Old 03-18-2008, 07:47 AM
Warren's Avatar
AKA Bad W
Rides:1997 BMW 328is, 1988 Porsche 951S
Warren is a New Registered Member
Going AA Superchaged...
I've decided to go with the AA supercharger kit for my 328is while its still on sale. It will be running 8psi of boost. My engine has 130,000 miles on it and runs without any problems.
From experience what do I need to do in order to maintain daily driveability?
I was thinking about just getting the head rebuilt with a cometic gasket.
Any recommendations would be appreciated!
Thanks!
1997 BMW 328is:
Gruppe M intake
Clear corners, sidemarkers, taillights
UUC stage II clutch kit + lightweight flywheel
BA short shifter
BA performance ignition coils
AA supercharger @ 8psi (not yet installed)
PSS suspension (not yet installed)
VDO gage kit (not yet installed)
1988 Porsche 951S:
SSR 18 in wheels
custom chip by Lee at "My Garage"
Lindsey Racing Hard Pipes (not yet installed)
Lindsey Racing MAF kit
Old 03-19-2008, 05:46 PM
fairweatherpunk's Avatar
Rides:E36 325
Head gasket's not a bad idea, but I would do a compression test before I would do anything. Make sure it's close to the same across all cylinders. You are pretty far north, I don't know what the temps are like up there but heatsoak shouldn't be a problem.
Old 03-23-2008, 05:42 PM
BMW Maniac's Avatar
USMA '01
Rides:AA Turbo 97 M3, 06 Z4MC, 91 318i
BMW Maniac is a New Registered Member
Take care of the cooling system. If you're headgasket isn't leaking, don't worry about it....8psi on the stock headgasket is nothing.
2006 Interlagos Blue MZ4 coupe
Premium pack, extended leather, heated seats
97 Arctic Silver M3/2
Built motor + SC62 + TEC3r
91 Alpine White 318i
*For Sale*
Old 03-24-2008, 06:21 AM
Rides:E36 325
BMW Maniac, when you say take care of the cooling system do you mean upgraded water pump and thermastat? Just curious?
Old 03-24-2008, 08:37 AM
92318is's Avatar
<--Dream Car:)
Rides:'99 Eclipse GS-T
Region: USA - Great Plains
92318is is a New Registered Member
I'm sure he means replace the radiator with an all aluminum unit, replace the hoses, waterpump, thermostat, thermostat housing, and expansion tank.
To the OP, as long as your regular maintenance is kept up, and you have all of the normal maintenance issues taken care of (ie, cooling system) then running 8-9 psi on a stock motor shouldn't be an issue. No internals should need to be done, other than that, I would upgrade the stock clutch and while you're at it flywheel, maybe some motor/transmission mounts, injectors and fuel pump, get a good tune once you've got the charger installed...other than that, I would think you'd be fine with all other stock parts. Maybe get an oil and water temp guage, and obviously a boost guage, just to keep an eye on those things.
"If this isn't Burger King, then where the hell are we?"
'99 Eclipse GS-T
5 Speed, 20g Turbo w/16g Compressor Cover, Front-Mount Intercooler, 550cc Injectors, Apexi N-1 3" Cat-Back Exhaust, 3" Downpipe (cat eliminated), Manual Boost Controller, Bored out 1st Gen BOV, GReddy Turbo Timer, Apexi Air Fuel Controller (SAFCII), Auto Meter Boost & Air Fuel Guage, Polyurethane Motor Mounts, ACT 2600 Clutch, Walbro 255hp Fuel Pump, Professional Tune
'92 BMW 318 iS
Sold
Old 03-24-2008, 08:40 AM
92318is's Avatar
<--Dream Car:)
OP - sorry, didn't check your sig, you've already got an upgraded clutch/flywheel, so I guess you wouldn't need that
'99 Eclipse GS-T
'92 BMW 318 iS
Sold
Old 03-24-2008, 12:46 PM
Rides:E36 325
Thanks
Old 03-26-2008, 11:40 AM
Warren's Avatar
AKA Bad W
So you are saying that as long as I have good compression and upgrade the fuel and cooling systems my engine is going to be alright with 130,000 miles on it?
