| Turbo Charger on 325i ?? Hi All.. am planing to turbo up my E36 325i 1992 manual with toyota supra 7M standerd Turbo.. is it going to be danger if i run the turbo with my standerd engine (pistons) and how many boost can i run with it if it's possible, thanks regards MR.E36i |
| The 7M-GTE turbo wastegate spring it set at 7-8 psi (based on friend's 89 Supra). This would be good start point for a intercooled setup with proper fuel control and your ignition timing backed off a few degrees. You don't need a built motor to handle this pressure (several 10:1 6G72 motors run 10 psi intercooled). You DO need proper fuel control and timing control for it to be safe.
| i hear from a few different sources that an M50 2.5 can handle up to 15psi on stock internals safely..... anyone else confirm this...
| 15psi with a VAC headgasket ![]()
__________________ ![]() Turbo 325IS - GT40/82, M3 cams, 55# injectors, AA HFM, .140MLS , 20PSI For Sale: 413 DME red-label w/AA stg2 chip , 42# greentop fuel injectors |
How would you use this on a turbo? custom manifold?? |
| with a 92 you can hold boost a little better than the vanos 93+ motors. stronger internals and valve springs
__________________ ![]() -330is-540HFM-24lb-Cosmos 3.5"-Crack pipes-Remus Exhaust-TMS software-Samco 3.5" TB boot-LTW fly-Sport Clutch-and MUCH MORE! |
With a 92 2.5L M50, with standard internals and a MLS Head gasket, and the right tuning, you could get to produce about 15psi 350rwhp reliably... apparently the M50 2.5L are the best ones to boost up.... Correct me people if i am wrong?
