Old 05-29-2007, 02:18 AM
Rides:328i turbo- subaru sti
328B is a New Registered Member
e36 328 turbo?
Hey guys,
been sometime since i was on this forum, i've been modding my scooby but miss my BM
so here is the question, i have a 328 that had a turbo but it blew up, the rebuild is now on and i am looking for a turbo to push 300wkw and about 500nm , what can you guys suggest.
thanks
Ryan
Old 05-29-2007, 06:32 AM
itsabimmerthing's Avatar
Anti-bandwagon
Rides:Soon a bimmer
Always get good engine management, and a good tune..... A good tune, fuel delivery, and proper afrs are soooo vital to boost. Matching a turbo/intercooler as well as an efficent exhaust mani is also very important.
Old 05-29-2007, 07:04 AM
the motor didn't blow up the first time from tuning, it was because of the wrong gasket and when it burnt through the gasket it went through the ally block.
i had a t4 turbo on there and it made good power, but i want something a little more. and i also want to rev to about 8000rpm.
Old 05-29-2007, 07:48 AM
Anti-bandwagon
Rides:Soon a bimmer
A good set of gaskets, bolts etc makes a huge difference lol, and unfortunely left you fucked. I would personally get some forged internals, a good HG, bolts, a GREAT tune, and lots of fuel. I would defintly have it dyno tuned..... The difference between running a good time, and going home in a flatbed is how well you setup your car. If you want an 8k rpm redline,m that shouldnt be a problem at all. They do damn near that stock, correct? Make sure your exhaust system, ignition, and fuel system are on par for what you want to do. I personally will be doing an M52 up myself, using a GT40R, and all of the stuff I mentioned. Good luck with your build.
Old 05-29-2007, 08:04 PM
MrBlonde's Avatar
I got a parcel here!
Rides:BMW M Coupe 1999
MrBlonde has achieved their Master LicenseMrBlonde has achieved their Master LicenseMrBlonde has achieved their Master LicenseMrBlonde has achieved their Master LicenseMrBlonde has achieved their Master LicenseMrBlonde has achieved their Master LicenseMrBlonde has achieved their Master LicenseMrBlonde has achieved their Master LicenseMrBlonde has achieved their Master LicenseMrBlonde has achieved their Master LicenseMrBlonde has achieved their Master License
Hello!
You don;t want to rev your 2.8 to 8000 RPM. A little more boost is better than a little more RPMs, especially on that engine.
300 rwkw ~ 400 rwhp so you're looking at a GT30R or larger.
With a small capacity engine I'd go for GT30R .. certainly no larger than GT35R .. keep your spool as nice as possible.
.-=[ Kenny ]=-.
1999 BMW M Coupe 10.775 @ 134.35 mph w/1.600 60' (Best 136.07 mph).
Watch my drag racing movies.
Old 05-29-2007, 08:46 PM
Defacto's Avatar
Rides:'88 M6, '57 507, '02 Z8, '07 750Li
Defacto is a Permit Holder
Yep, and if you are tuned well, in my opinion, there is no need to build your motor. A stout stock bottom end with a gasket should handle matters just fine.
Old 05-29-2007, 10:59 PM
Rides:95 M3 and 95 GT35R 332i
RogueM3 is a New Registered Member
OT, but Matt, can you check your PMs when you get a chance.
95 GT35R 332 and 95 Avus Blue M3
Old 05-29-2007, 11:51 PM
Originally Posted by MrBlonde View Post
Hello!
thanks, i think i will do that , what i find funny is that guy here is South Africa are running gt35 on there subaru's 2.0l talk about lag!
so what i am going to do is bore out the 2.8 to 3.0 and put a bigger gasket on it to drop the compression run a gt30r. looking to boost to 1-1.2 bar boost.
should the std internals hold , if i get a good tune? (p.s i have gone trough 2 scooby motors thanks to guys that don't know how to tune, so... i know how important it is)
thanks Ryan
Old 05-30-2007, 12:04 AM
The standard M52 internals, as well as the s50 internals, are easily capable of sustaining 1 bar and many have pushed the motors up to 1.2Bar without issue. The weak link in both motors are the rods, which though heavily debated, are said to be safe up to about 17psi (others have gone much higher to nearly 2 bar with the 2.8 rods, though I wouldnt call that a reliable boost level with a stock bottom end).
Old 05-30-2007, 11:20 PM
i heard that if you change the rod bolts on both those motors to ARP bolts, they should be fine. any idea if that true??
Old 05-31-2007, 05:47 AM
Anti-bandwagon
Rides:Soon a bimmer
That may be true, but in any event, it never hurts to do the build right, and get forged con rods...... Along with ARPs..... I would rather push 20psi through good rods, instead of limiting to 17 on OE.
Old 05-31-2007, 08:49 AM
how can i argue with that logic.
buy cheep ,buy twice!!
thanks for the help guys
Ryan
Old 05-31-2007, 09:12 AM
Anti-bandwagon
Rides:Soon a bimmer
Ryan
Good luck with the build, it should be a fun car!
Old 08-06-2007, 09:52 PM
cvilayphone's Avatar
Rides:BMW,E36,94
Region: Asia
cvilayphone is a New Registered Member
what manifold do you guys perfer using?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517
