| Just had a car do the same thing; and it was the water pump... Do you have anything squeaking like the sound a bad bearing on a pulley makes? If so - I'd guess it's the water pump. That is - after you bleed the system properly... air bubbles can cause this; so can not having enough coolant; so check your fluid levels too... Then replace the water pump. ![]()
__________________ ![]() [Ethan "if it weren't for that cone" Connor | 99 M3 #89 BS] |
| Yeah the fan works, I think that it's a "auto" bleeding system (euro spec car...) but even if not, that fluid was replaced at bmw so i guess they did bleed it... i'll go for the water pump and let you know... thanks ! ![]() Tom |
