Old 03-11-2002, 06:32 PM
Rides:97' 328is
pidnaul is a New Registered Member
Question should I un-install shark injector with nitrous???
This Wednesday I will be having SMA installing my nitrous kit for me.(decided not to do it myself because too much school and work..) So should I un-install the shark injector software before I always run nitrous?? Would it be okay if I left the software in and use at least 100 octain fuel?? I have heard that leaving the software in might cause damage to my engine due to timing advancement.
H&R race springs
Shark injector
ECIS intake
Zex nitrous kit(75 shot)
AA Generation III exhaust
Denso Iridium spark plugs (one range colder)
5% tint all the way around
Two 12" Kicker CompVR
PPI amp
Old 03-11-2002, 07:32 PM
Rides:BMW, M3, 94
Brekyrself is a New Registered Member
I know for a fact on OBDI cars with chips that advance the timing you can't run them with nitrious. But I do not know how much the Shark Injector plays with timing. I've heard the shark just really bumps the rev limiter and takes off the top speed limiter. Thats why it really doesn't offer a big performance upgrade.
'95 M3
Bone Stock........on the outside
Old 03-11-2002, 08:22 PM
Rides:97' 328is
Shark Injector
That's wierd becuase when I installed the shark injector, it took a whole secound of of my QT...This could have been becuase I drove better the secound time but I doubt it.
Before Injector: 15.7 QT's
After Injector and changing spark plugs: 14.5 QT's
H&R race springs
Shark injector
ECIS intake
PPI amp
Old 03-11-2002, 08:37 PM
Rides:'98 BMW M3
Yes you should in-install the shark software if you want to hook up a N20 system.
Old 03-11-2002, 08:43 PM
Rides:97' 328is
Just checking...do you meen un-install and not in-install?
H&R race springs
Shark injector
ECIS intake
PPI amp
Old 03-12-2002, 12:34 PM
Rides:S/C 328is
RFish328 is a New Registered Member
Definatley take off the shark software and maybe find a way to retard your ignition timing.
Old 03-12-2002, 12:46 PM
Scho's Avatar
Moderator
Rides:1999 White M3
You should take it off. You will not need to retard your timing unless you are running over 100 shot. Get an MSD Window Switch.
Old 03-12-2002, 05:53 PM
Rides:97' 328is
what is an MSD window switch and how will that help me?? also what is the min. octain fuel I should run? Where I live I can get 135 octain for $5 a gallon...
H&R race springs
Shark injector
ECIS intake
PPI amp
Old 03-12-2002, 06:31 PM
Rides:02 M3
///Alpine95 is a New Registered Member
Sorry don't know what the octane requirements are, but the window switch permits nitrous delivery only above a specified minimum rpm and below a specified maximum rpm. Hence the term "window". It's basically a safety feature.
Old 03-12-2002, 06:37 PM
Rides:97' 328is
Thanx
H&R race springs
Shark injector
ECIS intake
PPI amp
Old 03-13-2002, 09:30 AM
Rides:1997 M3, A Camaro, and a Truck
FaRTaLOTTT is a New Registered Member
MSD Window Switch
MSD Window Switch
http://midnightautowerks.com/Installs/MSDE36/MSDM3.html
- Derek 1997 BMW Lux M3 Coupe 5 spd (RE Exh, ECIS Intake, Sharked, M50 Manifold) SC61 On the way!
- 68 Camaro, 05 Tacoma, 02 Honda CRF .50
Old 03-14-2002, 09:14 PM
Rides:97' 328is
Well they finally finished the install. I must say they did a very nice job..looks very clean. You can hardly tell that it is even there. Hopefully I will be able to take picks tomorrow so you can see.
By the way.......I inquired about the MSD window switch, and SMA told me that I could not use one with my application because normally you would tap onto the solinoid, but my unit is totally sealed.
H&R race springs
Shark injector
ECIS intake
PPI amp
Old 03-14-2002, 10:26 PM
luckybmw's Avatar
Rides:soon to be gsxr600
luckybmw is a New Registered Member
hmmmm..... you usually tap the ground wire for the solenoid into the msd window switch. tell them to try that.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601
