Old 05-06-2005, 11:22 AM
BMW2ner's Avatar
Conekill3r
Rides:BMW, 325i, 1991
BMW2ner is a New Registered Member
Question E30 325i TURBO QUESTIONS !!
Can you guys help me please with a few things I have to clear up on my turbo set up. I am putting together a turbo kit and I have come to the confusing parts. Any help would be great. I only plan on running 5-7psi for a while so I'm not going crazy till I can get more money
1. What is the best thing to do for a fuel set up? Is it true that I can use 524td injectors and a Fuel Pressure Regulator?
2. What do I need to do to account for the extra air in the system? Is a new computer needed for only 5-7psi?
3. I got a 524td downpipe on ebay for cheap just hoping it would work, will it? What is the best exhaust setup? I know I need a one pipe set up, but do I need two mufflers like in the stock set up?
Any other things that you can help me with would be great. Thanks again
Old 05-06-2005, 11:46 AM
Rides:90 325is
e30boosted is a New Registered Member
I would look for company that makes a chip, it will run way better! Run a FMU and i would use 5.0 Mustang injectors(direct fit)....For exhaust run no cat 2.5in to a magnaflow or some muffler...
PNW e30 crew
Old 05-06-2005, 11:50 AM
Rides:90 325is
P.S. i thought u wanted to maybe trade me?
PNW e30 crew
Old 05-06-2005, 12:33 PM
BMW2ner's Avatar
Conekill3r
thanks for the help and I did want to trade but then I came into a little bit of money and decided to build my own. I still think your car is amazing, I dont know to much about it but it is down right beautiful. If you dont mind me asking what color is your paint.
Old 05-06-2005, 01:12 PM
NWe30's Avatar
Banned
Rides:e30
NWe30 has achieved their Master LicenseNWe30 has achieved their Master LicenseNWe30 has achieved their Master LicenseNWe30 has achieved their Master LicenseNWe30 has achieved their Master LicenseNWe30 has achieved their Master LicenseNWe30 has achieved their Master LicenseNWe30 has achieved their Master LicenseNWe30 has achieved their Master LicenseNWe30 has achieved their Master LicenseNWe30 has achieved their Master License
No offense, but your first post makes it crystal clear you have no idea what you are doing. Perhaps you should rethink you plans.
Old 05-06-2005, 01:26 PM
BMW2ner's Avatar
Conekill3r
No the problem is that I know how things work but I have no "real" experience with putting a turbo on. The reason I need to ask the questions is mainly because of fourms. I read mixed answers, I was just asking peoples personal experence, not what they read some where on the net.
Old 05-06-2005, 03:11 PM
NWe30's Avatar
Banned
Rides:e30
ok.... right....
As far as fueling goes. 19lb injectors will take you to 275HP. go with 21 or 24lb injectors if you will be making more power then that.
adjustable FPR is a good bonus, but not needed if you have the car tuned right.
stock ecu will handle 5-7psi fine with fuel system upgrades
524td injectors dont work. its a freaking diesel... also the 524td manifold/downpipe is garbage. make a custom setup.
Old 05-06-2005, 07:11 PM
Rides:90 325is
Haha..its chill... My paint it Candy Apple red.
PNW e30 crew
Old 05-06-2005, 07:34 PM
NWe30's Avatar
Banned
Rides:e30
Old 05-06-2005, 11:03 PM
Rides:90 325is
Haha thats awesome! i like...
PNW e30 crew
Old 05-07-2005, 02:48 PM
MaDhAtTeR's Avatar
Throttles ahoy.
Rides:E21 JPS 323i, B6 2.8, E30
MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR MaDhAtTeR
ok.... right....
You know what, you have been giving out some really shit advice recently, you bag others for their lack of knowledge but you exhibit the same traights.
19lb injectors at 58psi (system pressure) are not large enough to support 275hp, where did you get that figure from? pull it out of your arse? Unlike jordan's mythical numbers, you can actually work out horsepower ratings with a simple formula.
19lb injectors, when run at 58psi equate to just under 22 lbs/hr. To find out how much horsepower they can flow it is simple.
Injector size (lbs/hr) x duty cycle / BSFC
Using basic figures for both duty cycle (80%) and BSFC (of 0.5 for a NA, 2 valve engine), it is as follows
HP flowed = (22 x 0.80) / 0.50
= 17.6 / 0.50
= 35.2
So, 6 injectors, rated at 19 lbs, have a maximum flow rate of around 211hp. It differs slightly with the real BSFC of the engine (from experience i have found them to be around .56), just what duty cycle you wish to run (though you shouldnt really exceed 80%), and just how much fuel pressure you want to run, but 19lb injectors arent good for more than 220hp at best.
Lastly, the 524td manifold is fine, quite a few people use it but you need to modify it (notch out some of the holes to fit). You could easily make in excess of 300hp with a td manifold.
The other option many people use is to copy the manifold adaptor, it bolts straight onto the existing pair of manifolds, forms a u shape bend, then comes back up to a base plate to bolt your turbo onto. Saves you spending vast amounts of money on a tuned length tubular style manifold that really isnt needed for most people.
You need to settle the hell down jordan, you arent the be all and end all of E30 knowledge, you treat people like shit when they dont deserve it. If your advice was accurate enough of the time you might have the ability to backup the talk, but im affraid you dont.
Now that is finished with, there are a couple of threads here which might interest you.
http://www.e30tech.com/forum/viewtopic.php?t=3318 that is the turbo faq
http://www.e30tech.com/forum/viewtopic.php?t=3215 that is the injector thread.
Edit: Couple of extra links.
http://www.e30tech.com/forum/viewtopic.php?t=3341 talking about the TD manifold.
http://www.e30tech.com/forum/viewtopic.php?t=1913 talking about manifolds in general
And if you go here http://www.mkosonen.com/manifold.html to matt's site you will see the adaptor i was talking about before.
- Website with full rebuild content coming real soon -
Old 05-07-2005, 03:34 PM
NWe30's Avatar
Banned
Rides:e30
My bad, after a long day of work, late at night i crunched some numbers and multiplied by 8 instead of 6. Life goes on.
Still he wont be making that much power with his m20.
the 524td manifold is still a cast log style hunk of shit. Its ugly, it flows poorly, and its just crap. If you are going to make a turbo setup do it right! don't use some 20 year old rusty factory manifold that sucked 20 years ago, and still sucks today.
There are several full manifolds available, but they cost money. something most of the stupid kids that want turboz dont have.
Old 05-07-2005, 03:45 PM
MaDhAtTeR's Avatar
Throttles ahoy.
Thats what is called DIY, plenty of people use them for low boost setups without a problem in the world. They are cast iron so they generally last for ever, the biggest plus for them is they are compact, and it makes it easy to change your spark plugs.
You have no hope in hell of getting a socket in with a full length manifold, even people with the adaptors have the same problem, most end up unbolting the turbo everytime.
Old 05-07-2005, 06:44 PM
NWe30's Avatar
Banned
Rides:e30
Thats true, but that aside... custom cars be customized labor. How often do you change your spark plugs? Once a year? Maybe twice?
Old 05-08-2005, 02:12 PM
BMW2ner's Avatar
Conekill3r
Hey MaDhAtTeR thanks for the advice and the formulas. Those links were also pretty helpful, but have you ever heard of using the mustang 5.0 injectors before? I think that would make things a little cheaper, but if you listen to NWe30 CHEAPER always equals BAD.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
