Old 02-12-2005, 02:36 PM
Brasilian Driver.
Rides:Fiat Marea HLX2.4 20v 2002 /Marea ELX2.0 1999
marcostognozzi is a New Registered Member
Question Eletronic Turbo for a new BMW
If someone can answer this...someone who has already done thatīor knows anything about mechanical stuff of these german cars
This message is about the new 5 series "545 4.4 V8" or the new 3 series "Motorsport 330 V6". Nice cars in my opinion...but
Can we install an Eletronic Turbo on Both Cars?
Is it possible to set this Turbo boost to start "at 3750 RPM over++"?
Old 02-12-2005, 02:41 PM
carstereopro's Avatar
bmw's are not V6's, but inline 6's.
An electronic supercharger, maybe. Not a turbo, a turbo is a supercharger driven by exhaust gasses.
You'd have to move some serious air to be effective, IMO not practical.
Phil Chartier
Carstereopro
Old 02-13-2005, 01:23 PM
Track Nut
Rides:Mini Cooper S 2003
Atreus is a New Registered Member
To achieve the same CFM of air that a normal turbo or supercharger does, it takes a lot of power. On a 12 volt system, somebody figured it out to be 1,000 Amps.
Basically, they are a joke and simply restrict your intake.
-Andrew
Old 02-13-2005, 02:15 PM
Brasilian Driver.
Oh, sorry... I typed the wrong thing my intention was to say that 330 has 6 cylinders
By the way, what does "IMO" stands for? What means this short name?
And I still didnīt understand.... You say that these Turbocompressor kits that pushes air and Gas mix into the cylinder wonīt be effective on these cars?
Old 02-14-2005, 04:17 PM
Track Nut
If you are talking about the 12 volt electronic air compressor that you hook up to your intake, then no it won't be effective. As an example, (taken from the thread below) an 03 svt cobra supercharger takes 60 hp to make 10 psi. The compressed air gives the engine more power, but it still takes 60 hp to compress the air. There is no way this 12 volt fan is 60 hp, or even 30 for that manner.
60 horsepower is 44,742 watts, which is 3728.5 amps at 12 volts. I don't know what the amp rating is on BMW alternators, but a dodge diesel 3500 pickup (big ass truck) only has a 160 amp alternator.
Basically, these kits blow air into your intake, but they blow less air into your intake than your car normally uses, so you end up restricting your intake and losing power.
IMO=in my opinion
Here, you can read this electric turbo discussion on racingflix forum
-Andrew
Old 02-15-2005, 03:57 AM
Brasilian Driver.
The turbo kits for M3īs and M5 are witch type, the eletric or what?
Old 02-15-2005, 04:46 AM
Rides:1990 525i
crutex is a Permit Holder
no they're driven off exhaust right? I've never heard of an electric turbo.
Old 02-15-2005, 08:27 AM
Silverstreak328's Avatar
Rides:96 BMW 328is 5spd
Silverstreak328 is a Permit Holder
ELECTRIC superchargers DO NOT WORK. They are a scam and a ripoff please do not buy one.
Old 02-15-2005, 05:01 PM
nondescript's Avatar
All Your Base
Rides:99 M3
No...
No no no no no.
The "kits" for any car that "work" are either belt driven supercharger or turbocharger (exhaust driven)...
Old 02-15-2005, 08:35 PM
twisted69's Avatar
Rides:1995 Bmw M3
twisted69 is a New Registered Member
There is no supercharger/turbo thats electrical. You eather have one driven by exhaust gass (a.k.a. turbo) or of a belt (a.k.a. supercharger) If you happened to buy one already, sorry, you waisted your money. If you are looking into them, you would be better off taking the intake hose and blowing air into it with your mouth. There one of the largest scams out there. Dont fall for it.
Old 02-16-2005, 01:54 AM
Brasilian Driver.
Okay Okay Okay, Once again I mistyped itīs not ELETRICAl itīs ELETRONIC TURBO.
The first thing I want to know if itīs possible to install a turbo on a new BMW like 545 or 330 and set it to work only after 3500 RPM
I have seen some cars that are equipped with a Turbo and when you step softly until 3400 RPM the Turbo doesnīt push hard the car(saving Gas) but if you step over 3500 the turbo works and pushes the car hardly giving it sometimes extra 40 horsepower
My intention is to do that, but as far as I know, German cars are no so simple, I think I have to set the "ECU" for the new stuff Iīm going to install.... RIGHT?
Old 02-16-2005, 07:22 AM
All Your Base
Rides:99 M3
I _think_ you are talking about the turbo spool... I don't think there is any electronic govenor (or bypass) involved in any factory turbo setups. You might just be able to use a larger turbo than your application calls for if you "want" that delay. However, that isn't normally suggested. The better way to save gas with a turbo car is to use self control with the go fast pedal. :P
Oh, and also - yes any changes that you plan to make will require new code on the ECU... When you change something the entire system needs to understand what is happening to it. You'll probably want larger injectors too. No good having more air if you don't have more gas to keep the mix right.
Old 02-16-2005, 08:08 AM
twisted69's Avatar
Rides:1995 Bmw M3
Turbos are always working. There just not making the good hp boost until higher rpms. If your wanted a system that kicks in after 3500 but want to save gas then really your only option is nitrous. I know some people dont like this idea but you only really want like 50hp and dont want it on all the time then i think this would be your best bet. If you get the right system then there is no need to have the ECU messed with. Venom makes a really good and really safe one if your interested in there. you can have it WOT (wide open throtal) activated or you can go hollywood style. (big red button smashing)
Old 02-16-2005, 11:46 AM
Brasilian Driver.
Oh, No nitros. Itīs very difficult to find Nitros Oxide in Bottles for cars, they are very expensive, and here doesnīt have much mechanicals that can make this job...
I prefer to spend more gas in this case
Old 02-16-2005, 11:47 AM
Brasilian Driver.
...by the way, you mean that M5 spends lots of Gas even if you ride it under 3250 RPM as an everyday car?
DTM Power Đ 2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431
