatar
needs a new username
Rides:2004 Carbon Black M3
Mike325is is a New Registered Member
Damn... 20 hours is a lot for a supercharger... but I guess that's partly because Dinan, the most expensive aftermarket company, is combining it's labor with the dealer, the most expensive shitheads you'll ever encounter...
Anyway, does anyone know what kind of labor rates are usually associated with a turbo?
What does AA charge in labor to put in one of their turbos??
Old 04-17-2002, 08:00 PM
thinair's Avatar
Creative Driver
Rides:97 328is, a few bicycles
thinair is a New Registered Member
Well, this is how is works, they do 4 hours labour installing on one day, rest/sleep for 12 hours, then the next 4 hours the next morning finishing it up. Basically the 12 hours of rest/sleep time charge is one nights storage/rent fee.
Nelson Papel
Madeira Violet 97 328is
For more info on my car, click here
Mosport Skidpad Video
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454
