Old 03-09-2002, 08:22 PM
Rides:97 m3
Lemunade00 is a New Registered Member
Question Turbo Vs. Super
Ok i know its the age old question.. but i finally have got enough money together for one or the other.. And i would really like to know what ppl out there think.. most bang for the buck.... this is going on a 3.2 m3 engine.. any advice is helpfull.. thanks
Old 03-09-2002, 08:46 PM
Rides:BMW, M3, 94
Brekyrself is a New Registered Member
Well it depends on what you want to do with the car. First off if your going to be tracking, get a supercharger because the power curve is more linear. The SC will behave like a normal NA engine just with a lot more power. Now the turbo on the other hand will make full boost at around 3000-4000rpm! The turbo makes all its boost way down low because they can spin up faster since there working off the exhaust not the crank.
I would have to say a SC (vortech blower) is more reliable because its not always going to be making so much boost in normal driving. One nice thing about the turbo though is that you can use the boost controller and adjust it to however you like. If you want a drag car get the turbo! Another added bonus of the turbo is the blowoff valve
'95 M3
Bone Stock........on the outside
Old 03-09-2002, 08:51 PM
Banned
Rides:BMW
Here is your answer.
Old 03-12-2002, 11:44 AM
Rides:97 m3
welp i have been looking around and reading alot since i last posted this.. the cheapest SC i found was the ESS.. which is offering 357Hp.. i am really striving for atleast the 400mark.. but i still wanna keep this car some what of a daily driver.. but you as said.. we all the luv that sound of that blow off on the turbos.. i am still up in the air with this.. lol
Old 03-12-2002, 11:52 AM
Rides:93 325is
caball88 is a New Registered Member
i was reading alot about this as well, and i thought that the turbos were the way to go cause you get most the power down low in the rpm range. but looking at cost the supercharger seems to be more reasonable. you get about the same amount of power even tho its in the upper part of the rpm and it's cheaper and easier to install. you can use the money that you save to get a big brake kit to help stop all that new power as well. i'm sure if you up the boost a bit on the supercharger that you can get to 400hp.
Old 03-12-2002, 12:51 PM
Joey325i's Avatar
Go for RMS Stage 2, my cousins pushing 392HP to the ground on 91 octane, hes almost to the 400 RWHP mark
Old 03-12-2002, 01:48 PM
Florida Rep.
Rides:'98 Turbo M3
///MCubed is a New Registered Member
Two different animals in terms of price, performance, and use. Having had both, I chose to go and stay with turbo. Like I said, two different animals with too many variables to really present an unbiased opinion. If you gave me more information as what the intended use/application would be (i.e., track, daily use/street racer, ego booster, etc.), amount of HP and TQ you wanted, I would be able to give you a better answer.
'98 M3
GReddy Gauge For Sale (Click Here)
"Come Play with Power"
Old 03-12-2002, 01:57 PM
scottycs's Avatar
Custom Turbo 328
Rides:e28, e30, e36, e39
You can have a blow off valve on a supercharger. My friend has one on his supercharged civic si.
-Chris
Old 03-12-2002, 02:19 PM
Rides:Alpine 95 M3
PDX///M is a New Registered Member
I think the answer is pretty simple. If you want a race car and you have a lot of money then turbo it. If you want a reliable daily driver then just add a SC.
When you start getting up in HP (~400) you are going to need to replace other pieces of the car. For example a better clutch, better brakes to stop you when your hauling ass
For the money the SC is hard to beat. The ESS kit is the best HP/$ ratio out there.
Now if your really wanting more than just the SC I might suggest the upgraded CAMS and Full exhaust. That will also depend on the city you live in because exhaust probably isn't legal.
Here is what I am doing:
ESS SC system ($3900 with group buy discount)
Brembo Brakes (or something comparable $2000)
Racing Brake ducts for cooling ($200)
Supersprint Cat Back Exhaust ($650) (has to be street legal)
Carbon Fiber Hood ($800) (maybe)
Still with all of those options you still are $2000 less than the turbo kit.
If you want to look at the groupbuy info check out:
http://home.attbi.com/~kbleck
Lots of info there
Old 03-13-2002, 05:20 PM
Rides:97 m3
i for sure know brakes are going to be key.. and i checked out the thread.. if i were to get in on that deal when would it get to me.. i have a may10th deadline..
Old 03-13-2002, 05:58 PM
Rides:Alpine 95 M3
Hoping to order this week
First order will go in this week if I get 10 people ready to go. Otherwise the 2nd order will go in after the deadline for the GP which is March 31st.
Old 03-17-2002, 06:28 PM
Rides:97 m3
Ok the SC in the group buy is the ESS VT right? I tried finding out info on there VX SC that is supposed to be coming out. Anybody heard any specs on it???
Old 03-17-2002, 07:23 PM
Rides:E36 M3
Hellrot Sachin is a New Registered Member
Personally, I'd go supercharger before turbo. Yeah, it's cool to have a turbo, but in the end, the power is about the same. I was shocked to see the AA dyno runs netting around 300rwp. Supercharger power seems more usable because it's linear. You can power through a turn with moderate boost whereas in many cases, excessive boost down low makes it hard to plant.. Plus, the cost is less than 1/2..
HRS
...ouch, I got bit by the mod bug.
Old 03-17-2002, 11:52 PM
Rides:'99 M3
CKim is a New Registered Member
As someone who's currently supercharged (roots blower on my '00 Integra GS-R), I would say that a turbo is a better bet than the centrifugal blower (which only makes full boost at redline).
Granted the blower will have a more linear power curve, and no lag, the turbo will definitely make more power at the same boost levels because there's no parasitic drag. Also, most superchargers don't have intercoolers and the hot air reduces the amount of power made, and also can create problems with detonation.
Instantaneous boost is also not always a plus. While you won't get instantaneous full boost with a centrifugal SC, you do with a roots blower, and I'm finding that I'm having tip-in detonation problems. Boost hits too fast, timing is over-advanced in the mid-range, and then you get pinging. Also, if you get part-throttle boost, you'll still be running open loop, and you'll tend to run lean, which can also cause problems.
I'm planning on getting an e36 M3 sometime in the near future, and I'll most likely be turbo-ing it (building my own system, hopefully).
Old 03-18-2002, 12:22 AM
Rides:1997 M3, A Camaro, and a Truck
FaRTaLOTTT is a New Registered Member
I thought AA now makes you purchase a big brake kit and requires you to take at least one Driving school prior to purchasing a turbo kit from them. At least that's what I read in the new issue of European car regarding the AA turbo kit in the '95 M3 that spanked a Viper. =) You should take that into consideration in regards to pricing since you only have enough for one or the other.
- Derek 1997 BMW Lux M3 Coupe 5 spd (RE Exh, ECIS Intake, Sharked, M50 Manifold) SC61 On the way!
- 68 Camaro, 05 Tacoma, 02 Honda CRF .50
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525
