| Smoke..... For some reason only when I start the car in the mornings and drive it, I start to see and smell this smoke coming through my vents. It didn't start happening until I put the SC on and it seems to only happen at idle. Almost smells like a burning clutch. I know the technician that helped me sprayed a lot of cleaner stuff in the engine bay so I was thinking that might be it. But it if it was a clutch, why would it be burning up at idle with the clutch not engaged? Any help would appreciated. It also seems to only happen before the car has warmed up.
__________________ - 97 M52 Beast - Vortech V-1 Supercharger Setup - Dinan Software - 28.8lb Injectors - 5psi going to 8psi - ZKW's - OEM Clears - DoubleSpoke II's - OEM M3 Spoiler - OEM M3 Front Bumper - 20% Tint - CCFL Angel Eyes - 6K Xtec HIDs in ZKWs - 6k H1 based D2S HID's in Foglights - Bilstein Sport Shocks - Eibach Sportline Springs - Cosmos Racing CAI - M50 Manifold Swap - UUC Motorwerks SystemU Exhaust - Fan Delete - 3.15 LSD - Last edited by bimmerboy328i : 02-06-2006 at 07:26 AM. |
| What did he spray the motor with?
__________________ ![]() |Eurowerkz|UUC|Sparco|UmNitza|SSR|Schrick Cams|Conforti| http://www.dtmpower.net/forum/showthread.php?t=169417 |
| Well it actually wasn't from the brake cleaner spray. After work I had more time to check it out and it was a leaky valve cover gasket. Was dripping on the exhaust manifold and burning then coming through the vents. Minor problem, and I already took care of. Man that was a nasty valve cover gasket.
__________________ - 97 M52 Beast - Vortech V-1 Supercharger Setup - Dinan Software - 28.8lb Injectors - 5psi going to 8psi - ZKW's - OEM Clears - DoubleSpoke II's - OEM M3 Spoiler - OEM M3 Front Bumper - 20% Tint - CCFL Angel Eyes - 6K Xtec HIDs in ZKWs - 6k H1 based D2S HID's in Foglights - Bilstein Sport Shocks - Eibach Sportline Springs - Cosmos Racing CAI - M50 Manifold Swap - UUC Motorwerks SystemU Exhaust - Fan Delete - 3.15 LSD - |
| After replacing the valve cover gasket, I still have an oil leak. I don't know if I blew the new one or what, but I still have some kind of oil leak around in that area. I do not believe it is a headgasket, and the oil does look like it's coming from up top near and around the valve cover gasket. I have not pulled the engine cover yet to see if there is oil in the plug holes, but I don't believe there will be since I just replaced those.
