Old 03-31-2006, 06:31 PM
Proctor750's Avatar
Ex M5 driver
Rides:bmw, M3, 1995
Proctor750 is a New Registered Member
Turbo Setup question
So im getting Haltech for my fuel management for my 95 M3, and a shop nearby will fab me up a manifold. But as for the turbo, i was looking at either the Holset Hc1 or Hx35 for my car. which would suite my car better with stock Internals? and with that what kind of psi would be safe? I think compression on a 95 M3 is 10 to 1??
Old 04-07-2006, 08:09 PM
Highboosting///M3's Avatar
Rides:'97 M3T, '95 Supra, '03 Hummer
Highboosting///M3 is a New Registered Member
10.5:1cr. And hardly anyone(especially outside of Sweden) are familiar with holset turbos. It's usually Garrett, Precision, ITS, Turbonetics... If you know what mm the compressor inducer is and what size the turbine housing is(a/r and T3 or t4) that would help.
I like big boost and I cannot lie, you other brothas can't deny, when the turbo spools at a violent pace and there's a crazy look on your face you get sprung! Deep in the vein the adrenalines flowin', I'm hooked and I can't stop boostin', oh ladies yeah ladies yeah this aint no f-in Mercedes, so turn it up, floor it out, even S/C guys got to shout, baby got boost! You can keep it sleeper or show, but please don't lose that boost!
(written by Cameron Vongschlong 7/17/08)
Full Gallery Showing Stages From Bought To Current Brock Lesnar is now the UFC Heavyweight Champion of The World! He is superhuman!
Old 04-13-2006, 07:32 AM
Rides:NA
esirtype? is a New Registered Member
First off, forgive me, I am not as of yet a BMW owner. I found this board while researching a BMW 325i convertible I plan on buying. I am a gear head and have been all my life. I have the intent of turboing this 325i if I buy it.
Now the reason I'm really posting here is due to the "Holset" comment. I have done a lot or research on the Hx-35 and HY-35 turbo. Try this link,
http://www.dsmtuners.com/forums/show...&page=24&pp=25
There are some generic compressor maps on the first page (if the link is still good).
Holset doesn't release their maps either.
I am running a HY-35 on my project MPI, Mitsubishi Starion (custom header, build by me and Megasquirt fuel and spark management). I really love the turbo. The G54B engines in the starquest are know for their terrible head flow with the SOHC. So I choose a hy-35 off a 2002 Dodge diesel. The turbo is a great choice for my setup. It has a small hotside and spools very fast on my unported head. Even when I ran the turbo on the TBI it spooled great for me.
Now the hx-35 has a large hot side and will max out at about 40psi, VS the hy's 30psi. However this is some serious CFM (from what I remember at 20 psi on the hy-35 was in the 750+ cfm range). I've seen the hx-35 and 40 turbo on some 2.0l eclipes engines and they are laying down 450+ whp at around 25psi.
The holset turbo is very effiencet. Like I said, I'm very happy with it. Some say it will out perform a gt-35 turbo.
Now to the BMW and holset question. The HC-1 is an older turbo, the Hx-35 would be better for you. However, I strongly recommend not using this turbo on stock internals. The reason is, these turbos are in the beginning of their effiency range at around 15psi (with 7.5:a cr). This is where I'm running it for the time being on my Starion, till I upgrade the head and head gasket. I have run it at 8 PSI, and it's no good there. From what I read, 9psi is about the safest you can go on a stock engine (s50). I am not sure on the m3 engine, but I think you're asking for trouble running a lot of boost on a stock engine, especial with 10.0:1 cr. That kind of compression is a low boost, engine. High CFM is fine however. A turbo that would probably be better suited for you would be a 20g, which have been found on Mitsubishi Fuso trucks and can be bought inexpensive at the right place. That turbo is good to about 20psi, will will do fine in the lower boost area. Another option would be some sort of t4 turbo. Something with big CFM at low boost.
I will say, my HY-35 will hit 15psi by 2700-2800 rpms, and with some headwork will be quicker. But from 0-7psi, it boosts a tad slow, past 7psi, the boost come VERy quickly!
But again, having researched these turbos, and having experience with them on another car, I don't feel this is the right turbo for a stock internal BMW, with such high compression. It's a recipe for disaster.
Let me konw if you have more questions on the turbo, I'd be happy to share with you what I know.
I personaly haven't choose a turbo yet, for this project (provided I get the car). I've seen some kits, using a t25, which is small. However, the turbo manifold only uses 3 of the 6 cylinders. I will be doing everything myself, as I always do. An intercooler will be included. As far as fuel management, I'm not sure yet, I'm still researching.
Shawn
Old 05-10-2006, 01:09 PM
mattytm3's Avatar
Rides:95 BMW M3 Turbo , 03 Nissan 350Z TR Edition
mattytm3 is a New Registered Member
I know some one from ICSperformance who runs 18psi on stock internals on a325 with 600whp.
Old 05-10-2006, 10:45 PM
GDO GDO is offline
Rides:bmw m5
GDO is a New Registered Member
im not sure, but i think he was referring to keeping the compression ratio stock though
Old 05-11-2006, 03:44 AM
mattytm3's Avatar
Well , I know of the car I dont personally know the owner. I am pretty sure he is on this forum. The car might be on their web site but any how I think all internals are stock with the great ICSperformance custom turbo fabrication thrown in there. He claims he takes it to the drag strip every weekend when weather permiting.
Old 02-25-2007, 02:24 AM
Proctor750's Avatar
Ex M5 driver
Rides:bmw, M3, 1995
It turns out I got the Hx35, and have decided to lower the compression via a .140" head gasket. Autronic will be the engine management, and I have FMIC with back door setup. I still haven't had everything installed, but I think with the head gasket the compression will drop enough to use the HX35 at efficiency. Im pretty sure the HX35 and the GT35 are extremely close in comparison, and a friend of mine is running a GT35 with stock internals and thicker head gasket on his M.
Old 02-25-2007, 07:31 AM
Rides:Many Turbo BMW's 1025rwhp currently..
Imported Cars has obtained their Street LicenseImported Cars has obtained their Street License
The vehicle was built by us, the guys name is Ulysses, screen name Cardcounter. His best run on a M52 2.8 liter 328i 4 door on drag radial was a 10.7 @ 136 + mph on a stock internals with over 100k miles obn the motor low compression VIA H/Gasket. The motor bent a connecting rod @ 704rwhp, his new set-up is a fully built 2.8 and has made a hefty 996rwhp on stock camshafts to date. We did install largers cams and tried to dyno it although as soon as the turbo reaches its efficiency it destroys every clutch set-up that we have installed. Ulysses is awaiting a triple disc set-up before the vehicle get re dynoed on high boost and before it see's the track. Great things to come this year.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
