Old 01-18-2002, 09:07 AM
CalypoRckt's Avatar
ATC 2B
Rides:Daytona M3 3.2 OBD1
CalypoRckt is a New Registered Member
non vanos M50's are better because you can mod more , right??
shed some light on this for me.. I HAVE HEARD YOU CAN DO A LOT OF MODS TO EARLY 6 CYL E36'S cheaper and will relaly make the car respond?!
please let me know what you know.. also on the suspension.. the car in question is 10/91 with the front suspension that is similar to the M3. Tell me what cheap mods can be done and effective..
thanks
Old 01-18-2002, 09:40 AM
Rides:M3
Spencer is a New Registered Member
I am not sure but since it doesnt have Vanos I think you can get more extreme cams or something. I am sure someelse knows for sure but it is along those lines.
Old 01-18-2002, 09:59 AM
NOSdriver's Avatar
Rides:M3
NOSdriver is a New Registered Member
My sisters car...
Hi! My sister is driving a 320i E30 with 129 Hps on stock. Thinking about some methods for faster acceleration we decide to make the suction tract a bit longer and build in an 57i kit.
After that we change the plugs and their voltage, the engine runs more
"rounder".
The result was a bit more power(150-160 now) and an unbelievable sound.
Hope that I could help you man...
Old 01-18-2002, 12:09 PM
psk145's Avatar
Rides:Blown 332i, AMG C32
psk145 is a New Registered Member
Re: non vanos M50's are better because you can mod more , right??
I think you are thinking of the differences between OBD1 and OBD2
Custom tuned by NickG
Old 01-18-2002, 12:14 PM
v.b.'s Avatar
Banned
Rides:-o-o-
v.b. is a New Registered Member
umm...I am thinking non-Vtech integra LS vs Vtech GS-R integra...
if you check out those ECU aftermarket chip site, the non-Vanos equip
cars won't gain that much ash Vanos OBC1
Old 01-18-2002, 12:16 PM
a.k.a. BMBUM
Rides:Hard Bargain
Bimmer Bum is a New Registered Member
Confirmed
Youre right. The 92's are more appreciateive of engine/exhaust mods than other years due to the lack of the Vanos unit. I have a 92 so i know the dramatic differences these mods can make first hand. The cams on this model more closely resemble a M cam with more aggressive specs than the 93+ . You can also over-revv without grinding your teeth as it can take it on the 5-speed models. 93+ is a trip to the engine rebuilder. Last note... the 92 2.5L was the last year of the M50 all cast iron block which is the basis for the M3 engine
~ It's the journey that counts ~
Old 01-18-2002, 04:08 PM
thinair's Avatar
Creative Driver
Rides:97 328is, a few bicycles
thinair is a New Registered Member
Plus the 92 has a better head. Stronger (thicker) valves and stuff.
Nelson Papel
Madeira Violet 97 328is
For more info on my car, click here
Mosport Skidpad Video
Old 01-18-2002, 07:43 PM
Rides:'94 325is
SoGold is a New Registered Member
so is there a difference in HP? how did the dyno charts change? and what was the point of adding vanos/duel vanos? I get the concept on Honda's, to save gas. However the non-vtec hondas are better down low (more torque) but the vtec equiped ones have a higher redline(more HP).
Mods: BMP Intake, TMS Big Bore TB, Remus Exhaust, Dinan Chip, M3 Short Shifter, Inpro Ellipsoids
Old 01-19-2002, 08:02 AM
doreenerzz's Avatar
Rides:1992 325i, 1993 325is, 2000 landrover discovery
doreenerzz is a New Registered Member
someone kill me if non vanos is better, because i just swapped mine last year with a vanos engine
Old 01-19-2002, 01:43 PM
Kyle K.'s Avatar
Rides:e34 540/6
Kyle K. is a New Registered Member
Could you feel a difference in the car before and after the vanos?
There seeems to be alot of contradictory statements on this thread . I've seen on the chip companies websites that that VANOS motor gets more of a hp gain from an engine chip, but i don't know about exhaust/intake and stuff like that....
Anybody know??
Old 01-19-2002, 06:50 PM
Evolution Driver
Rides:1998 BMW M3
BMWM3some is a New Registered Member
Logically would BMW have added VANOS if it somehow made the engine slower or made less performance, think about it, I mean i highyl dont think they added it for gas mileage (i could be wrong ) But I would imagine a motor with VANOS is going to be stronger. Why do you think its all hyped up that in Europe they have Dual VANOS instead of single VANOS like in the US. Think about it. Im not saying they dont respond better to mods, just saying that a motor with VANOS is probably more ideal.
Just my common sense speaking for me
Chris
2003 Mitsubishi Lancer Evolution
Rally Red
Old 01-20-2002, 02:03 AM
a.k.a. BMBUM
Rides:Hard Bargain
Vanos is smoother and makes even power through the entire band (ahem... more low end torque than 92). Non Vanos has more power in the upper band. Not sure of better mileage but i would assume so since it revvs smoother.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
