Yeah I know but I have done everything up to pulling all but one bracket off and trying to angle the blower closer. |
| try to get a mechanic who knows superchargers to put it on? worth paying someone and watching so you can do it next time.
__________________ "Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you." 'is she fucked or is she proper fucked?' 'shes proper fucked' 'ahhh fuck' |
Gates number K060551 length - 1415mm/55.7" You can order it on line from rockauto.com. When you get there, select 'part number search', and enter in the gates part number. Its about 9 bucks. Theyre very reliable; I always get my belts from them. ***EDIT*** My bad.. I hadnt noticed you were using an 8 rib belt. The info I gave you was for a 6 rib belt. I apologize. However, there still is another belt from gates you can try in an 8 rib config if you still need it.. this one is 3/8" shorter than the 560 which is listed by Rock Auto as being 56.625. Its the KO80558 and its listed with a length of 56.25. I know the lengths in inches they give are different than what you posted, but even so, looking at the numbering sequence, the one I found for you will be shorter than the 560 which you found too long. good luck.
__________________ Paul E '99 White M3 71k mi; Dinan SC kit, 6"/3.48" sc pulleys, Aftercooler: 10.5 psi-367 SAE rwhp/304 rwftlbs @80 degrees ambient (still with OBDII manifold); DynoTuning by Nick G (techniquetuning.com); Speed Shop: Imported Cars of Stamford; AA-Aquamist Water Injection, exhaust; Fikse FM-10s; Koni Suspension; Stealthboxes http://photos.yahoo.com/boostm3 ![]() Last edited by paul e : 07-03-2007 at 04:44 PM. |
