  #16 (permalink)
Old 04-12-2006, 12:57 AM
morerevsm3's Avatar
will race for food..
Rides:BMW M3, 1994
morerevsm3 has achieved their Master Licensemorerevsm3 has achieved their Master Licensemorerevsm3 has achieved their Master Licensemorerevsm3 has achieved their Master Licensemorerevsm3 has achieved their Master Licensemorerevsm3 has achieved their Master Licensemorerevsm3 has achieved their Master Licensemorerevsm3 has achieved their Master Licensemorerevsm3 has achieved their Master Licensemorerevsm3 has achieved their Master Licensemorerevsm3 has achieved their Master License
and ICS with 850+rwhp are only doing same traps as 450rwhp cars, dyno's are far too easily manipulated, trap speeds are not (for a given weight)
12.97 @ 105.98mph. high mph 106.48. best 60' to date 1.767
  #17 (permalink)
Old 04-12-2006, 07:13 AM
SWReedy's Avatar
Midnight Marauder
Rides:BMW M3 1997, KIA: 330CI
SWReedy has achieved their Master LicenseSWReedy has achieved their Master LicenseSWReedy has achieved their Master LicenseSWReedy has achieved their Master LicenseSWReedy has achieved their Master LicenseSWReedy has achieved their Master LicenseSWReedy has achieved their Master LicenseSWReedy has achieved their Master LicenseSWReedy has achieved their Master LicenseSWReedy has achieved their Master LicenseSWReedy has achieved their Master License
I'm not looking to make any more than 450-500rwhp.
E36 S52 Turbo project under way
330CI = KIA July 21, 2006...Klauss, you will be missed.
*Find something worth dying for, and live for it.*
  #18 (permalink)
Old 04-16-2006, 02:59 AM
Rides:95 BMW M3
yellowm3turbo is a New Registered Member
i may be putting a gt35r on my car here soon. i have a 9:1 compression ratio via head gasket and im getting a externally wastegated mainfold. im not sure if i will run into any problems. but i can keep you posted about my results
  #19 (permalink)
Old 04-16-2006, 07:56 AM
Mpower///_tyron's Avatar
M///
Rides:e36 325is
Mpower///_tyron has achieved their Master LicenseMpower///_tyron has achieved their Master LicenseMpower///_tyron has achieved their Master LicenseMpower///_tyron has achieved their Master LicenseMpower///_tyron has achieved their Master LicenseMpower///_tyron has achieved their Master LicenseMpower///_tyron has achieved their Master LicenseMpower///_tyron has achieved their Master LicenseMpower///_tyron has achieved their Master LicenseMpower///_tyron has achieved their Master LicenseMpower///_tyron has achieved their Master License
Isnt 9:1 compression a little to high for a turbo?
  #20 (permalink)
Old 04-17-2006, 03:45 PM
SWReedy's Avatar
Midnight Marauder
please do any input would help, though I think I'm just going ahead and jump right into creating the set up as soon as the car arrives. my engineer friend and I have been plotting for weeks.
  #21 (permalink)
Old 04-22-2006, 12:11 PM
Vader
Rides:BMW M3 1995
8psi//E36 is a New Registered Member
The GT35R would / will be a great, GREAT turbocharger to go with for an immediate 500+ hp setup (Crank hp) at 14psi. George (ICS Performance - www.icsperformance.com) - cando great things w/ tuning the car to run reliably and make 480 rear wheel at 14psi if you're really interested in going that route. I believe Nick G. (Technique Tuning) - www.techniquetuning.com can do the same for you as well but usually only installed a Turbonetics 60-1 (Powerful as well).
Personally, anymore I've decided to go with the Turbonetics 60-1 w/ ball bearing as an option to make 450 at the wheels and just try to max it out before going w/ anything bigger.
The GT35R can be an amazing setup as well on a stock bottom end but if you ever want / wanted more power out of it you will HAVE to upgrade internals unless you've got a spare S50 / S52 collecting dust in your garage. If you want 450 - 500, would that be at the motor or at the wheels? If you mean 450 at the wheels, as I've said the Active Autowerke's kit's will make that, but only if they're basically "maxed out" and they're way overpriced for my tastes ($7,500 - $10,000.00) and that doesn't include any drivetrain upgrades like a clutch, flywheel, mounts or anything else of the like, just the kit itself and no - NO labor included in that price for that matter. For whatever it's worth as well, I had the stage 1 OBD2 gen 3 kit from Active on a 99' M3 I used to own and it made a whopping 296.5 at the rear wheels at 8psi w/ about $3,500.00 in supporting bolt on and internal mods. It was fast(ish) for the street but I was lucky to ever make that power reliably. I had so many problems with that kit which led to me selling the car and realizing the install they did on the car was HACKED and they're not worth dealing with in my opinion.
