Old 02-02-2008, 10:48 PM
itsabimmerthing's Avatar
Anti-bandwagon
Rides:Soon a bimmer
boost general, and abbreviations
I think this would be a cool, useful thing if it isnt already on this site.
I think it would be cool, to post the common turbo slang, and some general FAQs. If we all pitch in, this could help many people. Lets see how it goes.
FMIC- front mount intercooler
SMIC- side mount intercooler
BOV- blow off valve
BPV- by pass valve
WG- waste gate
IWG- internal waste gate
EWG- external waste gate
IC- intercooler
SMIM- sheet metal intake manifold
MAP- Manifold Absolute Pressure (sensor)
BLACKBOX- device which hides boost pressure from ECU
ECU- Engine control unit
Boost creep- unintentional boost increase, usually through overrunning of a wastegate.
Duty cycle- the amount of work, in percentage, your fuel system is taking.
Boost leak- this is when you have a leak that is associated with turbo hardware. Car usually runs like shit, and boost doesnt go as high as you would wish.
Piggyback- A computer system which works in conjunction with your factory ecu, lets you datalog, and tune many parimeters in some situations
Stand Alone- Plugs in to existing harnesses (direct fit) which takes over your ECUs job. You program it to do what you want. Datalogging, nitrous, boost, timming, and other very important parimeters are tuned through this.
DOWNPIPE- Runs from turbocharger wastegate/hotside blades VIA Vband or flanged to your exhaust
DIVORCED DOWNPIPE- A downpipe in which you directly vent the WG to the atmosphere. Very effective, very loud, very illegal.
Common turbo abbreviations you may see when doing a homemade setup using FACTORY TURBOS FROM FACTORY CARS
CT26- MK3 Toyota Supra turbocharger
E3-16g- Evolution 3 16g. Light weight blades, largest 16g, very efficent.
F20g- FUSO 20g from the Mitsu Diesel
14b- Very powerful turbo for its size, from the 1g DSM cars.
13g- Automatic tranny 1g DSM turbo
E16g- Reverse scroll Evolution NG turbocharger
T3- Can be found on many cars, including the popular Turbocoupe Tbird turbo pre 87
Hx35- Came on certain Cummins I beleive. Popular, very hard hitting, very efficent, very strong turbo. Popular, cheap, easy to find.
HX40- Same as above, but larger lol
FAQ regarding boost levels.
How much can my stock engine take? -This is a just about impossible question to answer. It depends on how large your turbocharger is. Larger turbos create more power, and is more stressful to your motor at same boost levels with a smaller turbo.
How important is a good tune- The most important. Simple as that. With a good tune, you can push your car harder, while being smoother, and making more power. It is imparitive you have it done professionally on a dyno.
Can I install my own stand alone- Yes. You can if it is direct fit. It is LITERLY plug and play. But tuning is another story.
What are advantages to an external wastegate- An external wastegate stops boost creep, which can quickly destroy a motor. Also, boost recovery is quicker.
Can I run a large exhaust on an internal gate- it depends on the size of the turbo. In many cases creep occurs. Many people port out the internal wastegate, and notice no trouble. Many find out the costs of cutting corners.
Are bigger turbos efficent at lower boost- yes and no. Engine size helps dicatate many factors. A turbo can be unefficent at 10lbs versus 14lbs. Turbo surge charts are important
What does it mean to run lean- More air than fuel. Quite simply, it can create a very high EGT QUICKLY, and leave you pissed off on the side of the road
Is it good to run rich- You dont want to run too rich. You could foul plugs, and if bad enough, create carbon in the motor, loosing power anyway. This is where that tune comes in to play
Why datalog- Logging injector duty cycles, as well as knock count could save you headaches. If you see excessive knock, you know you have a problem, and should do something about it quickly. If you see duty cycles high, you need to determine what is safe.
Log manifolds versus equal length header- log manifolds are cheaper, and in some cases more durable than a turbo header. with a good header, it will be durable. many cheaper ones simply cannot get hot and cool down billions of times with the weight of a huge snail pulling on it. log manifolds are less effective at scavaging exhaust, and spoolup.
What is turbo lag- this is when you are not fully spooling the turbo. larger engines spool faster, smaller turbos spool faster. Turbo boost is always a downshift away. In many cases, lag is minimal because of this
Can I run low octane gas- I wouldnt. simple as that
Lowering compression- Lowering compression makes turboing easier, and tuning easier. Some cars benefit from raising, IE 7:8 on a turbo 4g63. Examples of lowering would to lower the high S50 comp ratio to help prevent detonation. Many people use thicker head gaskets. I would reccomend just getting the pistons and doing it right.
This is pretty basic. Hope it helps. Add what you know, and lets get this thing huge!
Old 02-03-2008, 04:51 PM
E30stain's Avatar
Sherminator
Rides:'96 323i
cant say theres anything i can add to this besides other turbo names but this is great!
'is she fucked or is she proper fucked?'
'shes proper fucked'
'ahhh fuck'
Old 02-03-2008, 05:06 PM
Anti-bandwagon
Rides:Soon a bimmer
Thanks man. I think this could help people big time. I know how it can suck to have to wait for a response before taking action on a project. Hopefully this can help people without having to feel dumb, or wait for a response.
Old 02-06-2008, 11:45 AM
BMW Maniac's Avatar
USMA '01
Rides:AA Turbo 97 M3
BMW Maniac is a New Registered Member
Charge pipe - piping that leads to the inlet of the turbocharger (contains filter, MAF, and piping in my setup)
97 Arctic Silver M3/2
AA Stage II w/ GT35r
NickG tuning w/o cats @ 15psi 425/443 on Mustang Dyno
91 Alpine White 318i
*daily driver and constantly under construction*
Old 02-06-2008, 12:39 PM
Anti-bandwagon
Rides:Soon a bimmer
A few more I forget as well!
Pressurized plenum- A pressured carb hat type device that is used when turbocharging carbed cars
EGT- Exhaust gas temp
Pyrometer- EGT gauge
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732
