| More HP out of Active Autowerke supercharger Can I crank out more hp out of 99 M3 AA SC ... I know RMS stage 2 you can do the aftercooler upgrade, would i be able to do somethin like that on active autowerke? What would help the most .... pully's
The AA S/c already comes with an intercooler and an oil cooler. The Rotrex is what it is, no upgrades. Unless the bigger Rotrex shows up. BUT you can do the ... *OBD1 manifold upgrade worth 10-20 RWHP and a hell of a pull up top. *You can do UDP's as suggested ~10 RWHP *You can do exhaust, headers(but only with cat delete) or do not waste your money, and nice rear exhaust. *You can do some 3.38, 3.46 or 3.64 gears for some nice zip. *You can do a lightweight flywheel for a quicker spool also. *You could add water injection to further cool your IAT's. *You could remove some weight from the car That could be a good start ![]() Last edited by Marc1119 : 01-17-2005 at 04:01 PM. |
As for marco's recommendations about gearing.. do it.. Shorter gearing with a supercharger is a good thing... the only thing you'll have to worry about is increased highway noise.. but for me it's a good compromise! -Dave
__________________ Dakar Yellow Z3 - 411rwhp/447rwtq SAE Engine Bay | Side Profile | Side Profile | UUC/Wilwood | Dyno | European Car Power: AA Stage II Turbo tuned by NickG:alright, .140" headgasket, ARP head studs, Porsche HFM, M50 manifold, Custom ICS 3" turbo exhaust, walbro 255 fp Driveline: 2.93 LSD, UUC Stage 2 LTW Flywheel/Spec Stage II Clutch, Whalen Shift Machine Suspension & Handling: TC Kline True Match Coilovers 450f/500r, Motorforce/Vorshlag adjustable camber plates, Dinan Stage II sway bars, Powerflex bushings all around, IE camber/toe kit, redline fluids, UUC/Willwood BBK, Slotted E46M3 Rotors, SS Brake Lines, Strong Strut trilogy, IE Subframe Bushings Misc: ACS Type II racing wheels, ACS Pedal Kit, Racelogic Traction Control, Blitz SBCiD Boost controller, Zeitronix ZT2 with remote digital display (Lambda, AFR, EGT, Boost), Sound System upgrades, Gramin Nuvi 360 GPS, Indash DVD system, and leatherZ rollhoop covers, armrest, S54 radiator upgrade and more! |
If you're looking for an AA S/C let me know. ![]()
Goddamn, that is sweet!! Is that your lady? ![]() |
| What about schrick cams? I am looking at the aa supercharger and i have schrick cams on my 99 m3 along with the m50 intake manifold underdrive pullies and going to a LTW flywheel. Also some lighter interior and gutted truck. Also i have an exhaust. Im curious to see the numbers i will me looking at with maybe some custom tunning. |
| I am told you can not run underdrive pulleys and a LTW flywheel just something to think about before diving in to both of those mods. I am getting the clutch from Bimmerworld that weighs 12 pounds total flywheel and clutch twin disk. As opposed to the 52 pounds of the factory pieces. My current clutch will not hold so I am in no big rush to get everything else done. But it is coming soon. Not my chick that would be nice just some chick at a show I did. |
![]() ///BP
__________________ ![]() Bayerische Motoren Werke |
| Running that Rotrex at 11 PSI will probably be a bad idea. First off, it's WAY over the max impeller speed the Rotrex is rated for, which will cause it to fail, maybe not right away, but it won't last long. And then there's an efficiency issue, at impeller speeds so much higher than what the blades were designed to run at, the adiabatic ratings will be crap, you're going to be making a LOT of hot air, so much in fact that you're getting almost no real gains with 3 more PSI. Keep in mind that the AA FMIC is just barely big enough to handle 8 PSI (some claim it's not even big enough for 8 PSI). You can water inject to help a bit with this, and you can always use a bigger FMIC, but that's a lot of effort just to get you back to what you had at 8 PSI, with a blower that's going to melt down really quickly.
__________________ ![]() Info on my M3 conversion - - - - - - - -CLICK SIG PICTURE FOR MORE INFO- - - - - - - - -CarDomain Page |
| They blower will only see those speeds for maybe 2 seconds per shift? If that long. So what are you saying keep the blower and 8 psi and and just run my nitrous to like a 75 shot? and maybe a FMIC sprayer? |
