| Depends - many will argue that a small, factory style turbo setup will last just as long as stock, due to modest power output resulting in minimum component stress and strain etc. You can probably consider a larger turbo w/ high output to be more strenuous because as the engine turns, there is a sudden increase in engine output, rather than a slowly ramped up output, which might suggest strain on rotating assemblies and causing shorter lifetime of components. But, I have a very high mileage large turbo setup and I have nothing but an oil leak coming somewhere from the front of the engine. As long as you are not sacrificing engine reliability with tuning (tune it wet on fuel) and such, then it should be reliable.
| Numbers I use for my 6G72, 400-500 HP, 17-23 psi boost, 8:1 compression, daily driver: I fully expect 120K Mile between top end jobs, at least 150-200K between bottom ends if nothing breaks. Only reason I freshen up the top end early is because leaking valve stem seals can lead to knocking which will kill a bottom end. I check and replace main and rod bearings at 120K, because my oil pan is dropped then anyways. I don't cut cranks because mine if forged, too risky, I just replace them if the bearing surface is FUBAR'd. That being said, on the race block I go by 100 hours for bearing check and cylinder borescope every 25 hours.
| 45 months and 7 days.
__________________ .-=[ Kenny ]=-. 1999 BMW M Coupe 10.775 @ 134.35 mph w/1.600 60' (Best 136.07 mph). Watch my drag racing movies. |
| keep the boost low and dont rape the shit out of it and you will end up with just as much mileage as you can handle.
__________________ "Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you." 'is she fucked or is she proper fucked?' 'shes proper fucked' 'ahhh fuck' |
