| Engine Management Hi, I'm planning on buying an m coupe (with the S50B32 engine, with the RGMotorsport supercharger kit, and headwork...) it has the dastek unichip on it... and people can't tune it right for some reason.. the idle is allways rich, and the car feels choked... considering that i wanna keep the double vanos, what engine management should i use? should i get a stand alone or a piggy-back system? thanks, Tom |
| Here's the deal. TEC-IIIR will not control DVANOS. The new box that AEM developed for HPF in the E46 M3 will. You can also contact certain companies, such as Discovery Automotive, for a custom tune of the stock DME. Also, MoTeC makes units that control DVANOS. However, they are rather expensive and difficult to implement, but when they are done, they are top notch.
| Talk to www.bavariacars.com.au about an Infinitas kit ..
__________________ .-=[ Kenny ]=-. 1999 BMW M Coupe 10.775 @ 134.35 mph w/1.600 60' (Best 136.07 mph). Watch my drag racing movies. |
| The S50B32 only has vanos on the inlet side (european motor right?), It is a high pressure system running at 100 bar. It is a pauls with modulated signal. The S54B32 has the vanos on the inlet and exhaust side. 100 bar and a modulated signal. IF it is a Non EVO S50B32 it would be a low pressre system that is an on/off switch that changes cam timing 12.5 deg. of advanve on the inlet side only. Currenlty running a non EVO S50B32 with a tec3 and I thought that my vaons was coming on, I may be "high" so I'll check and let you know. TWS |
S50B32 is DVANOS; Double VANOS continuously variable valve timing on both intake and exhaust strokes. The term "evo" is a marketing term used by BMW UK to distinguish the 3.2 litre S50B32 engine from the 3.0 S50B30. There is no such thing as a "non EVO S50B32", however the S50B30 only has VANOS on the intake side (continuously variable). The S50B30 USA engine (3.0 litre US M3 engine) has the two stage VANOS .. not continuously variable. This means the on/off postions. It's an M50 with a few tweaks, not a real "S" series engine.
What may force you to a standalone is if the DME cannot handle the parameters an FI engine throws at it. In this case a piggyback setup in conjunction with the DME can be a good solution. By the time you go standalone you're close to saying it's no longer a street car.
