Old 04-09-2005, 12:37 PM
NyteRyda's Avatar
Nyte Ryda 4 Life
Rides:1993 BMW 325is sold, current 89 supra turbo
NyteRyda has achieved their Master LicenseNyteRyda has achieved their Master LicenseNyteRyda has achieved their Master LicenseNyteRyda has achieved their Master LicenseNyteRyda has achieved their Master LicenseNyteRyda has achieved their Master LicenseNyteRyda has achieved their Master LicenseNyteRyda has achieved their Master LicenseNyteRyda has achieved their Master LicenseNyteRyda has achieved their Master LicenseNyteRyda has achieved their Master License
m3 swap turbo/supercharger question
I know this probably been asked a million times but o what the hell. I am planning to get an m3 engine swap for my 325is in the future. I heard that dropping a 95 m3 engine in would be the best fit? Is that true? Would it be easier to fit the 95 engine then a 96 and up 3.2 engine? and why? Also if I was to put in a 3.2 m3 engine how would it be possible to convert it back to obd1? Also what other parts would I need beside the engine? Also what good companys of turbo chargers or super chargers are good for an m3 engine? OR would it be cheaper to buy a used 95 m3 and add a turbo/ supercharger to it?
Old 04-09-2005, 02:55 PM
Rides:Bmw 325i 1989
SwolenColen is a New Registered Member
I think an engine swap would be a waste of money if you're planning on turbo - just get dished pistons and drop ur CR to 8 - 8.5, and put like 15 lbs of boost into it... that should bring you to like 320 hp. engine swaps are a lot of money and work, and you'd have to prepare the m3 engine anyway, and you'd only get 30 hp out of the whole deal.
Old 04-09-2005, 10:12 PM
NyteRyda's Avatar
Nyte Ryda 4 Life
how much would dished pistons cost and what brands should I look into? Also what do you mean by dropping my CR??
Old 04-10-2005, 10:50 AM
Rides:'94 Bmw 325is
amat3ur is a New Registered Memberamat3ur is a New Registered Memberamat3ur is a New Registered Memberamat3ur is a New Registered Memberamat3ur is a New Registered Memberamat3ur is a New Registered Memberamat3ur is a New Registered Memberamat3ur is a New Registered Memberamat3ur is a New Registered Memberamat3ur is a New Registered Memberamat3ur is a New Registered Member
If you are asking what CR means it stands for compression ratio. And you want to lower your compression ratio if you are going to turbo your engine.
Old 04-10-2005, 06:57 PM
NyteRyda's Avatar
Nyte Ryda 4 Life
thanks for the help amat3ur. I need to learn a lot more about turbo or super chargers. Also what is needed to lower the compression ratio? Also what forged piston brands and brands of turbo or superchargers would best suit my car?
Old 04-10-2005, 07:05 PM
queenz's Avatar
Rides:Dirty..3 duce~n~a quarter ((BOOSTED))
queenz is a New Registered Member
My 92 325is has a 3.2L in her now.. As for the OBD1 since a 92 is dosen
t have all the sens like a 96 and up car.. the setup was perfect..
Thug girl so fly n talk so nicely, Put her in da M coupe so she could feel da nice breeze. We could drive da city no dought, don’t say my Bemmer is topless, say da TT are out!
Old 04-10-2005, 07:10 PM
queenz's Avatar
Year do your homework.. i plan on turbo for my car. If u want high boost u must work the engine and lower the CR
Old 04-11-2005, 02:40 PM
Rides:Bmw 325i 1989
compression ratio is how much ur engine squishes the air and fuel in the cylinder before ignition - the lower the compression, the more boost you can put into it without any detonation, which is explosion before ignition, and is not good. The dished pisons just have a cavity in them that makes it squish less stuff, because some escapes into the dish. Ireland Engineering has custom pistons for $850, and JE also makes good pistons. I am getting the Ireland Engineering pistons this month, but I haven't heard nething on their reliability or quality. Also don't get a kit, build the system yourself. Get Maximum Boost by Corky Bell - its a little old and behind the times, and sometimes hes not very specific, but it has a lot of good information that you should know before putting a turbo in.
Old 04-12-2005, 10:45 AM
Rides:'94 Bmw 325is
I believe, correct me if I am wrong, that a few ways to lower the CR is to get a low compression head gasket and pistons. Does anyone know how much that will lower it.
Old 04-12-2005, 12:26 PM
Josh's Avatar
Rides:in a car
The S52 will drop right in, no problem. Because that engine was meant for OBD2, you will need to do a little extra work with the sensors and a few other parts to make it OBD1 compatible. This would not be a big deal for a shop that knows what they are doing and a lot of your M50 parts can be used to aid in the conversion, like the intake manifold.
Do the engine swap first and then determin what power route you want to go. It is a much better platform to start from. Don't bother with building up your 2.5, as it is not very cost effective depending on how much power you are realistically looking for. Well over 400 rwhp can be had safely on a S52 with stock internals.
Old 04-12-2005, 02:04 PM
Rides:Bmw 325i 1989
if you get a thicker headgasket, it will lower compression, but thats the ghetto way of doing it. Pistons are the way to go, and you can drop it however much you want - the thicker the headgasket / bigger dish in the piston, the lower the CR will be.
Old 04-12-2005, 02:07 PM
Rides:Bmw 325i 1989
with the money you spend on an engine swap, you can completely prepare your current engine and boost the hell out of it... you setup the engine right and you can run 15 psi eeeeeasily. theoretically 14.7 psi should double the stock horse (168 --> 336), so 15psi should definately give you at least 300, which would be difficult to get w/ an engine swap, unless you went w/ like a 4.0 V8
Old 04-12-2005, 02:09 PM
Josh's Avatar
Rides:in a car
I fail to see what is "ghetto" about a perfectly safe and proven method of lowering compression.
Old 04-12-2005, 02:11 PM
Josh's Avatar
Rides:in a car
Right and you have a smaller engine capable of less power and nothing to build off of if he wants to raise the bar on his setup.
Old 04-12-2005, 02:28 PM
Rides:Bmw 325i 1989
how much power do you want? Turbo will get you to 350 w/o going nuts on your engine if you do it right. You can drop in nitrous if you want, but going with the 3.0 or 3.2 will only give you 50 hp max, not to mention costing tons of money. If you have all the money in the world, and don't care about details of handling / weight distribution, then there is no reason to stay with a 2.5 liter engine, but if you dont have a money tree in your front yard i would not suggest a swap.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
