| What turbo to run I am building a custom Turbo kit for my 95 M3 and am looking to make about 300 Hp and run around 8 psi. What turbo would anyone recomend to use? I also need it to have a internal wastegate on it.
| http://www.turbobygarrett.com/turbob...on/catalog.pdf this is the garrett turbo catalog. it has the proper displacement and rough hp ratings for each turbo. makes it easier to select the right one.
| It should give you about 300 rwhp. I'm nto sure on the efficiency range but assuming it's in the right range a GT28R would defintely give you what you want. ALso a t60-1 would leave room for improvement. |
__________________ 97 Arctic Silver M3/2 AA Stage II w/ GT35r NickG tuning w/o cats @ 15psi 425/443 on Mustang Dyno ![]() 91 Alpine White 318i *daily driver and constantly under construction* |
| 20g all the way. After a while 300whp will get boring and you want to boost it up more....trust me.
__________________ 05 WRX Mods: Cobb AP - Cobb Catless DP - Helix UP - Invidia N1 Race Catback - Kartboy Short Shifter - Kartboy Shifter Bushings - Perrin I/C Hoses - Perrin Radiator Shroud - APS Short Ram - Perrin Turbo Inlet - FP Big 16G Turbo - TurboXS TMIC - SARD 650cc Injectors - Walbro 255lph Fuel Pump. Protuned - 293whp / 282wtq Meth Injection and EWG to come.... |
| I would go larger than a 20g...either a T60-1, GT30r or GT35r....trust me, if you are going to do this, do it right and go big now so that upgrading won't cause you to go to a whole new kit....you'll thank me.
__________________ PS - This is what part of the alphabet would look like if Q and R were eliminated. - Mitch Hedberg RIP |
Iff u find that 300hp suits u than doo the work!
__________________ Doctor! |
-Hoots |
| He was being a little sarcastic....or having a blonde moment.
| Ok, he didn't say if he wants more, also a 20g internal gated is not a great idea... If you want more, take my advice and run a holset hx40.. IMO a 20g is not worth the money, I could think of 10000 turbos cheaper, flow more air, and more potential...
__________________ BMW The three most powerful letters in the alphabet |
