| Proper Crank Case Ventilation with S/C Setup I just installed an RMS Stage I S/C this fall and love it. However my airfilter fell off and in the process of reinstalling noticed heavy oil flow coming out of the s/c intake tube down through the HGM and into the airfilter. I presume this is from the crank case ventilation going directly to the inlet tube without any kind of drain back into the oil pan. Any body else experience this. I was a little uncomfortable ditching the stock cyclone system, maybe this reaffirms my fears. Any insight would be appreciated. Complete Mods as follows: m50 manifold, Gen III exhaust, 3.5"hfm, RMS Stage I. thks |
| Since my system was replumbed, pic attached, the hosing seems drier inside. The 1" hose coming off the valve cover which feeds the breather system is dry as a bone. Hence, youd expect the hoses it feeds to be dry as a bone. The catch can which Marco gave me is also dry. I mean, its got a film inside of it, but there is NO accumulated oil at all. In comparison, before the replumb, the hoses were much wetter, and oil was definitely pooling inside the manifold. When you get up there in boost, ie, over 6 psi or so, Ive been told the dinan system is a bad design. Alot of people seem to feel the replumb is the correct way to do it with forced induction.
__________________ Paul E '99 White M3 71k mi; Dinan SC kit, 6"/3.48" sc pulleys, Aftercooler: 10.5 psi-367 SAE rwhp/304 rwftlbs @80 degrees ambient (still with OBDII manifold); DynoTuning by Nick G (techniquetuning.com); Speed Shop: Imported Cars of Stamford; AA-Aquamist Water Injection, exhaust; Fikse FM-10s; Koni Suspension; Stealthboxes http://photos.yahoo.com/boostm3 ![]() Last edited by paul e : 11-09-2004 at 01:16 PM. |
| Can someone explain how this is plumbed. What was done to the Crank Vent going into the manifold? ALso...under the Dinan SC discharge tube are two nipples. One for the BPV. What is the other nipple for?
__________________ 97 M3/4: 307+ RWHP SAE Dinan SC 6 PSI RMS Aftercooler AA Turbo Clutch AA LTW Flywheel Supersprint Exhaust AA Track Pipe Dinan Suspension E46 M3 RSM AA Strut bars (F&R) XBrace BMP Rear Camber Correcting Arm IFG A5 Forged LTW wheels on Pilot PS2 CF Hood And a whole bunch of forgotten and replaced upgraded items. |
| gerry, heres a pic that someone else had posted somewhere. Where the difference is, is that the hose out of the valve cover, instead of going to the oil separator in the diagram, goes to the nipple on the intake tubing to the blower.. the nipple on he separator then is capped. The plug at #3 stays. The hose wiht the check valve in the pic is not there. This pic is very similar to the dinan system, with the listed mod about going to the intake being implemented. The thing labeled 'check valve' would be analogous to Dinans 3 way breather control valve.. ON mine, we just go directly from teh valve cover to the intake side of the blower, with an inline catch can to catch any vapors.. Ive found very little of it so far.. >>ALso...under the Dinan SC discharge tube are two nipples. One for the BPV. What is the other nipple for?<< One for the bpv, the other I believe is for connection to the Idle Control Valve.
__________________ Paul E '99 White M3 71k mi; Dinan SC kit, 6"/3.48" sc pulleys, Aftercooler: 10.5 psi-367 SAE rwhp/304 rwftlbs @80 degrees ambient (still with OBDII manifold); DynoTuning by Nick G (techniquetuning.com); Speed Shop: Imported Cars of Stamford; AA-Aquamist Water Injection, exhaust; Fikse FM-10s; Koni Suspension; Stealthboxes http://photos.yahoo.com/boostm3 ![]() |
| Thanks Paul
| Thanks Paul, what's the contraption at the end of the hose before going into the s/c inlet. Is that the catch can or some kind of oil seperator. What do you attribute the improvement to, just the larger diameter hose. thks |
| ertelj.. what contraption.. in the photo u mean? Thats a catch can marco gave me a while ago off some compressor at his job. Seems to function decently as a catch can.. As to why things are drier now, I really have no idea. Im really not an expert on this whole crank case breather/pcv/cyclone separator field anyway. Im only reporting what others have told me whom I trust; engine experts have told me that the Dinan breather system is just plain lousy, and it gets worse the more boost you run.
| what check valve? Can u describe it a little more??
| >>In the diagram above there is a check valve that is pictured between the intake of the blower and the top of the valve cover for ventilation.<< Ok.. i see it, over on the left. Keep in mind this is a modified redo of what looks to be an oe ETK sketch, with someone's intended mod being shown. On the Dinan system, for instance, the number '1' in the sketch is the location of their 'Breather Control Valve'. It is a valve which is run by manifold pressure. Under vacuum, the valve is in a position where the vapors follow the OE path down to the cyclone separator; under boost, the valve is repositioned, and the vapors flow directly into the intake side of the blower, for recirculation. I guess the 'check valve' in the sketch would be for the purpose of making sure the hose its in only Exits air, and does not intake it. But, even in the implementation pictured, why would it be needed? ie, doesnt air only flow OUT of the valve cover, both in Vacuum and in booste? And if thats true, why would you ever need a check valve there? I dont know what his purpose was. Actually, the pictured system looks Very similar to the Dinan system, if you make one simple change; take the hose that goes from #1 to whats listed as 'vented to atmosphere', and route it to the intake side of the blower, as he indicates hes going to. Once thats done, and #1 is a 'breather control valve' then its the same as the Dinan pcv system.
