Old 04-08-2005, 01:30 PM
Rides:Bmw 325i 1989
SwolenColen is a New Registered Member
how low can you drop compression
i've been planning on dropping my compression to 8.2:1 for 15 psi, but i was thinking, since im getting new pistons, why not go lower? Corky Bell, in Maximum Boost, says that anything lower that 8 is not driveable, but my friend says that he's running 7:1 on his daily driver, and doesn't have any problems with it. What are your opinions on this, and also, how much horse/torque do you lose from dropping the ratio?
Old 04-12-2005, 09:16 AM
KatnipBimmer's Avatar
Intoxicated User
Rides:Bavarian Crotch Rocket
KatnipBimmer is a New Registered Member
well...there are alot of facets to this issue that corky bell doesn't really explain in his book. (good book...but vague in some areas)
You can run 9:1 compression and still boost to 18psi if your motor is tuned correctly and you are running high octane gasoline (103ish)
If you had boost early on (very low revs) you could get away with lower compression but if you didn't have air being forced in it would be a rather un-powerful engine.
Old 04-12-2005, 02:36 PM
Rides:Bmw 325i 1989
i will only be running 93 octane, and i'm not really trying to test the limits of my engine. I'd like to drop down to 7:1, but i'm afraid i'll have problems w/ startup, idle, low rpms, etc. I'm planning on only having max boost at 4k +.
Old 04-12-2005, 04:20 PM
Rides:V-Power
RvolvoR is a New Registered Member
run lower boost and a higher comp ratio, you will get better all around prformance, because all you are doing when you raise the boost at a lower comp ratio is making up for how much you dropped it
Old 04-12-2005, 05:37 PM
Highboosting///M3's Avatar
Rides:'97 M3T, '95 Supra, '03 Hummer
Highboosting///M3 is a New Registered Member
Just look at the Supra guys. 8.5:1CR and they have made 1520rwhp on an auto! I would think that you aren't going for more hp than that.
With max boost at 4K rpms you are looking at maybe 650rwhp max(if you lucky). More than that and you will have more lag.
So no lower than 8.5:1CR! Why? Cause there is no reason for lower CR unless you are building a drag car....your car will just bog before boost.
I like big boost and I cannot lie, you other brothas can't deny, when the turbo spools at a violent pace and there's a crazy look on your face you get sprung! Deep in the vein the adrenalines flowin', I'm hooked and I can't stop boostin', oh ladies yeah ladies yeah this aint no f-in Mercedes, so turn it up, floor it out, even S/C guys got to shout, baby got boost! You can keep it sleeper or show, but please don't lose that boost!
(written by Cameron Vongschlong 7/17/08)
Full Gallery Showing Stages From Bought To Current Brock Lesnar is now the UFC Heavyweight Champion of The World! He is superhuman!
Old 04-13-2005, 04:12 AM
Rides:Bmw 325i 1989
with an 8.5:1 CR I will be able to put in 15-17 psi max... bimmerjim is running 17 and getting 300 hp
Old 04-13-2005, 02:33 PM
Intoxicated User
Please dont rip new assholes just cause i counter this BUT; I don't think this is neccesarily true. NA cars gain power from an increase in CR and the same can be true for FI cars. We like to lower the compression in are cars because 1) it's safer and 2) we don't have to run exotic fuels just to drive around.
I'm no expert so if i am wrong, no hard feelin's. just some thoughts from another gearhead. (i'm planning on 9:1 CR for my project engine...but that is to retain driveability at low engine RPM and a turbo that doesn't kick in till high in the rev range)
Old 04-13-2005, 02:34 PM
Intoxicated User
Also; if your only going to be running 93 octane...then you will be fine with a higher ratio (granted you aren't trying to push 2bar over the whole rev range!!)
