Old 11-09-2004, 12:44 AM
Game designer, Valve
Rides:BMW M Coupe 1999
Blown M Coupe is a New Registered Member
M Coupe Turbo videos
I finally got around to digitising some video I took a few days ago, so here they are!
The first one is on a private road accelerating from 0-120mph. The second is me having fun with the camera on a tripod. The exhaust sounds so damn cool with the high-flow cat installed, I just had to do a couple of external shots.
Here's a dyno of the car as it performed in these videos. My goal is to improve the 5k-7k range and hit 370whp. A little tuning is still needed.
Old 11-09-2004, 12:56 AM
Oh I almost forgot, this is an Active Autowerke OBD2 turbo stage 2 with no boost controller. If anyone has any thoughts on how to achieve my goals, please let me know! Thanks.
Old 11-09-2004, 01:45 AM
orijinal_poser's Avatar
Freude am Fahren
Rides:gay car
orijinal_poser is a New Registered Member
damn, good job with the M
National Capital Chapter BMW CCA #375530
Old 11-09-2004, 05:43 AM
Rides:06 M3, 97 M3
M3 Kid is a New Registered Member
Blown M Coupe, thanks for sharing the videos. It should be very easy to achieve your goals- turn up the boost and get it tuned. If you have the lower compression head gasket installed, our internals can easily handle 14-15psi. Just make sure you have the proper fuel tuning at those pressures. I would contact AA and ask them for advice, they know whats best for the system.
Joe
2006 M3 ZCP Interlagos/Cinn.
1997 Dakar Yellow M3/2 ** FOR SALE **
Old 11-09-2004, 06:49 AM
very nice, thanks for posting.
Old 11-09-2004, 08:20 AM
Rides:'96 M3 Turbo
///3oris is a New Registered Member
Hey, Nice car... I love the rims... part of the benefit of having an MCoupe, eh? What size tires are you running on those bad boys?
Also, few more questions, if you don't mind... are those magnaflows or stock exhaust? Do you have cats on the car? And finally, how much boost is your Stage 2 running?
Again, nice vids...
Boris
'96 Cosmos Black M3
Engine: Technique Tuning Stage 1 Turbo
348rwhp/342rwtq SAE @ 8psi (with stock cats and no other engine mods!) and AA Gen II Muffler. Drivetrain: Cosmos Black HM2's, SPEC Stage II Clutch, UUC SSK, UUC TME. Suspension: GC Coil-overs, GC RSMs, GC RTABs; H&R SB. Instrumentation: VDO Boost, VDO Oil Press, VDO Oil Temp, VDO Water Temp, Euro Gauge Cluster with Oil Temp, BMW Traffic Pro Navigation
TODO: EMC Diff Reinforcement Mod
Old 11-09-2004, 09:52 AM
Boris - thanks, the rims are Kinesis K19R with 275/35/18 rear, 235/40/18 front. The exhaust is the loud B&B Triflow catback exhaust with a 3" single port high flow cat (not sure what brand). I don't have a boost guage so I'm not certain, but I think we're at 9 or 10lbs boost.
Old 11-09-2004, 10:08 AM
Rides:'96 M3 Turbo
I'll check out the dyno/video forum.
Ahh.. I see... very nice.. I'm jealous of the size tires you're able to squeeze in the rear! Ok, I thought the exhaust sounded louder than usual but didn't know if it was your camera as sometimes they record quite differently than it really sounds (mine is super sensitive, that's why I asked).
You should really have a boost gauge on your car... get one on there so we know what's going on...
Again, sweet ride
Boris
'96 Cosmos Black M3
Old 11-09-2004, 10:13 AM
Sand Castle Expert
Rides:00S4,95M3,93 318w/m62
cgaffney004 is a New Registered Member
Sick F***ing car man, i like it alot. I have always wanted to own one of those.
Old 11-09-2004, 05:34 PM
Rides:Many Turbo BMW's 1025rwhp currently..
Imported Cars has obtained their Street LicenseImported Cars has obtained their Street License
Great #'s, have Karl give you 2-4 degree's more timing in the mid to upper end. 25-35rwhp gain can be achieved, good luck. 1 bar of boost with proper tuning = 400+whp with ease.
Old 11-09-2004, 06:07 PM
Certified C.M.F.
Rides:Milf, 328is
328ischef is a New Registered Member
good work
Hey man, sounds like you are well on your way. If you get that thing tuned properly you should be set. I suggest getting a fuel pressure regulator if you havent already, and something that will tune your air/fuel, you should be able to gain at least 25-30 HP if that is done correctly. You always have the option of raising your boost, but work with your other options first to be safe.
Josh
stock
Old 11-09-2004, 06:23 PM
533i's Avatar
PC Load Letter
Rides:E30 325i 1990
533i is a New Registered Member
Cool car man! Keep tuning that beast and it will be a.... uhh... beast... soon....
Be Fast, Be Brave, BMW.
Old 11-09-2004, 06:26 PM
Rides:'96 M3 Turbo
George, do you even know what kind of tuning he's running now? How much timing? Where? Or, even better, how much boost or anything else? How the hell do you predict where to add timing and how much power it will gain? Is this the way you calculate power on your cars?
I wouldn't make recommendations like that without even knowing anything about his setup... let him and Karl work that out... I'm sure Karl knows much better what the car needs.
Boris
'96 Cosmos Black M3
Old 11-09-2004, 06:57 PM
Scott///M's Avatar
Rides:BMW, 325is, 1988
Scott///M is a New Registered Member
nice.
very nice...
tell me more about the high-flow cat you have installed. your Coupe sounds awesome.
Scott///M | BeerTech #467 | Spec E30
Old 11-10-2004, 06:19 AM
Rides:06 M3, 97 M3
Boris, I'm assuming George is giving that advice under the assumption that it is "out of the box" stage II software, and as we both know, George has extensive experience with AA stage II cars..
Joe
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
