| Injector used for SC or Turbo I'm redoing me current SC system, and according to my calculations I need something larger than 27lbs. My question, to those of you with SC or TB, is exactly what injectors are you using (model # etc)? I know a lot of people run 24lb mustand injectors (the blue ones) with their setups, but there are 10 different types of 24lb mustang injectors. Any specifics, comments on different brands, etc, would be great. Take it easy, Bman
__________________ BMW Speed Freak 93' 325is, ESS Supercharger, Insane Computer/Stereo http://end2endintegration.com |
| I would buy 30# injectors. There is a couple of places that should be able to provide this AA, ERT, RMS, and almost anybody that sells injectors. |
| I was told by the mustang performance shop that Cobra-R injectors are available in 30# and are the same size as the stock injectors. This means that they will fit our cars because the others fit. I do not know the resistance but at the worst you would need a resistor pack to run them. You may want to call them. My only issue would be that at low duty cycles the car may idle rough. But I guess with proper tuning of the ecu you should be set.
__________________ Nick If I wanted any crap from you, I'd squeeze your head |
| Im running the ford racing 30# injectors in my car with no problems at all. Summit racing has them the cheapest. www.summitracing.com
__________________ ![]() Custom tuned by NickG |
