Old 05-06-2009, 09:38 AM
Rides:bmw, 318i, 1994
94bmw318i is a New Registered Member
turbo e36 318i??
im new to the whole bimmer scene and i want to turbo my 318i e36 but i dont know where to start or where to look for a full kit.....an guidance would be appreciated
Old 05-30-2009, 10:10 AM
Rides:BMW, 318ti, 1998
Jazzykelly is a New Registered Member
I am new to this forum. Like you I am interested in a turbo kit for my 1998 318ti. Recently I had a BMW dealer re-program the ECU for better performance. The power improvement was only noticeable above 3500RPM. I then installed a cold air intake system. The combination produced very noticeable power improvement in acceleration at take off and at high RPMs. Still I think I want more. That is why I am checking out a turbo kit. I checked out the supercharger, but $3200.00 is above my means. Anyone out there with a complete turbo kit for a 318ti? Jazzykelly.
Old 06-04-2009, 09:03 PM
Rides:BMW 318IS 1992
chapellej is a New Registered Member
don't turbo you will need to change internals if you want proper hp gains, with stock internals you will only be able to boost between 5-7 psi with no damage. if you super charge it easier on the engine and better for daily driving, go to KO Performance - High End Import Performance and OEM Parts, car parts . i am super charging my 318i and it is alot easier to install and less hassle.
Old 06-05-2009, 05:38 AM
Thank you chapellej. After much research I also found that installing a supercharger is the best way to go. My preference is the Downing-Atlanta supercharger. I will use the KO Performance only if I cannot get the Downing Atlanta. My installation is a near future project. Have to raise US3500.00 first. Please let me know how your car performs after the install.
Old 06-05-2009, 08:02 PM
will do i was hoping at first that i could twin turbo my car however upon much research this is no t a viable way to get power that is affordable, also less hassle. keep in mind you may also want to change cams as well as your exhaust manifold, install a cold air intake and chip. you will see some gains from that. i have done all of that plus custom 2.5 pipe for my exhaust and because the emissions restrictions arn't as strict i have removed my catalytic converter. also i have added a fuel pressure booster which helps with the fuel response. but do your research and also check out m42club.com
Old 06-06-2009, 09:35 PM
Rides:318ti318
bluntface is a New Registered Member
also lots of people over at 318ti.org have the Downing-Atlanta, lots of good information there..
Old 08-08-2009, 11:44 PM
frank1975's Avatar
94 318i
Rides:94 318i
It's not how much boost it's how much HP. It's possable to make more HP with less boost (adiabatic efficiency). Also I much rather trade in a 318 for a 325 vs a DASC. You will have the same power and probably have money left over.
E36 Parts For Sale
Old 08-09-2009, 05:25 AM
Thanks for your response. By shear accident I was able to buy a used DASC for $2700.00 (shipping included) from the friend of a Mechanic who works at a BMW specialty shop. He has checked it over, made sure all parts are there and replaced all the serviceable parts. I should be receiving it this week. I plan on starting the install as soon as I receive it. I will post the results.
Old 08-09-2009, 09:07 AM
frank1975's Avatar
94 318i
Rides:94 318i
Cool, the two best mods I did were exhaust and tuning especially since the exhaust only cost me about $50. Throttle response and the gain was pretty darn good. Later I ran mine at 10psi and used larger injectors. There was a noticeable gain, but not work the time or money.
E36 Parts For Sale
Old 08-09-2009, 10:03 AM
I do not plan on making anymore modifications after the DASC is installed. 215+ hp and 200+ lbs of torque is more than enough for me with a 2800lbs car. The only thing I will change in the future is the muffler when it goes. I like the Remus mufflers.
Old 08-10-2009, 04:32 PM
Rides:318is, Accord, Jeep CJ7
sikdogg is a New Registered Member
For about the same money, you can do a motor swap on your 318. With a DASC you can get ~200hp, but at that HP level the m42/44 is topped out and the only way to get more power would be to rebuild with forged internals. With a motor swap, 200hp is the starting point. J!m at 318ti.org sells a swap manual to walk you thru the whole process including all the parts (with part numbers) that you would need.
Old 08-10-2009, 06:30 PM
Yes, that is true, but I think installing the DASC is much easier. Also 200hp is enough for me with this car. I do not race. All I need is just a little more power around town and on the highway. Thanks for the info though.
Old 08-10-2009, 06:49 PM
frank1975's Avatar
94 318i
Rides:94 318i
I think it's 210 at the crank and you don't need to do a built engine for more than that. After mods mine ran 189 at the wheels which is about 230 at the crank. I've seen more a few dasc's on 100% stock motors put out 200-225 at the wheels. Low end still sucks with the DASC though. I'm not sure what 0-60 is but a stock m44 with a stock DASC only runs low 15's in the 1/4 which is not much better than the average car with is mid to upper 15's. It was a fun car, but nothing great.
E36 Parts For Sale
Old 08-11-2009, 04:35 AM
I read somewhere that the M44 with a DASC does 0-60 in 6-7 secs. It's up there with the 325i. I think that's good enough for me. I am really looking forward to having mine installed.
Old 08-11-2009, 04:37 AM
Do you hear the supercharger whine in the car?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
