Old 07-05-2005, 10:11 PM
Rides:Bmw 325i 1989
SwolenColen is a New Registered Member
why don't ppl do this...
I was thinking... the worst part about turbocharging is that you have to choose between less lag and upper rpm power - unless you set up your system so that you have 1 second + lag, and don't reach full boost until nearly redline, you will build up backpressure in the turbine and lose power top end, which sucks for racing b/c upper rpm is where you live
So anyway - I think I found a way to help get the best of both worlds; it seems like ppl would have thought of this by now so I'm wondering if there is something about this that would not work - only route about half of the exhaust gasses through the turbine. For example, if you have a 3.0 6 cyl, have 3 cyl go through the turbine, and have the other three join straight into the downpipe. Then just mount a small turbo (.48 or something) to the first three. This way, you could make the turbo a little too small for the amount of gasses its taking (fast spool, normally would kill top end), but the backpressure would only cut off half the power that it normally would if you wanted the same throttle response while routing all gasses through the turbo. The only two problems I see with this are 1) making the manifold / downpipe and 2) varying backpressure for different cylinders (i don't even think this would be a problem, but you never know)
even better - if you could find a motorcycle turbo or something, and just get a big compressor on it, you could run it off of one cyl. and you would lose barely anything... anyway thanks for your opinions
PS - This is what part of the alphabet would look like if Q and R were eliminated.
- Mitch Hedberg RIP
Old 07-05-2005, 11:32 PM
Soccer Mom Lubber
Rides:97 2DR M3
Jason_M3 has achieved their Master LicenseJason_M3 has achieved their Master LicenseJason_M3 has achieved their Master LicenseJason_M3 has achieved their Master LicenseJason_M3 has achieved their Master LicenseJason_M3 has achieved their Master LicenseJason_M3 has achieved their Master LicenseJason_M3 has achieved their Master LicenseJason_M3 has achieved their Master LicenseJason_M3 has achieved their Master LicenseJason_M3 has achieved their Master License
I imagine it would mess up the flow of the engine. The exhaust would be a lot more free-flowing that than turbo and it would cause some crazy port area backlog imo.
1997 BMW M3
1997 VW GTi
Old 07-06-2005, 02:50 AM
Rage\'s Avatar
Rides:BMW E36 320Ci - 1992
Rage\ is a New Registered Member
What about the exhaust pulses?
Old 07-06-2005, 04:52 PM
Rides:E30 325
VASHEE is a New Registered Member
that would not work because you have half of the engine working to support the turbine which is slowing exhaust gasses and keeping more pressure in the cylinder, while u have the other half of the engine free flowing. Half of the cylinders would be running slower than the others and that would not mix. Im guessing something bad would happen to the crank because the slower cylinders would throw of the balance of the engine.
Old 07-09-2005, 12:55 PM
pimpin 5er's
Rides:TCD 535 s1
gol10dr1 is a New Registered Member
not to mention it would grossly reduce power with a turbo that small,
BAVARIAN PERFORMANCE GROUP
Andrew
AIM: gol10dr1
TCD stage 1 535i Turbo
Old 07-12-2005, 01:16 AM
M50_328is's Avatar
Is pretty Darn Qwik
Rides:Madeira Violet 328is
M50_328is has achieved their Master LicenseM50_328is has achieved their Master LicenseM50_328is has achieved their Master LicenseM50_328is has achieved their Master LicenseM50_328is has achieved their Master LicenseM50_328is has achieved their Master LicenseM50_328is has achieved their Master LicenseM50_328is has achieved their Master LicenseM50_328is has achieved their Master LicenseM50_328is has achieved their Master LicenseM50_328is has achieved their Master License
I posed that same ? about a year ago, I have a T3 laying around that is good for about 250 HP +/- and thought of using 3 cyl. I got laughed at too lol Too bad there isnt a effecient way to do that. What about Doing a small turbo i.e. T3 w/ 40 trim or something, to help low and midrange power, kinda like TT cars such as the Maserati BiTurbo, Supra, VR-4's etc. on all 6 cyl? Then when max boost is reached around 4-5k rpm, it simply bypasses the turbine. It would be like a TT setup w/ only 1 turbo ??? Flame suit on lol
~Phil
3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> M50 Manifold -> S52 Cams. AA software, Dynomax Cats & Stromung exhaust
UUC Pulleys & Clutch stop, FDM=Zionsville radiator w/ SAMCO hoses, Fidanza LTW f/w & M3 clutch, UUC Evo3 SSK, 3.23 LSD
H&R Springs w/ Billstein sport shocks/struts, PUR RSM's & RTAB's, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace
18x8.5 M-Classics, Power Slots w/ Pagid Pads, Hella CELIS projectors + 5k Prolumen HID's, Hella Yellowstar fogs and LTW wing.
CCA Member #382557 FS: E36 Sport Springs & Sport Pkg Sway Bars
Old 07-13-2005, 04:37 AM
e28 driver
Rides:85 635csi 93 325is
tjn182 is a New Registered Member
It wouldn't work. There wouldn't be enough exhaust gasses to power the turbo. If you had a small enough turbo to be powered by only 3 cylinders then it would be too small to power the entire engine. Not to mention it would cause some weird stuff w/ the exhaust - half the engine would have different backpressure than the other half - that along w/ other properties would cause one weird acting engine.
Good thought, but it wouldn't work.
87' BMW 535is Turbo (545is)
JE Forged Pistons in the mail
Old 07-13-2005, 08:53 AM
queenz's Avatar
Rides:Dirty..3 duce~n~a quarter ((BOOSTED))
queenz is a New Registered Member
~Phil
where in MD are u from.. i never meet u before?/
Thug girl so fly n talk so nicely, Put her in da M coupe so she could feel da nice breeze. We could drive da city no dought, don’t say my Bemmer is topless, say da TT are out!
Old 07-14-2005, 05:43 AM
Rides:E28 535i
P4g4nite is a New Registered Member
Later RX-7's used two different sized turbos in sequence, one smaller at lower RPM then a larger one later in the range.
Old 07-15-2005, 10:41 AM
M50_328is's Avatar
Is pretty Darn Qwik
I live near Frederick, I'll be hitting up the East Coast Euro meet next friday.
~Phil
Old 07-15-2005, 11:29 AM
markley02's Avatar
Rides:1997 M3 4D
markley02 is a New Registered Member
I dont think the exhaust would be as big of a deal as the balancing of the crank as said before. It would need one hell of a counter balance and that would make a lot of rotating mass. Just like P4g4nite said, this is why we have twin turbo cars. (which arent exactly twin turbo, but a small turbo is used to spool a bigger turbo)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644
