Originally Posted by mattduncan you might want to tell pepole what the chip is setup for and what ecus it will work with. |
It's for a 1995 E-36 M3 (506) is the DME #. It's setup for the AA stage II/III with a Mitsubishi custom built TD06 20g turbo. Also,the 440cc injectors & head gasket & spacer to lower the compression ratio from AA. Also setup for the throttle body to be honed out/enlarged by Big Bore Throttle bodies....
I kind of figured if their were anyone out there that was interested that they might contact me to find out what/how it might work.
I just sent it back to AA to have it reflashed,they did not charge me anything due to a flaw in it that they had to repair. However,I did ask though if it occurs again,or if I want to reflash the program,due to adding something new,it will be a cost of $50.
