| Nitrous is half the equation, what about fuel? hi. i've been reading some things about nitrous on this board and alot of ppl say running a 50-100 shot of juice on a bimmer is no problem.. but what about fuel? im more of a turbo guy myself and theres alot of japanese electronics that can manipulate the air flow meter(or whatever you want to call it) for turbocharged cars. For example SAFC and things like that. What about nitrous? if running a 50-100 shot of juice on our cars is safe, then installing a turbocharger which bumps hp up 50-100hp is also safe without fuel control then right? if not, then what makes nitrous so special that it doesnt need fuel upgrades? im sure there are nitrous electronics+fuel pressure regulators that can bump fuel pressure up whenever the juice is flowing but how come nobody is using any of those? im very interested in installing a nitrous system for my bimmer but i just cant understand why running an extra 50-100hp on an engine doesnt require anymore fuel than stock. |
A wet kit puts fuel and n20 in the intake after the MAF. I think the biggest shot available in a NON directport is 75hp
__________________ 3.2L OBD1,Polished Vortech V-2 S/C,NX nitrous kit,NX GENX-2 kit,MSD window switch,NGK V Power plugs,BMP racing tranny mount,TB coolant bypass,AC removed,fan clutch mod,K&N CAI,cats removed,DTM style cat back exhaust,AA short shifter,AA clutch,AA light weight flywheel,Autometer and R1 competition meters,Custom 100% lockup diff.,17"BBS RC wheels,Eibach springs,back seat removed,Momo seats,Momo steering wheel,Momo pedals,Sony Xplode,JL audio,Rockfordfosgate First time at the track 12.72@107mph 1.8 60ft (NO NITROUS) |
| thanks for the reply. now i understand more. i know when the maf(if thats what u wanna call it) senses more air entering your engine it adjusts the fuel accordingly whether it be increasing duty cycle to the injectors or raising fuel pressure(i think increasing duty cycle). now that makes sense. so is a dry system a little bit safer than a wet system? and i guess the nitrous jets would be plummbed before the MAF, and thats near the intake i suppose? thanks. scho: yes i have heard that a wet system is safer also, but i just cant understand how the ecu is going to know if more fuel is needed. the amount of fuel sprayed into an engine depends on a number of factors, what the MAF reads, TPS, engine temp etc..., but most importantly the MAF. If the maf doesnt know that more air is entering the engine, then how can it tell the ecu to increase duty cycle? the only thing i can think of is that the BMW'S engine is really strong, strong heads and all. thats why detonation is minimal. other than that, i think the engine is running lean and wearing down quite quickly. much faster than if were to add fuel into the equation. timing is also crutial, but not for 100extra hp. Last edited by 94_325is : 04-02-2002 at 07:01 PM. |
scho, what size jets does your nx kit come with? where does it tap into the fuel line? |
| What are advantages or disadvantages when going with a wet or dry nitrous kit? I'm very curious to know...
__________________ H&R Sports | AA Chip | Cold Air Intake | Short Shifter (///M Lever) | OZ 17" Wheels | Zimmerman X-Drilled Rotors (front only) | Clears all around | RockfordFosgate and Pioneer audio | 5-Speed on 3.91 Differential |
Luke, the jets are for 35, 50, and 75 that came with the kit. I talked to them about 100 wet shot, but we will see how the 75 does first. ![]() |
| Luke, what I explained is how most of the kits work I was not refering to ZEX or VENOM nitrous kits, if he asked a specific question about a specific kit then I would have tryed to help with a specific answer but this is how the kits that I have worked with operate. Quote:
Thanks, Josh
__________________ 3.2L OBD1,Polished Vortech V-2 S/C,NX nitrous kit,NX GENX-2 kit,MSD window switch,NGK V Power plugs,BMP racing tranny mount,TB coolant bypass,AC removed,fan clutch mod,K&N CAI,cats removed,DTM style cat back exhaust,AA short shifter,AA clutch,AA light weight flywheel,Autometer and R1 competition meters,Custom 100% lockup diff.,17"BBS RC wheels,Eibach springs,back seat removed,Momo seats,Momo steering wheel,Momo pedals,Sony Xplode,JL audio,Rockfordfosgate First time at the track 12.72@107mph 1.8 60ft (NO NITROUS) Last edited by E-36 Tuner : 04-03-2002 at 08:05 PM. |
The kit that we are referring to is the Zex, and it most DEFINITELY injects the N20 after the MAF. On the BMW E36 there is an elbow right after the MAF, where the nitrous is usually injected...right before the throttle body. Luke has a rubber elbow there, mine has been upgraded to aluminum for my turbocharger kit. |
| I think on ALL kits it is supposed to be injected after the MAF. I have never seen nor heard about putting it before unless it was some prehistoric Nitrous kit. I would never put it before. Just think, direct port kits put it directly into the manifold. That is about as far from the MAF you can get. |
| well... ALL of the DRY kits for the new camaro, firebird and corvette LS1 engines inject the nitrous B4 the MAF sensor. the way it works is the sensor sees the drop in air temp, therefore denser air and more O2, and adds the corresponding amount of fuel. it actually works pretty darn well. the kits available include NOS, TNT, nitrous works, and maybe more. needless to say, it is a VERY easy install. and, no, it dosent ruin the MAF sensor on these engines. i think that the mustangs are the same way...maybe just a domestic thing. i thought that the BMW kits worked the same way (based on the advertisement pics that i have seen), and may have led E-36 Tuner to some false info about the BMW dry kits. i personally run the NX wet kit that uses a fogger nozzle in the intake tract. currently jetted @ 100hp. (approx 500 crank HP) ![]()
__________________ Black 2000 SS 6 speed, stripper car !egr, !TB coolant bypass, FTRA, k&n filter, whisper carbon fiber lid, borla cat-back, 17" nitto drag radials, 2002 LS6 clutch and slave cylinder, drill out mod, NX 50-150 hp kit, NX heater, NX purge, NX remote bottle opener, NX 3 gang switches mounted in front of shifter, NGK TR6's, Harlan shift light in the center vent, scanmaster. MI vanity plate "UBEHIND" best NA e.t. 12.67@110 with open borla, bypass power steering, and nittos. 3300#. best nitrous e.t. 11.74@119 with 1.8 60 foot and 150 hp shot. |
| you got me thinking now. what type of element do the domestic maf's use in them? ours are a heated film. i'm gonna email zex about this and find out what they say. thanks for all the good info. how do you like that harlan shift light? i was thinking about getting one. Last edited by luckybmw : 04-05-2002 at 06:45 PM. |
