| its so easy to make a half decent equal length manifold im half way through an e30 325 turbo conversion havent hit any real snags yet heres a pic of my manifold its far from finished but shoud do the job i just used an old 6 branch manifold that i picked up cheap and cut it about abit ![]() are you intending to uprate your internals im part way through rebuilding my whole engine but as its a test bed im using standard parts with a thick copper head gasket to lower the compretion once im happy i know what im doing i will build another engine with forged internals amongst other things keep me updated mate on how your getting on |
| For the time being I'm going to stick with stock internals, a thicker head gasket, and a conservative boost level. However, I do have future plans for a full rebuild with forged internals. |
| look at this site its what got me started also if your after a decent manifold use the pro turbo link at the bottom of the page there maniolds look lovvvely http://webk.uk.ask.com/redir?u=http%...rl=&Complete=1 ( |
| Go with an equal lenght mani Quote:
This is Dan's design based upon, the Proturbo equal lenght mani in sweden. I would recommend this along with a forged 524td crank, and forged pistons for maxium boost. ![]()
| You can also use an adapter, such as the Proturbo adapter. Its a lot less than the full mani. This is my setup, I had to add the wastegate addition to it. More pics are on http://www.e30tech.com/featured/matt and http://www.mkosonen.com Turbocharging Dynamics sells a good log style manifold, probably the best flowing log for our car (compared to cartech and the 524td). I believe its around $600. If you know or learn how to weld, it will save you a lot of money in this stage. ![]() matt
matt
Tyron- I used a flux core wire feed welder (mig without gas) to weld the wastegate extension and most of my exhaust as well. I used tig for intercooler pipes and the exhaust tips, and gas mig for other parts of my exhaust. matt
