Hi all, am going to start my new project since i change the old engine and swapped to the M50B25 i have all the turbo parts from the old conversation, HX35 turbo with 12cm turbo housing and 3" downpipe all the way till the muffler in the end, am using 1 high flow muffler only, am going to use a thick head gasket to lower the CR, but still now sure what thickness is needed in my case, and for the ECU what i can run other than a standalone ECU or MS, am on budget here, am aiming to run at 1.5 bar as safe boost, so guys help me with the following:
1-what head gasket thickness i should get to run the 1.5 BAR boost safely, without any damage to the engine??
2-what i can use other than getting MS or something like that? i already have FPR with its gauge to watch over it??
3- what would be the result of such setup??
thanks in advance for helping me here guys
