Old 06-13-2006, 11:29 PM
Proctor750's Avatar
Ex M5 driver
Rides:bmw, M3, 1995
Proctor750 is a New Registered Member
Intercooler size question
Im looking for Intercoolers for my E36 M3. Im not sure what dimensions will fit, Im just buying a core, and the shop is doing custom endtanks to fit. I have the stock M3 bumper, and splash guards, just wanted to know what dimensions will fit. (dont feel like measuring)
Old 06-16-2006, 07:58 PM
eurotekM3's Avatar
meh......
Rides:95'BMW M3/ 01'AUDI S4
eurotekM3 is a New Registered Member
Old 06-17-2006, 12:05 PM
Proctor750's Avatar
Ex M5 driver
Rides:bmw, M3, 1995
What fits under the stock bumper...
Old 06-18-2006, 04:52 PM
Highboosting///M3's Avatar
Rides:'97 M3T, '95 Supra, '03 Hummer
Highboosting///M3 is a New Registered Member
Largest core I have seen anyone fit is 24x12x4 but that is overkill and you do have to slightly modify a couple things to fit it. Not sure on your hp goal but I would say 22x10x3 is fine for up to 700hp or more and it should fit no sweat. My last intercooler core I had on the car was 24x10x3.
I like big boost and I cannot lie, you other brothas can't deny, when the turbo spools at a violent pace and there's a crazy look on your face you get sprung! Deep in the vein the adrenalines flowin', I'm hooked and I can't stop boostin', oh ladies yeah ladies yeah this aint no f-in Mercedes, so turn it up, floor it out, even S/C guys got to shout, baby got boost! You can keep it sleeper or show, but please don't lose that boost!
(written by Cameron Vongschlong 7/17/08)
Full Gallery Showing Stages From Bought To Current Brock Lesnar is now the UFC Heavyweight Champion of The World! He is superhuman!
Old 06-18-2006, 05:47 PM
dummerdork's Avatar
Banned
Rides:my car
dummerdork is a New Registered Member
sounds good
Old 06-18-2006, 08:45 PM
Rides:bmw, 328i, 1996
1996328iAbalos is a New Registered Member
There's a guy named J.P. that used to have a 700+hp bmw m3 here in Las Vegas before his engine blew to shit in one month period after coming out of pprauto.com - www.pprauto.com but it wasnt there fault something else was wrong but 24x12x4 intercooler was what he was running but the thing is with that size he actually had to literally cut the lower portion of his bumper & did some banging on his bumper to make it fit just right.
Old 06-18-2006, 08:46 PM
Also whats your specs on your E36 m3?? Looks good from the rear but i wanna see more, yes more.....!
Old 06-19-2006, 01:48 AM
SaLto's Avatar
Rides:BMW M5 E34
SaLto is a New Registered Member
Question
About the positioning of the intercooler, if i wana put another aditional intercooler maybe can make a air flow separator ,dimensioned in the relation of the two intercoolers volume size, for two intercoolers from the turbo and fitt the aditional on the side off the car or maybe under the hood iff its thiner, and make some scoops to let moore air flow, than a air flow joiner right befotre the intake mainfold?
What doo U think about that?
It iss a bit looney but actualy can work if its done propertly!!!
Doctor!
Old 06-19-2006, 06:40 PM
Usually the only time people use twin intercoolers(one on each side) is because of the way the bumper is or since there is a lack of space in front. The G35 usually calls for twin small intercoolers since the front center mouth of the bumper is thin but the opening on the sides are larger for more air flow. Also this makes piping easier for twin turbo cause the pipe can come straight from compressor a short distance to side IC and out up to merge in the middle for the V6 intake in the middle.
Corvettes also usually have side intercoolers cause there is more room near the tires and because of twin turbo and it being a v8.
Top mount IC is usually just for rally cars with a big scoop but when going for big power they always scratch that location and do front mount with a large IC since it has the room.
So with an M3 the conventional FMIC is best location for sure for piping route, room for placement, air flow and everything!
Specs are top secret for now.
Basic info:
Semi-custom widebody
Fully built race motor = I6
All custom piping and manifolds
Rather large turbo
Tec 3R PnP from Vic Sias and tuning by Vic Sias
335 equivalent tires in rear.
Old 06-20-2006, 09:09 PM
Vader
Rides:BMW M3 1995
8psi//E36 is a New Registered Member
Basic info:
Rather large turbo
Pics + NWS or ban
Always the best with you Cameron, keep up the great work.
///M3DarkSide: You know this will be on "Wildest Police Chases XXII" or some shit like that. It will say, "After barreling down the road like a bullet through a gun, this dirt bag has the nerve to pull over and smoke a cigarette. But before he can hop back in his speed maching to grab his uzi so he can start popping caps, an officer pulls up to give him with a fist full of justice. This is the last joy ride this speed freak will be taking for a while after they give him a list of charges that reads like a shopping list."
Current project:
1995 //M3 - 2 door, 5 speed - Cosmos Black
- Rogue engineering shock tower mounts
- UUC street / track transmission mounts
- JT-Designs aluminum underbody paneling
- Active Autowerke 3" intake
- Active Autowerke differential support bracket
Stockish for now, and love it
Old 06-25-2006, 08:56 AM
itsabimmerthing's Avatar
Anti-bandwagon
Rides:2004 M3 vert, manual
This is a DSM trick, I am not sure how BMW owners will respond, but here goes:
You can cut the bumper support on the car, and hack the front bumper. If done properly, it does actualy look nice, and not like you would think. It is easy, and as I said, if done right, looks sweet. And will allow for a larger FMIC to fit. FYI the largest FMIC isnt always best anyway. You have to look at how efficent it is. A higher efficent smaller FMIC is better than a larger FMIC with the opposite efficent numbers. Look at PSI loss@60mph. If it is efficent, you will have a great core. Just something to help you make an informed choice.
2004 M3 vert, 6 spd
HPF 2.5 turbokit on the way
Old 07-27-2006, 11:40 AM
EricBMW's Avatar
Boosted
Rides:95 M3 Turbo | 89 525i
EricBMW is a New Registered Member
Two ords to consider
pressure loss
1995 BMW M3 - Dakar/Black
Bimmerwerkz
Old 01-07-2007, 09:14 AM
Proctor750's Avatar
Ex M5 driver
Rides:bmw, M3, 1995
will 20x11x3 fit under a stock bumper?
Old 01-12-2007, 02:35 PM
Probably but if you want any intercooler that is taller than maybe 6 inches to fit up close to the mouth, you will need to either cut the bumper support or remove it like most people do.
Old 06-08-2007, 01:10 AM
Pichuhn's Avatar
Rides:BMW, 325I
Pichuhn is a New Registered Member
Looks Good Right (32x12x3)
Video - Crazy Dado's Drifting
325I A Turbo Project
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
