| Alternatives to RMS aftercooler I am just curious if there is anything else out there besides the RMS after cooler or the Carteck FMIC for us superchared guys. I read somwhere that we might be able to get the Evosport(?) twin screw manifold and air to water cooler as a alternative . Anyone else know anything about this or anything else .. Thanks . Michael
__________________ 1986 325es 93 M50 motor swap 95 M3 cams lower compression - coming soon (9.5:1) ARP head and main studs VAC MLS Head gasket RMS Stage 1 - Stage 2 coming soon (11-12 psi) Tec3 EMS - coming soon Genine headers UUC underdrives Big bore TB Custom cold air intake Fully rebuilt suspension and rear subframe 3.73ls gears RPI Enginering BBK ( 12.3in rotors Willwood 4 piston calipers ) 17" Iforged wheels for sale |
| you can also get a air to air intercooler from cartech... do some searching, there's a member that has done an actual install.. http://www.cartech.net/intercoolers.htm -Dave
__________________ Dakar Yellow Z3 - 411rwhp/447rwtq SAE Engine Bay | Side Profile | Side Profile | UUC/Wilwood | Dyno | European Car Power: AA Stage II Turbo tuned by NickG:alright, .140" headgasket, ARP head studs, Porsche HFM, M50 manifold, Custom ICS 3" turbo exhaust, walbro 255 fp Driveline: 2.93 LSD, UUC Stage 2 LTW Flywheel/Spec Stage II Clutch, Whalen Shift Machine Suspension & Handling: TC Kline True Match Coilovers 450f/500r, Motorforce/Vorshlag adjustable camber plates, Dinan Stage II sway bars, Powerflex bushings all around, IE camber/toe kit, redline fluids, UUC/Willwood BBK, Slotted E46M3 Rotors, SS Brake Lines, Strong Strut trilogy, IE Subframe Bushings Misc: ACS Type II racing wheels, ACS Pedal Kit, Racelogic Traction Control, Blitz SBCiD Boost controller, Zeitronix ZT2 with remote digital display (Lambda, AFR, EGT, Boost), Sound System upgrades, Gramin Nuvi 360 GPS, Indash DVD system, and leatherZ rollhoop covers, armrest, S54 radiator upgrade and more! |
