Old 08-22-2005, 04:18 PM
mattytm3's Avatar
Rides:95 BMW M3 Turbo , 03 Nissan 350Z TR Edition
mattytm3 is a New Registered Member
Exclamation tuning air/fuel ratio
I live in northeast CT and I can't find a dyno shop that is relitively close to where I live. I need to get my car dialed cause it runs lean at about 4 grand. If any body is from the area and knows a good shop to go to please help me out. I also only have a HKS super AFR so thats really all I have to work with.
Old 08-22-2005, 08:57 PM
Rides:06 M3, 97 M3
M3 Kid is a New Registered Member
ICS Performance in Stamford CT. www.icsperformance.com
Joe
2006 M3 ZCP Interlagos/Cinn.
1997 Dakar Yellow M3/2 ** FOR SALE **
Old 08-23-2005, 06:52 AM
BeRzErKaS's Avatar
Mobile Mammographer
Rides:'94 325is
BeRzErKaS is a New Registered Member
If there aren't any dynos in your area then why not just fix the problem yourself.
I'm guessing you already have a wideband02 since you know its leaning out at 4k. Can you log data? I'm using an SAFC-II but the HKS unit shouldn't be too different.
1) pick your rpm points above 4k
2) turn the knob to the RICH side
3) check your datalog to make sure your curve is sitting where you want it
Problem fixed ...and it didn't cost you any money!
BMW 3 Series - "Consistency of Purpose...Excellence of Execution."
ERT Supercharged
::ALPINE::AUTOTEK::ORION::
Old 08-23-2005, 01:21 PM
mattytm3's Avatar
The wideband02 must be an air/fuel meter, right. Well I dont have that one but I do have another meter problem is I ve never did it before so I don't know where to hook it up at to see if I am lean or rich.
Old 09-26-2005, 05:00 PM
Rides:1989 325is
Q5Quint is a New Registered Member
please sell me your car
you can get a decent air/fuel narrowband meter for about 60$ from napa, and you hook it up to your o2 sensor.
A wideband is about 200$ and you have to drill/tap/make a hole in your exhaust for it, and a nice guage is about 200$, though it wont really tell you anymore than a narrowband.
Remember that cars were tuned with screws and 'feel' before the narrowband, so even that is a major improvement.
what engine management are you running?
Old 09-26-2005, 05:27 PM
E30TRBO
Rides:1989 BMW 328i
Not really.
The Innovate LC-1 wideband sensor controller is probably the cheapest on the market. It uses a Bosch LSU4 5-wire wideband sensor, and is very sesitive (8:1 afr - 22:1 afr). It has multiple outputs so you can connect one into the stock ECU (if you still use it), and one into your HKS Super AFR or a regular narrow band gauge. You can tune the outputs to read as a normal narrow band o2 sensor, but with the accuracy of a wideband gauge. Narrowband is good for telling you if you are lean or rich. Wideband is good for telling you HOW MUCH you are lean or HOW MUCH you are rich. They can sense almost every exhaust pulse if you set the sensitivity that way. I have the LC-1, and its probably the best decision I've made.
matt
Old 09-27-2005, 01:50 PM
card counter's Avatar
996whp 2.8
Rides:328i
card counter is a New Registered Member
call ICS
ICS performance custom turbo 2.8 996 rwhp
UUC Drivetrain and suspension
My web page www.bmwturbo328.com
Old 09-27-2005, 04:34 PM
BeRzErKaS's Avatar
Mobile Mammographer
Rides:'94 325is
I'll 2nd matt325is statements and say the Zeitronix Zt-2 wideband doesn't require you to drill or tap anything either. I've been using it's simulated narrowband to feed my ECU for months and the A/F is spot-on.
Not the cheapest option, but I got the full setup w/ the digital LCD display monitoring lambda, A/F, BOOST, and EGT. The SAFC-II displays RPM, %MAF Air , Fuel Correction, and Knock/Ping level. Both units are mounted side-by-side where the sunglass holder used to be. Everything you need w/ no ricey A-pillar gauges.
In car tuning is a snap... check the data log from the Zt-2, turn the knob on the SAFC-II and watch the A/F display change in real time.
The two have proven to be a pretty sweet combo for A/F tuning.
ERT Supercharged
Old 10-03-2005, 07:30 AM
paul e's Avatar
Rides:'99 SC M3
>> Narrowband is good for telling you if you are lean or rich. Wideband is good for telling you HOW MUCH <<
Which means that a narrowband wont decipher between 11:1 and 14:1.. Youll see 'Rich' in both cases.. Pretty useless. A narrowband is pretty useless in doing any meaningful tuning with your FI application.
You dont need an expensive gauge to show the result.. Innovate's LM-1 comes with a handheld display which is ideal for tuning, and capturing results, while displaying the results at the same time. One other point.. If youre mainly interested in WOT afrs, you dont need to install a pre-cat bung. You can buy from them an accessory which will insert and hold the wide band O2 sensor deep into the tail pipe, and it will work the same way the sniffer at the dyno works: at WOT, the effects of the cats are minimized as O2 is scavenged clean above ~3500 rpms, and your result will be very similar to a reading taken pre-cat. Ive compared readings taken pre-cat and in this method, just as with a dyno's sniffer in good shape, and the results are all very close to one another.
Paul E
Old 10-05-2005, 10:17 AM
bmxcm's Avatar
i ♥ my car
Rides:raped ape
bmxcm has achieved their Master Licensebmxcm has achieved their Master Licensebmxcm has achieved their Master Licensebmxcm has achieved their Master Licensebmxcm has achieved their Master Licensebmxcm has achieved their Master Licensebmxcm has achieved their Master Licensebmxcm has achieved their Master Licensebmxcm has achieved their Master Licensebmxcm has achieved their Master Licensebmxcm has achieved their Master License
www.victorresearch.com
FOR SALE:Euro Headlights Wiring Harness
- PM for details...
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731
