Old 07-29-2007, 05:08 AM
Proctor750's Avatar
Ex M5 driver
Rides:bmw, M3, 1995
Proctor750 is a New Registered Member
Valve Retainers turbo M3
So I have an early 95' M3, which will be turbo soon. Soft valve retainers right? Should I replace them? or will they hold up..
Old 07-29-2007, 01:42 PM
eurotekM3's Avatar
meh......
Rides:95'BMW M3/ 01'AUDI S4
eurotekM3 is a New Registered Member
if your going for big hp/boost i would..if your not then dont..
vacmotorsport.com has all the good stuff....
Old 07-29-2007, 07:34 PM
Proctor750's Avatar
Ex M5 driver
Rides:bmw, M3, 1995
Well im shooting for 400whp with just the 140mm headghasket. Should I put the retainers off until I put the lower compression pistons and rods way down the road when I shoot for 600whp? Or just go ahead and do it for the 400?
Old 07-30-2007, 04:56 PM
RacerJames666's Avatar
Id say why not replace! Broken cars suck ass...
ask kormanfastbmw.com too, they are quite knowlegeable
Old 07-30-2007, 07:54 PM
tws tws is offline
Rides:BMW, M3, 1998
tws is a New Registered Member
Shouldn't spring replacment have to due with what RPM the vehilce will be running at and the amount cam lift will be?
i.e. under 6,800 RPM with stock cams the springs will not reach a frequency that will keep them open causing a valve to float.
It is a slippery slop and the grade is steep. If you do the head work might as well do the bottem end. Have 600HP at RMS and not 600HP at peak.
Old 07-31-2007, 06:42 PM
Proctor750's Avatar
Ex M5 driver
Rides:bmw, M3, 1995
I'm just replacing the Retainers for now.. I will do the entire valvetrain once I do the lower comp. build. Springs will stay stock for now. Im not planning on doing the 600whp build for more than a year....
Old 07-31-2007, 07:49 PM
tws tws is offline
Rides:BMW, M3, 1998
call a few shops that race the vehicles and they lead you into the right direction. i.e. VAC, Turner, Bimmer World or what were else.
My oppion: if you are not running the vehicle at a high RPM for a sustained period of time the stock parts will hold. Most ceeper/retainer failer occures due to a floating vlave.
Is there any other real input out there!!!
