Old 04-14-2005, 08:39 AM
Rides:95,m3
fitler1 is a New Registered Member
Water/Alcohol Injection kit
i'm contemplating instalingWater/Alcohol Injection kit on my dinan s/c m3. can anyone tell me exactly how and why it works. and also if it is worth the money. to my understanding it doesn't incease hp but will allow me to retain it in under high temp.
if anyone who has this installed would like to comment it woud be appreciated. or if you have one for sale let me know price
Old 04-14-2005, 08:55 AM
redforcedbmw's Avatar
boosted bimmer
Rides:93' 325is, 86 audi 5000cs
redforcedbmw is a New Registered Member
i have one on my car i dont know the hp gains but you can feel a diff on the higher end
1993 BMW 325is ERT Supercharger Kit, 2.70" Powerdyne pulley Aquamist 1s system, Apexi S-AFC II, 3 inch Exhaust, Magnaflow High Flow Cat, 3in Test Pipe, Custom CIA, M3 clutch kit, M3 lightened Flywheel, M3 slave Cylinder, UUC short shifter,Bilstien sport shocks, H&R Springs, Brembo Cross Drilled Rotors,BMP Front and Rear Strut Tower Bar, M3 Body Kit, Euro headlights, and smoke tails
The difference between my car and your car is that when my car gets louder it goes faster
Old 04-14-2005, 09:18 AM
03E39LemansBlue's Avatar
Unicycle Passenger
Rides:'03 M5
03E39LemansBlue is a New Registered Member
Let me preface this with the fact that I dont have forced induction, or water/alocohol injection.
I dont know what exactly the differences would be, but check this out:
Water Injection Kit
The kit was designed around a 1991 Nissan 300zx Twin Turbo pushing 17 psi off the stock turbos. I dont know what changes would need to be made to modify it for a BMW inline 6 like the s50/s52.
Just letting people know another option than AA exists.
Old 04-14-2005, 09:47 AM
here is some info.
Turbo Water/alcohol Injection - The Theory
Water/alcohol injection relies on the fact that it takes much more energy to raise the temperature of water than it does to lower the temperature of air. The specific heat of a substance is a measure of the amount of energy (kJ) required to increase the temperature of a certain amount of it (kg) by a certain temperature (° C). The specific heat of water is 4.184 kJ/kg ° C. This means that it takes 4.184 kJ of energy to raise one kg of water 1° C in teperature. The specific heat of water is more than four times that of air, which ranges from 1.00 kJ/kg ° C to 1.05 kJ/kg ° C, for the temperatures we're concerned with.
Water/alcohol injection is dependent upon the relative humidity in the atmosphere. Lower humidity will increase the effectiveness of water/alcohol injection.
Advantages to Water/Alcohol Injection
Suppressing Engine Knock. Water/alcohol injection works to suppress engine knock in several ways. First, the water (and alcohol) reduces the temperature of the compressed air. When the exhaust gases are expelled from the combustion chamber, the cylinder, piston, and valve surfaces are at a very high temperature. The water entering the cylinder with the compressed air will work to cool these surfaces and any hot spots which might exist. It is in these hot spots that predetonation would typically occur. As the air is compressed in the cylinder, the water serves to reduce air to fuel contact, reducing the likelihood of auto-detonation. Lastly, if any alcohol is used, it serves to increase the octane of the fuel.
Increasing Intake Air Density. As previously mentioned, the water serves to decrease the temperature of the charged air. Since water/alcohol injection presents no additional flow restriction, this reduction in temperature can only be accompanied by in increase in air density. Also, when the water cools the metal surfaces in the combustion chamber during the intake stroke, this allows more air to enter the cylinder - effectively increasing the volumetric efficiency of the engine.
How Much Water and Alcohol?
Water to Alcohol Ratio. A 50/50 water/alcohol mix is recommended as the minimum, with 70/30 being quite common. In fact, many people use filtered windshield wiper fluid without any modification for a very cheap solution. For our analysis, we'll assume a 70/30 mix, which will have a specific heat of 3.66 kJ/kg ° C (the specific heat of ethanol is 2.43, and methanol is 2.51).
Water/Alcohol to Fuel Ratio. Most experts suggest a maximum water to fuel ratio of 25% and point to many tuning problems with rations this high. Typically, 10-15% water to fuel is a more manageable ratio.
Where to Inject Water
Theoretically, water/alcohol injection can happen anywhere between the air filter and the intake runners. However, injecting water before the turbocharger will damage the compressor wheel. On the other hand, injecting water after the turbocharger is made difficult by the need to increase the pressure under which the water is injected in order to overcome the additional pressure. Also needed is a check valve to inhibit compressed air from entering the water reservoir when water is not being injected, such as in low boost situations. The water should be injected as soon after the turbocharger as possible to allow time for the water to form small droplets. Often, people will inject perpendicular to the tubing to use impact with the back wall of the tubing to further break up the water drops. Alcohol also assists in creating smaller droplets. If water/alcohol injection is to be used in tandem with an intercooler, the water should be injected after the intercooler in order to maximize the temperature drop.
active overcharges, you can build your own for cheap.
http://members.cox.net/stevemonroe/AlcoholInjMod.html
http://www.lehigh.edu/~cak7/Upgrades.../WaterInj.html
Old 04-14-2005, 06:33 PM
Rides:95,m3
where
ok so where exactly do i go to buy a kit so i can avoid paying 750 to aa? and is it completly compatable with 95 m3?
Old 04-18-2005, 08:08 AM
GOTUBCH's Avatar
Rides:BMW M3 1999, GS400
GOTUBCH is a New Registered Member
You can buy them off ebay or look around at Mustangs sites they have them too with out paying AA prices.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