The Mitsubishi (Active Autowerke) TD06H 20G setup is good for about 400hp / tq. at the crank on it's own (Maxed out) and good for over 425 at the rear wheels with the 60-1 front end which will run you about $1,550.00 from what I understand (For the 20-G / 60-1 hybrid). This setup is again good but will not spool nearly as well or make the same kind of usable power as the GT30R / GT35R or the Turbonetics 60-1 + / - ball bearing turbochargers would / will.
I only wish the GT30R wasn't so much $$$ or I'd just go with that, Cameron made some silly numbers with his 30R setup. I believe he made a little under 500 at the wheels (450hp / 474 ft.lb torque) at around 14psi? Don't quote me on those exact numbers but it was very similar what he made w/ his GT30R and a custom T3 Stainless exhaust manifold www.danzioperformance.com
I hope this clears some questions up? If not pm me, I'd be interested to hear about what kind of setup you have so far w/ the car you're building.
///M3DarkSide: You know this will be on "Wildest Police Chases XXII" or some shit like that. It will say, "After barreling down the road like a bullet through a gun, this dirt bag has the nerve to pull over and smoke a cigarette. But before he can hop back in his speed maching to grab his uzi so he can start popping caps, an officer pulls up to give him with a fist full of justice. This is the last joy ride this speed freak will be taking for a while after they give him a list of charges that reads like a shopping list."
Current project:
1995 //M3 - 2 door, 5 speed - Cosmos Black
- Rogue engineering shock tower mounts
- UUC street / track transmission mounts
- JT-Designs aluminum underbody paneling
- Active Autowerke 3" intake
- Active Autowerke differential support bracket
Stockish for now, and love it
  #22 (permalink)
Old 04-22-2006, 03:55 PM
Rides:Many Turbo BMW's 1025rwhp currently..
Imported Cars has obtained their Street LicenseImported Cars has obtained their Street License
You must be very far mistakin, I have made 977rwhp on a car than has not seen the track. The 2 cars that have seen the track have both over 100,000 miles on them, stock internals low compression via headgasket, factory tuned ECU. 1 is a 328i 4 door 2.8 making 635rwhp, runs 10.78 @ 136.79, on DOT street tires, and the other is a 95 m3 stock internals, low compression gasket running 10.90 @ 136.52 on 18 inch street tires, this car has not been dynoed yet, the 2.8 has a 35r turbo. Both cars will soon see low 10's upper 130's low 140 trap speeds, over the next few weeks. (Factory tuned ECU)
  #23 (permalink)
Old 04-22-2006, 07:52 PM
Vader
Rides:BMW M3 1995
That's what I like to hear
Current project:
  #24 (permalink)
Old 04-22-2006, 08:09 PM
SWReedy's Avatar
Midnight Marauder
I'm looking for a very reliable and streetable set up that'll get me 400whp and about equal wtq. I think I'll be contacting Danzio, unless anyone knows of a better west coast shop / tuner
  #25 (permalink)
Old 04-23-2006, 01:49 AM
Just call Nick @ Technique tuning, www.Techniquetuning.com buy his off the shelf stage 2 you will be more than satisfied with it, up to 450rwhp and over 400rwt, best bang for the buck. Good luck.
  #26 (permalink)
Old 04-24-2006, 08:13 PM
Highboosting///M3's Avatar
Rides:'97 M3T, '95 Supra, '03 Hummer
Highboosting///M3 is a New Registered Member
anyone have any experience or data with the GT35R on an OBDII E36 M3?
There are plenty! It's teh most popular turbo among e36 guys next to the To4b HiFi.
Go here! Lots of tried and tested guys under the GT35R turbo!click me
stock e36 m3
  #27 (permalink)
Old 04-24-2006, 09:16 PM
Thanks for that.
I am the Cameron he is talking about. I actually built the website for Chris(DanZio owner) for free because I like him and want him to succeed. He built me an incredible setup. Here is a link that tells all about that setup However, I need to know what you want to spend. I made good power because everything was custom and a Haltech e6x standalone with harness was used. Now, he has made a more conventional custom setup for kaliboy that utilizes the Turbonetics manifold. He made 518whp at 20psi on stock internal 2.8L(328) 8.9:1CR via thicker headgasket and GT35R. That was also with standalone. Of course standalone will cost more but if you are willing to pay more, you can have really cool things like anti-lag, a switch to go from a pump fuel map to race fuel map when you want to fill up with race fuel...and it will be easy to retune if you ever want to change to a larger turbo and larger injectors.
Again, please click on this link which shows a list I am working on to help guys exactly in your position! click here to listen to people who have tried many different BMW FI setups!
Cameron
stock e36 m3
  #28 (permalink)
Old 04-24-2006, 09:35 PM
islasian67's Avatar
Rides:1998 BMW M3
islasian67 is a New Registered Member
good thing this thread came up, a friend and i are having thoughts of going with the gt35. speaking of the gt35, with the right tuning and set up, will it run well through circuit tracks?
  #29 (permalink)
Old 04-24-2006, 09:47 PM
Did you click on my link above? It's a list of people that have used many different BMW FI setups and turbo combinations. You can learn from their experiences and see their results.
stock e36 m3
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258</
