Old 03-17-2006, 07:57 PM
5150CT's Avatar
European Mafia
Rides:E30325is, E36332is, E46M3, & 911 Turbo
5150CT is a New Registered Member
What engine management?
What is the most cost effficient engine management system? I'm trying to decide between the evosport modified AEM unit or the tech 3 system. The car has a 3.2 drivetrain and it's going to have a turbo on it?
"It's better to be hated for what you are, than to be loved for something you are not!"
Old 03-17-2006, 08:28 PM
Highboosted's Avatar
Road Race or Die
Region: USA - Great Plains
I've seen what the AEM EMS is capable of, and I am a BIG fan of it. (yes, I know you guys dont get the plug and play EMS....)
I worked with the TEC II, and if the 3 is anything like it, it should also be a good system, but given the choice, I would choose the AEM for my car....
Join NASA, too!!!!!
Old 03-20-2006, 03:11 AM
EricBMW's Avatar
Boosted
Rides:95 M3 Turbo | 89 525i
EricBMW is a New Registered Member
Tec3 is a proven system and works well. As mentioned the AEM EMS is great too. Also noteable is Haltech e6x
1995 BMW M3 - Dakar/Black
Bimmerwerkz
Old 03-27-2006, 07:46 AM
Rides:BMW, M3, 1995
Keener is a New Registered Member
the e6x is a fuel and ignition comp, so my question is does it control factory features like vanos? or can you piggy back it to the stock unit?
Old 04-10-2006, 08:45 PM
justindd911's Avatar
Ghost
Rides:BMW 528i/Lexus Sc300 Turbo
justindd911 is a New Registered Member
AEM EMS
Lexus SC300 Turbo
BMW E39 528i Sport
Old 04-11-2006, 04:24 PM
Rides:bmw,m3,97
x2dg is a New Registered Member
i would like to kno that too.
Old 05-04-2006, 08:59 AM
sjle11789's Avatar
night rider
Rides:2002 330xi , 1985 318i
sjle11789 is a New Registered Member
when installing the new ems do you remove the stock computer? Is a new ems necessary for a moded car?
BMW all the way!!!
Old 05-04-2006, 10:37 PM
Road Race or Die
EMS replaces stock computer, though you might need your computer to run some things (My car has separate computers for climate and alarm, ect). You'll lose VANOS if you lose your computer, AFAIK.
EMS just has sooo many options and controls. When tuned right it will run smoother than stock.
Join NASA, too!!!!!
Old 05-05-2006, 07:57 AM
E30TRBO
Rides:1989 BMW 328i
Cost depends on how much you can do yourself as well. Megasquirt or VEMS are the least amount of money for standalone systems. Megasquirt can be set up for under $500, and Vems can be set up for under $1000. Both can control any injector size, multiple inputs and outputs. Vems has a built in WBo2 circuit, requiring only the $35 LSU4 WB sensor. Very capable if you can do it yourself, or know someone who can install (wire and tune) for you. I use megasquirt, and have installed on a few other vehicles as well, very capable.
http://www.megasquirt.info
http://www.vems-group.org
matt
Old 07-15-2006, 05:38 PM
333m3nut's Avatar
go fuck yourself
Rides:BMW M3 1996 S/c Tech 3 custom tuned 385rwhp
333m3nut is a New Registered Member
I run a tech 3 for my setuo and get 385 and 320 foot pounds of tourqe..It has worked great.my ac even works..I even maitain comftorable drivability.its almost as much who tunes it as what standalone u use..
Pat
Old 07-28-2006, 11:28 AM
Rides:BMW E36 M3
Cebola_1 is a New Registered Member
Whit Motec M800 you will not lose VANOS!
http://www.kempower.be/NEWS/bmw_petrol_news.htm
VANOS control with MOTEC
We are proud to announce You that we developed together with Motec the software to control completely the continuous variable camshaft control of BMW VANOS systems on a M800
Old 09-22-2006, 12:18 PM
5150CT's Avatar
European Mafia
Sorry i took so long to reply. Multiple projects started at the same time is a really bad idea cost and time wise. I went with the Tec3 plug and play system with wide band 02 from Sias tuning as i noticed Dado did this aswell. I plugged it in and it didn't play! I talked with Vic, seems like he's trying to help me out, but it's been like 3 mo. of waiting to figure out why it's not working and i've lost all interest and patience in this project! I've been modding my e46 330ci and 930, cost, time, and enjoyment factor are much better with these projects.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703