What about putting an intercooler on the supercharger?
Thats a releif, if I dont need a rebuild then I can get that LSD I've been eyeing too lol.
1997 BMW 328is:
Gruppe M intake
BA short shifter
1988 Porsche 951S:
SSR 18 in wheels
Old 03-26-2008, 06:37 PM
BMW Maniac's Avatar
USMA '01
Let the company that you buy from do the R&D....if it doesn't come with it, then you probably won't need it.....but yes, as long as all that is ok, save your money...get the LSD!
*For Sale*
Old 03-27-2008, 08:21 PM
92318is's Avatar
<--Dream Car:)
As long as the engine is still running strong and there are no problems, it should be fine. Obviously it couldn't hurt to rebuild the engine, but thats a lot of money (unless you can do it yourself, but it'd still be fairly expensive). But running such a small amount of boost, you're not putting a whole lot more stress on the engine. If you have the money to get it rebuilt and are planning on keeping the car for a while, I would do it, otherwise, I wouldn't worry about it too much.
'99 Eclipse GS-T
'92 BMW 318 iS
Sold
Old 03-28-2008, 10:55 AM
Mad Scientist
Rides:BMW, M3, 1997
mcclaryjj is a New Registered Member
Good afternoon everyone, I've been gone for some time and in a few days I'm headed to japan for 8 months. But, when I retrun I will be dumping some money a little at a time into my 97 m3, it has 110,000 mile on it. The upgrades are as listed; UUC short Shifter, UUC CAT Back exhaust, UUC Cold Air Intake, Shark injector. That's pretty much it... I know that's nothing but I had to start some where... I'm asking you guys what can I do next and if anyone has a step system I can try first, like what's first...
Old 03-28-2008, 03:18 PM
92318is's Avatar
<--Dream Car:)
Most people will first tell you make sure all of the maintenance is taken care of, but hopefully most people know that. Not just regular oil changes, but tansmission fuild and diff fluid, also radiator flushes are always good, and make sure you have had the entire cooling system (radiator, expansion tank, thermostat, thermostat housing, waterpump) replaced as well, since its such a major weak point on all e36's. After that, I've heard some really good things about Turner Motorsport's performance package for the e36 m3 Turner Motorsport - Item# TMS-I3THDR - E36 M3 OBD-II TMS/Conforti Performance Package Stage IV - E36 MZ3
I would also upgrade the suspension, if its just street/light track driven, I've heard good things about coilover suspensions, again, Turner's site has some good stuff. Also, bbs rims look awesome on BMW's, and can reduce weight. Also, as a side note to Turner's performance package, you can buy each peice separately, since you do already have a CAI, but after getting the headers, injectors, etc. that come with the kit, I would definitely get the chip it comes with, since its tuned to work with those performance parts the kit comes with.
How's that for a start?
'99 Eclipse GS-T
'92 BMW 318 iS
Sold
Old 03-28-2008, 09:44 PM
Mad Scientist
Rides:BMW, M3, 1997
Thanks Agian
Thanks again, you've been very helpful... One more thing, I've had trouble with a ticking noise under the hood lately like noisey lifters, but I took it to my regular Mech and they told me that my engine is strong and sealed great, no leaks, no overstresses. But it just troubles me sometime when I hear it. How much money will it cost for an engine rebuild or shall I ask what does an engine rebuild consist of?
Old 03-29-2008, 01:41 PM
BMW Maniac's Avatar
USMA '01
Noisy lifters...use thicker oil if it bothers you that much. As far as an engine rebuild, its a lot more money than you'd want and for the money, why not just go turbo? You can install a thicker hg, arp head studs and make over 600rwhp on that engine....if you still want to take the engine apart, build it with forged internals and keep upping the boost
*For Sale*
Old 03-29-2008, 05:28 PM
Mad Scientist
Rides:BMW, M3, 1997
TurBo or Engine Build?
Forgive me for not being up on the tuning, but I thought if I went turbo I would have to rebuild to get more out of it? And by the way a turbo will cost ooh I'd say last time I chekced around $8~10 not including labor... am I right...and who's got the best....I see that alot of the cars on here is stuck on AA...
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
