View Poll Results: Twin Turbo or Single Turbo?
Single Large Turbo 7 63.64%
Twin Turbo 3 27.27%
Turbo and Supercharger 1 9.09%
Twin Screw Supercharger 0 0%
Voters: 11. You may not vote on this poll
Old 12-18-2007, 03:44 PM
Track License
Rides:Turboed 98 ///M3/ 93 turbo 240sx/ 2007 X5
DC47A is a New Registered Member
Twin Turbo vs. Single Turbo?
Let me Know what everyone thinks, about the ever popular debate single turbo or twin turbo. Especially these days with the new ball bearing turbos pretty much eliminating that dreaded twin turbo lag of the past.
Old 12-18-2007, 04:53 PM
ANDRÜ's Avatar
mooseoftoose
Rides:'87 325
Well the point of a twin turbo setup is to reduce lag, which it does. The "dreaded turbo lag of the past" would be form a single turbo. Twin typically solves solves this problem.
-Andrew
Old 12-18-2007, 07:55 PM
Track License
See i thought it was the total opposite. You have to spool both turbo witch takes more time and emission hence the lag. I guess you learn something new everyday!
Old 12-19-2007, 11:54 AM
Rides:Turbo 332is, 86 535i
LDORADO325 is a New Registered Member
With all the extra work in fabrication and parts cost for twin turbo, the single turbo is the way to go. Most high hp cars use a single turbo setup.
-Mike
Built S52 w/GT3582R T4
My Website w/ More Pics
Old 12-19-2007, 12:18 PM
RacerJames666's Avatar
I concurr with ldorado on that issue.....one less turbo to cook.....
and a lysholm or roots type blower is the best choice for "slap it on and go" performance
Old 12-19-2007, 04:54 PM
gnastydent's Avatar
Rides:bmw 325es 1986
gnastydent is a New Registered Member
well when you think about it the twin turbo has 3 cylinders powering it comparied to the 6 powering the single. single large ball bearing turbo like the t51 kai
Old 12-19-2007, 08:22 PM
Rides:BMW M3 95
twinm3 is a New Registered Member
ONCE YOU GO BOOST YOU NEVER GO BACK!!!
Old 12-23-2007, 06:07 AM
Rides:BMW 325i -87
Nisse977 is a New Registered Member
It it better for the turbo-spolup when it is only 3-cylinders that i banging in to the impeller. 6-cyl it to smooth if you understand what i mean. Why do you think the old Alpina B10 Biturbo had two turbos, and why does the new 335i have two. Toyota Supra, Nissan Skyline and so on.
I have a friend that is working on Saab. He is mapping the turbo engines for them, and he says it is a little bit better to have twinturbo on a strait six engine than just to have one. But like i said, one works good also, but maybe you will have little more lag.
Another thing is if you have one turbo with two intakes... then it is also best to have 3-cyl in one hole and the other 3 in the other. So just don´t put al cylinders to one pipe.
But ofcourse like you said, it is easier and cheaper to only have one turbo.
Read the book Performance Tuning Forced Induction by A. Graham Bell then you understand more
Product: Forced Induction Performance Tuning
Old 12-23-2007, 10:08 AM
Highboosted's Avatar
Road Race or Die
Region: USA - Great Plains
Depends. That's my final answer.
Want to have the fastest Skyline? Twin turbo setup in parallel.
Want the fastest Supra? Single turbo.
Want a torque monster? Positive displacement supercharger.
Want the bolt-on-and-go compromise? Centrifugal supercharger.
Want the "dyno queen" monster? Huge single. (Larger the compressor and turbine, the more efficient)
Have a V style engine? Best bet is twins, because going single gets tricky and expensive.
PS The 335i has twins for packaging and emissions purposes according to BMW. Smaller compressors allows them to close-couple the turbos, ports, and catalysts (lights off the cats faster), which is the only way they could make it meet the new regs on emissions, and it allows them fit it all in the engine bay. A single would make the runners longer, and the downpipe to the cat longer (because the single would not fit directly next to the engine), which would make it not pass emissions. If lag was the major concern, they would have used a Garrett VGT turbo like Ford and Porsche did.
Join NASA, too!!!!!
Old 12-23-2007, 06:47 PM
Track License
I really want to thank High Boosted and Nisse for brining two really good posts together! You both brought some great information together!!!
Old 12-25-2007, 08:45 AM
gnastydent's Avatar
i think its just a sales thing also, if you own a supra or a skyline then you got money and if someone say 1 turbo your like, o ok a labarin has a turbo but when you say twin it like omg 2 turbo that must be like twice the boost. i still go with single large because you can push more boost faster cause 2 med size turbos will take longer than 1 single large turbo. and you also got to think about the air flowed to the intake because it maybe 30 at the turbo but 25 at the throttle body i just think personally i choose 1 single large air flowing monster it also way less confusing in setting up the maps.
Old 12-28-2007, 01:17 AM
E30stain's Avatar
Sherminator
Rides:'96 323i
as far as in know...
*single large turbo = longer spool up but bigger top end power
*twin turbo in series = smaller one spools up gives engine more low down power to spool larger one up quicker (only know a couple of drag cars with this setup... knowledge of this comes from very very very big diesel engines on ferries ect. that dads driven.\
*twin turbo in parrallel = 3cyl on each turbo... many different applications of this setup can be set up for low down power or huge immense amounts of power although the turbos of today are big and efficient enough to not need this sort of setup.
im not an expert so if someone wants to correct what ive just said :P oh and the series setup is really weird but the engines its used on are that big and boosted that the oil actually has to be heated and then pumped through the engine for a good 15-30mins before startup... so yeah not the best setup to consider on a car let alone one to be used on street.
'is she fucked or is she proper fucked?'
'shes proper fucked'
'ahhh fuck'
Old 01-01-2008, 01:45 AM
Rides:BMW 325i -87
Yes most dragcars has one single turbo. But Vidar Strand has twinturbo setup on his M3 E36 dragcar with S38 engine (E34 M5 engine).
Look here!
V.S Motor - Vidar Strand
BMW M3 E36 3,9 - 1422bhp / 1610Nm (1186ft.lbs torque) - engine buildt by V.S Motor
And here you have some movies when he was driving it on some car meetings in Sweden 2006. the best time was 7,64s @ 293km/h on 1/4mile That´s a fast Beemer!
Old 01-18-2008, 07:18 AM
TRANCe36's Avatar
Track License
Rides:e36 coupe
TRANCe36 is a New Registered Member
WHY IS ONE OF THE OPTIONS TURBO + SUPERCHARGER, WOW
E46 Dinan XI-E36 Turbo sedan - totaled, suffered a blow from a drunk woman in a pickup
Alpine white- e36 coupe
Old 01-18-2008, 08:01 AM
itsabimmerthing's Avatar
Anti-bandwagon
Rides:Soon a bimmer
I wouldnt ever twincharge, but it has been done. A shop twin charged a mini cooper with excellent results. Many people take the 4agze supercharged mr2, and slap a turbo with it. VW actualy has a new car comming out with twin charging technology. Its not impossible, and not that far from being a fad.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393