Old 04-14-2005, 06:06 AM
e28 driver
Rides:85 635csi 93 325is
tjn182 is a New Registered Member
The M30 engines have 8:1 comp stock (from the e28s) -- So far we've had 22psi of boost dumped on our engine w/ stock internals (including stock headgasket). The only thing that went wrong there was the headgasket blowing. We can go much higher if we replace our headgasket with something more high performance. I've heard accounts of someone hitting 26psi of boost on stock internals as well. Some of the 745i's came with a 7.5:1 compression - and are real slugs off the line, but kick some serious ass once they build boost. I wouldn't drop the compression much past 8:1 - it's not necessary. The lower the compression, the slower it'll be off the line -- Yet the more boost you can dump into the engine. The higher the compression - the faster it'll be off the line -- Yet with less amounts of boost able to be dumped in the engine.
87' BMW 535is Turbo (545is)
JE Forged Pistons in the mail
Old 04-14-2005, 02:29 PM
Rides:Bmw 325i 1989
the only drawback to boost is detonation. I am going to crank the boost up as high as i can w/o getting any detonation. The ways you can add more boost w/o detonation is lower CR, cooler intake charge, running rich (not an option), and higher octane gas. And I am not building a drag car, if you read the original post, I want to know how low people have dropped compression, and how that's effected the drivability.
Old 04-14-2005, 02:32 PM
Rides:Bmw 325i 1989
I do not understand this at all. Why would 93 octane gas make it fine to have a higher ratio? If i have a 8:1 CR and 93 octane, lets say i can run 18 psi. If I had like 103 octane, then i could still run 18 psi on a higher compression (like 9:1 maybe), but I don't see how i will be fine w/ high compression and 93 octane.
Old 04-21-2005, 07:26 AM
2jz 2jz is offline
Rides:Anything with wheels.
2jz is a New Registered Member
you want to run a 7.0:1 on the street? I have a '95 SC300 with stock compression of 10.5:1 and used a 3mm headgasket and put it down to 8.7:1 and put down 644rwhp with a GT60 turbo. goood luck with that compression....sounds like its very streatable
'97 993 Twin Turbo - - '94 Supra Single Turbo GT74, among others....
Old 04-21-2005, 01:09 PM
Rides:Bmw 325i 1989
The point of this post is to find out what is "streetable", in your words, for compression. I don't know why you feel the need to mock me for considering it. If you know about this subject, please tell me why 7:1 is not "streetable".
Old 05-19-2005, 10:46 AM
Rides:1997 audi a4 1.8tq
Dragonsi is a New Registered Member
7:1 is very uncommon, I've actually never heard of anyone making pistons of compression ratios that low, 8:1 is the lowest. You need a decent compression ratio to spool the turbo. That's why on honda-tech there is a 11.5:1 cr on a t3/t4? and he has absolutely no lag since he has exhaust gases literally on tap. Unless you want to make a full out dyno queen, then 7:1 is useless, and/or you are gonna make some insane highway pulls
Old 05-20-2005, 01:41 PM
Rides:328iC, 1997, 325i, 1990
328iTunr2 is a New Registered Member328iTunr2 is a New Registered Member328iTunr2 is a New Registered Member328iTunr2 is a New Registered Member328iTunr2 is a New Registered Member328iTunr2 is a New Registered Member328iTunr2 is a New Registered Member328iTunr2 is a New Registered Member328iTunr2 is a New Registered Member328iTunr2 is a New Registered Member328iTunr2 is a New Registered Member
The lower the compression, the greater the responsiveness suffers. If you lower compression more, you can add more boost. This effect is like a lancer EVO. Absolutely no power/responsiveness in lower RPMs, but a huge surge when the boost comes.
1990 325i 5 spd. charcoal gray.
17" Anthracite rims, yoko. AVS100s
Custom flowmaster exhaust + high flow cat (header back) K&N filter
Pioneer deck 2x12" 400W, Kenwoods
Eibachs + Urethane +Tokicos
New tranny
s50 swap on the way!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
