Old 05-08-2005, 03:52 PM
Rieger M3's Avatar
::GT35R boosted::
Rides:Turbo Rieger M3
Rieger M3 is a New Registered Member
GT35R Turbo Parts, will these work?!
:: I need to know if 1000cc injectors from a 500whp civic would work in my M3.. I also need to know some dimensions on the intercooler... i can get a 12" x 24", huge as fuck.. i dunno if it wil fit, or i can jsut get this 24" x 6" intercooler... anyone got any suggesstions.
oh ya.. would a Tial 44mm wastegate (2 springs) & a Tial 50mm bov on the same civic work for my setup?
OHH YA.. for a boost controller, what do you guys think of the GReddy PRofec B-Spec II??
Old 05-08-2005, 06:22 PM
JGCM3's Avatar
Rides:AA Turbo M3
JGCM3 is a New Registered Member
1000 cc injectors are way to much
Old 05-08-2005, 06:53 PM
Rides:96 m3
caracas_e30 has achieved their Master Licensecaracas_e30 has achieved their Master Licensecaracas_e30 has achieved their Master Licensecaracas_e30 has achieved their Master Licensecaracas_e30 has achieved their Master Licensecaracas_e30 has achieved their Master Licensecaracas_e30 has achieved their Master Licensecaracas_e30 has achieved their Master Licensecaracas_e30 has achieved their Master Licensecaracas_e30 has achieved their Master Licensecaracas_e30 has achieved their Master License
750cc injectors will do just fine.
Old 05-08-2005, 08:03 PM
Rieger M3's Avatar
::GT35R boosted::
what you mean WAY TOO MUCH, will they NOT work, or are they going overboard, cuz.. i have them already, i jsut don't knwo if they will work, they were in a civic... will they fit and run good.??
Old 05-08-2005, 09:41 PM
Rides:06 M3, 97 M3
M3 Kid is a New Registered Member
Rieger-
What software/ECU do you plan on using to tune your car? This will determine whether 1000cc injectors are too big. Whats your power goal? Stock m3 internals are good to 500whp or so, which means the 1000cc injectors will be overkill. 400-450whp cars are running 36-42 lb injectors (350cc-450cc) injectors, so unless you plan on making more than that, I'd consider a different injector. A 12x24" intercooler is nice, but what are the specs on it? If its a decent intercooler, it should be more than enough. A Tial 44mm wastegate and a Tial 50mm BOV will work if you decide to use a stand-alone ECU or Nick G's custom blow thru HFM setup. As far as the Greddy Profec 2B goes, I have used the unit myself and I personally don't like it. I'd consider Greddy's Profec S or one of the Blitz units. Another good boost controller is the TurboSmart E-boost controller/gauge.
Good luck,
Joe
Joe
2006 M3 ZCP Interlagos/Cinn.
1997 Dakar Yellow M3/2 ** FOR SALE **
Old 05-08-2005, 09:57 PM
Rieger M3's Avatar
::GT35R boosted::
i still am undecided on the software, also, do i have to go with a stand alone Fuel mang. if i use the Tial bov and Tial wastegate, and if so, what do you suggest for a stand alone system for my car?
Old 05-09-2005, 06:53 AM
Rides:06 M3, 97 M3
Since the Tial 50mm BOV is a open atmosphere BOV that can't not be recirculated back into the intake tract, you will either need to use NickG's custom blow thru HFM setup or a standalone. AA's "draw thru" HFM setup is not ideal for open atmoshpere BOV, they need Bypass Valves or BOV's with a recirculation kit. I'm not a big fan of stand-alones unless you plan on making a lot of power or know someone who can REALLY tune the car(theres more to tuning than just playing around with the WOT map). You can make up to 650whp on a stock ECU, so I see no need for a standalone. Try contacting NickG @ www.techniquetuning.com or calling Active Autowerke (www.aatuning.com) . Tell them what you want and see what they recommend.
Joe
Old 05-09-2005, 07:51 AM
Originally Posted by M3 Kid
Rieger-
not for very long. That's a lot of power for stock internals. 1000cc injectors sounds overkill as well.
Old 05-09-2005, 06:46 PM
Rides:06 M3, 97 M3
Dado-
Just because no one has pushed the limits of the stock S52 pistons doesn't mean that they are low. I personally believe the limits stock internals of the S52 motor are much higher than people believe them to be.
Joe
Old 05-09-2005, 10:08 PM
Highboosted's Avatar
Road Race or Die
Rides:SPEED DENSITY!!!
Region: USA - Great Plains
LoL, I replied to the other thread before seeing this one.
Stock internals (being genaric, never dug into an M motor, so ill be vauge) are usually more overbuilt than most people think, a 10:1 NA DOHC 3.0L v-6 in a 3000gt withstands 26psi of boost pressure (30psi occasionally), fastest 1/4 time is 11.450@129.83MPH, and it's FWD. A 8:1 DOHC 3.0L v-6 in a 3000GT VR-4 withstands 790.29AWHP with stock internals. The stock internals in a 4.2L OHV v-6 withstands 448RWHP daily driven. The thing that is common between all these are the ALL are on standalone engine management systems with proper tuning and are raced and driven regularly (well that and came stock with forged cranks, all had cast pistons). I'm actually slightly surprised your engine lasted as long as it did (running a wanky tune?) on the stock ECU, Dado. M3 Kid, I'm with you on the M3 motor being capable of reliably putting out 500WHP on the stock bottom end, but to get there and be drivable and reliable I feel a standalone is nessessary, as well as headwork as NA heads primary function is port velocity and a turbo's heads primary function is flow.
Old 05-18-2005, 10:15 PM
Dakar is Fast
Rides:Carrera Aero
icemann633 is a New Registered Member
1000cc is way too big...you want complete atomization of the fuel...Not splashing...
Just because you have them doesnt mean you should use them...
I think you need to do more research before you post so you can make better questions...
The BOV and the WG are universal...They will work on any setup as long as you have the pipe with the right flange...Regardless if its a civic, a bmw, or a ferrari, they are going to use a supplied flange atached to a pipe running off of the manifold...So YES it will work...But you have to make it work...
-Keith
Old 05-19-2005, 10:17 AM
Rides:1997 audi a4 1.8tq
Dragonsi is a New Registered Member
if someone is gonna push the limits of teh stock internals, they might as well spend some extra cash and get water injection as well just to be on the safe side
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
